Old 04-30-2012, 06:58 AM   #1
2006 ion2
2006 ion2 will become famous soon enough
2007 ION-2 Sedan
Default update for those interested
LEDs are still holding strong. the only tricky one to keep an LED bulb happy in is the license plate light. DRLs, brake lights and rear blinkers are all holding strong for a year and a half. be careful to do research, buy quality over cheap, and buy a bulb that will PERFORM the same as what you're replacing. after a couple attempts to replace the CHMSL, I have found it a bad idea. it's hard to get LEDs in that spot that will perform the same, but it will also disable cruise control unless you use a load resistor.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 04-30-2012, 09:29 AM   #2
MeanGreen
MeanGreen is on a distinguished road
MeanGreen's Avatar
2004 ION-2 Sedan
Default Re: update for those interested
Which LED's did you put in for the front turn signals? I'm looking for ones that either have the resistor built in or are compatible with our cars
2004 ION 2 Sedan
-Autozone short ram
-FE5 Suspension with Pedder springs
-4300k Hi-lo HID
-OPTX green underglow
-35% tint all around
-Kicker Audio all around
Add to MeanGreen's Reputation
Rate the quality of this post and help MeanGreen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MeanGreen is offline   Reply With Quote
Old 04-30-2012, 09:53 PM   #3
2006 ion2
2007 ION-2 Sedan
I don't use resistors, they just waste the energy you save with the leds.
I just let the blinker blink fast. any bulb that doesn't make it blink fast just has a resistor in it.
I use 3157-R18-T and 3157-A18-T from superbrightleds.com, and they outperform the stock bulbs in the brake lights and rear blinkers. don't replace just the front, also replace the rear (stock bulbs can't keep up with the faster blinking, anyways). you might want the 45 LED bulbs up front, but the 18s do pretty good. the only thing I had to do was trim the sockets' lip a little to let the bulbs, it's not an important part of the socket, and you can still go back to stock bulbs later if you want.
2007 Saturn Ion 2
Old 05-01-2012, 06:55 PM   #4
MeanGreen
MeanGreen's Avatar
2004 ION-2 Sedan
I'm going to replace the rears with full LED replacement lights
http://www.ebay.com/itm/290667638936...ht_5527wt_1139
So I'd rather have the slower blinking though, I don't think I'd ever get used the to "psycho blink" I guess I'll keep looking till I find a set of front LED's I like
2004 ION 2 Sedan
-Autozone short ram
-4300k Hi-lo HID
Old 05-01-2012, 11:20 PM   #5
2006 ion2
2007 ION-2 Sedan
don't. those list they work on sedans and coupes, that's impossible. I don't trust that seller. also, if you run the numbers, you will see some pretty impressively lower peak amp draw. this makes the strain on the alternator a lot less, and can even help increase gas mileage.
2007 Saturn Ion 2
Old 05-02-2012, 07:19 AM   #6
MeanGreen
MeanGreen's Avatar
2004 ION-2 Sedan
The seller is selling both coupe and sedan style tail lights, so i'm guessing they're too lazy to make 2 separate ads, I'll contact them to be sure but the picture is for the sedan lights, a separate post he has the coupe lights
2004 ION 2 Sedan
-Autozone short ram
-4300k Hi-lo HID
Old 05-03-2012, 10:21 AM   #7
SilverSpectre
SilverSpectre is on a distinguished road
SilverSpectre's Avatar
2007 ION-3 Quad Coupe
2006 VUE 2.2L
So to clarify, when you replace bother the front turn signals/DTRL's and rear turn signals/brake lights, things fit just fine but you get "hyper flash"? I've been considering doing this for a while.
