Old 04-14-2012, 09:28 PM   #1
jam12
jam12 is on a distinguished road
Default Rack and pinion catches when turning
I have a 2003 Ion and have read about the power steering motor problem. My issue is in the rack and pinion I think because when you turn the wheel to the right when sitting to park when you get to the initial turn off center the wheel locks up and you can feel a bad clunk in the left front. So I even raised the front end up to release the pressure on the front end and wheels,and when you turn the wheel back and forth simulating a turn you can feel the steering want to lock. I took the knuckle loose at the gear to ck the u-joint and it is ok. The u-joint at the steering column seems to be ok also when I spin the wheel disconnected it is free from binding. I guess what I am asking is has anyone replaced the rack for this binding and locking up problem? Thanks
Add to jam12's Reputation
Rate the quality of this post and help jam12 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jam12 is offline   Reply With Quote
Old 04-20-2012, 08:34 PM   #2
jam12
Default Re: Rack and pinion catches when turning
update..............I replaced the rack and pinion and found that the pinion and gears in rack were binding off center. When I would try and turn the pinion in the vice you could feel the gears jamb and stick, not very safe if your driving and need to turn sudden but anyways that was the problem. I might add also this was the EASIEST rack and pinion to replace in the 30 years of working on cars!
Old 04-28-2012, 05:16 PM   #3
Spaghettiohead
Spaghettiohead is on a distinguished road
1999 SC2
Do you have to bleed the system after a rack replacement?
Add to Spaghettiohead's Reputation
Rate the quality of this post and help Spaghettiohead reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Spaghettiohead is offline   Reply With Quote
Old 04-29-2012, 12:01 AM   #4
2006 ion2
2006 ion2 will become famous soon enough
2007 ION-2 Sedan
what would you have to bleed? it's a manual steering rack.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 04-29-2012, 05:40 PM   #5
Spaghettiohead
1999 SC2
Assumed it was power...never mind!
Old 04-29-2012, 06:38 PM   #6
2006 ion2
2007 ION-2 Sedan
power steering, manual rack.
2007 Saturn Ion 2
Old 04-29-2012, 10:17 PM   #7
kg6mvb
kg6mvb will become famous soon enoughkg6mvb will become famous soon enough
kg6mvb's Avatar
2003 ION-1 Sedan
All Ions have electric power steering. Nothing to bleed.
Proud to be a member of both the Ham Radio and Saturn Cults.
Avitar is a Saturn V rocket engine.
Add to kg6mvb's Reputation
Rate the quality of this post and help kg6mvb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kg6mvb is offline   Reply With Quote
Possible bad 95 Rack and Pinion Canyon S-Series Tech 18 09-08-2008 07:57 PM
rack and pinion Jeremy13 S-Series General 3 06-09-2008 01:30 PM
99 SL2 Rack and Pinion question mlambert77 S-Series Tech 4 04-10-2007 03:03 PM
Rack & pinion Lafarga L-Series Tech 7 02-06-2006 04:15 PM
Possible rack and pinion problem? JS593 S-Series General 16 01-11-2006 03:53 PM
