Old 05-06-2012, 08:38 PM   #1
good ol diy'er
good ol diy'er is on a distinguished road
Default fuel problem
car starts and idles fine but after engine builds heat if you rev the motor to about 3000 to 3500 rpm it sounds like it's choking out and not getting enough gas. Not sure if it is the filter stopped up,weak fuel pump,or fuel pressure regulator. But i am going to check fuel pressure just wondering what should the pressure be?
Thanks for all the help so far
Tim
Add to good ol diy'er's Reputation
Rate the quality of this post and help good ol diy'er reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
good ol diy'er is offline   Reply With Quote
Old 05-06-2012, 08:50 PM   #2
Default Re: fuel problem
Year, make, model, mileage? Just a guess but if this car has high mileage and a clogged catalytic converter, pull the front O2 sensor off for a LOUD drive.
Old 05-16-2012, 08:35 PM   #3
good ol diy'er
it is a 2000 sl2 with about 119000 miles but i will try it without o2 sensor
Old 05-16-2012, 09:41 PM   #4
madpogue
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
1996 SW2
If it's on the original fuel filter/regulator, it's almost 20,000 miles overdue. Only the NAPA/Wix and OEM replacement units provide the proper fuel pressure.
Add to madpogue's Reputation
Old 05-16-2012, 11:51 PM   #5
Spaghettiohead
Spaghettiohead is on a distinguished road
1999 SC2
No joke?
Add to Spaghettiohead's Reputation
Rate the quality of this post and help Spaghettiohead reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Spaghettiohead is offline   Reply With Quote
Old 05-17-2012, 12:00 AM   #6
adventureoflink
adventureoflink's Avatar
Originally Posted by Spaghettiohead View Post
No joke?
No joke. For bonus points, get a filter we don't recommend, but don't be surprised if you eventually pull SES codes P0171 and/or P0301-P0304 (especially P0303 since you have a DOHC) and those codes are traced back to burnt valves from lean fuel mixtures.
Not to mention the maintenance interval for the fuel filter on a 1998-2002 is every 100k miles.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive & Well
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, prolly needs front driver strut
Add to adventureoflink's Reputation
Rate the quality of this post and help adventureoflink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-17-2012, 12:16 AM   #7
Spaghettiohead
1999 SC2
Well hell, just replaced mine with an AutoZone part 800 miles ago...might as well replace that while I've got everything apart now anyway, if that's really the consensus here! I'm embarrassed to admit as well, that the filter I pulled off was original with 260K. Never realized it was a regulator as well. Oops.
Old 05-17-2012, 07:34 AM   #8
madpogue
1996 SW2
Regulator notwithstanding, I doubt there's any vehicle on the road for which a fuel filter, even a stand-alone, would last more than 100,000 or so miles, let alone 260,000. This is why every Saturn that left Spring Hill had a maintenance schedule in the glove box with the owner's manual (and for secondhand owners, they're abundantly available on eBay).
Old 05-17-2012, 01:12 PM   #9
Spaghettiohead
1999 SC2
I readily admit to that neglect, but I've been on top of everything else, and she's run like honey for the decade I've owned her...I can live with such a one-time infraction LoL
fuel problem? tim2at429 S-Series Tech 9 04-29-2012 11:02 AM
I don't have a fuel pressure gauge, is there a way to check problem fuel pump without dddaaa S-Series Tech 6 08-06-2011 02:09 PM
Fuel problem? swv3 S-Series Tech 2 01-19-2011 09:03 PM
fuel problem panama58 S-Series Tech 3 12-18-2009 12:38 AM
Fuel Problem kirchc L-Series General 7 10-10-2005 12:29 PM