Thinking of getting the 45's too. I like "Superbright". lol
2007 Saturn Ion 3 QC - "The Silver Spectre"
Resurrected 12/29/11
OZ Allegerita Racing Wheels, Progress Rear Sway Bar, TWM Short Shifter, LED interior, Custom Gauge Face, Infinity Speakers
Add to SilverSpectre's Reputation
Rate the quality of this post and help SilverSpectre reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SilverSpectre is offline   Reply With Quote
Old 03-16-2013, 11:40 AM   #8
2006 ion2
2007 ION-2 Sedan
update: superbrightleds now has a direct replacement for the CHMSL. I upgraded the brake lights to the newest style with more output (and more draw) and it allowed me to run all but 2 bulbs (not counting headlamps and fog lamps) as LEDs. I had to leave 2 CHMSL bulbs as incandescent to retain cruise.
sorry, silverspectre, yes, the blinkers just blink fast. I had to trim the socket (they had extra tabs of plastic that were not necessary for the retention of the bulbs), but it's not hard to trim.
2007 Saturn Ion 2
Old 03-16-2013, 04:27 PM   #9
2006 ion2
2007 ION-2 Sedan
I also modified the CHMSL with a piece of aluminum foil to stop so much of the light from going down and back, and into the cabin. depending on how well it works, I may just use a piece of sheet aluminum.
2007 Saturn Ion 2
Old 03-16-2013, 09:10 PM   #10
snakes
snakes is on a distinguished road
snakes's Avatar
2005 ION-1 Sedan
I just installed those eBay led tail lights on my 05 ion sedan. The fitment was good and ill see how long they last. I'm kind of a noob with LEDs, lights, etc the only thing I wasn't sure about was there was a small square black box( balis(?) looked like a small battery pack attached to a green wire inside the housing of the tail lights. It had sticky tape on one side and wasn't sure what it does . The stock tail lights didn't have them so guessing its something with the LED.
Add to snakes's Reputation
Rate the quality of this post and help snakes reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
snakes is offline   Reply With Quote
Old 03-17-2013, 07:15 AM   #11
2006 ion2
2007 ION-2 Sedan
not sure what a balis is, but I'm sure that is a load resistor so your blinker doesn't blink fast
2007 Saturn Ion 2
Old 03-18-2013, 10:07 PM   #12
MeanGreen
MeanGreen's Avatar
2004 ION-2 Sedan
I used 3M double sided sticky tape...3 years ago, no more red light in my rearview when I hit the brakes!
2004 ION 2 Sedan
-Autozone short ram
-4300k Hi-lo HID
Old 05-11-2013, 06:36 PM   #13
Gman91107
Gman91107 is on a distinguished road
2006 ION-2 Sedan
I put switchback LEDs on mine they are awesome with retrofitted Projector headlights
Add to Gman91107's Reputation
Rate the quality of this post and help Gman91107 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gman91107 is offline   Reply With Quote
Old 05-11-2013, 09:01 PM   #14
NotAHondaDriver
NotAHondaDriver is on a distinguished road
2007 ION-2 Quad Coupe
The glad from the brake light doesn't bother me, and I'm just going with the super white xenon bulbs from ZZP for head lamps and that'll do it for me, lol.
What a tie...
Add to NotAHondaDriver's Reputation
Rate the quality of this post and help NotAHondaDriver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NotAHondaDriver is offline   Reply With Quote
Old 05-13-2013, 02:05 PM   #15
theredneckvlog
theredneckvlog is on a distinguished road
Ya. Same here. Don't want to over do it.
Add to theredneckvlog's Reputation
Rate the quality of this post and help theredneckvlog reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
theredneckvlog is offline   Reply With Quote
Anyone interested... OnDaGround Ion General 0 02-10-2009 01:18 PM
Are You Ppl Interested!!! rapidion Events 24 04-26-2007 12:35 PM
who would be interested? philip1 L-Series Tech 0 09-20-2006 04:47 PM
Ne1 interested in a aem cai soccer69er Ion General 15 03-10-2004 10:11 AM
Anyone interested in this mod? Jon94SoLo2 Mods and Performance 5 07-18-2001 11:48 AM
