Old 04-08-2012, 10:00 AM   #1
edmck101
edmck101 is on a distinguished road
Default Larger Tire Size for Offroading
We purchased an '05 Vue (3.5L AWD) a couple of years back to tow behind our motorhome. It came with 235/65R/17 tires which are just slightly taller than the factory 235/60R/17 tires. After selling the motorhome we landed here in Phoenix where we've discovered the fun of exploring old mining roads that lead up into the nearby mountains. Some of these roads are strictly 4WD but many are passable (with patience and care) in our Vue thanks to the good ground clearance. My question: Can we safely increase that clearance by increasing the Vue's tires size up to 235/70R/17? I know the Vue isn't the most stable vehicle on the road; will I be making it worse by going to bigger tires? I could use the extra clearance for the backroads but I don't want to screw up the car's handling or steering geometry on the highway. Thanks for your thoughts.
Add to edmck101's Reputation
Rate the quality of this post and help edmck101 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
edmck101 is offline   Reply With Quote
Old 04-08-2012, 11:23 AM   #2
RedGeminiPA
RedGeminiPA will become famous soon enough
RedGeminiPA's Avatar
2004 VUE 3.5L
Default Re: Larger Tire Size for Offroading
My '04 FWD V6 is wearing 245/65/17s (They were on it when I bought it in November), and I find the highway stability to be just fine. It obviously doesn't handle as good as my '05 Red Line, but it definitely rides MUCH smoother. When the time comes to replace them, I'll see if I can find a similar tire.
I don't think I'd go any larger than these. They seem to only effect the speed odometer by an average of 3 MPH at 70 MPH.
They also fill in the wheel wells nicely.
Avid Apple, car and vacuum enthusiast. Don't hate! ;)
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
http://www.facebook.com/SaturnFansNorthEast
Add to RedGeminiPA's Reputation
Rate the quality of this post and help RedGeminiPA reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RedGeminiPA is offline   Reply With Quote
Old 04-12-2012, 04:46 PM   #3
Thundercat
Thundercat is on a distinguished road
Thundercat's Avatar
2004 VUE 3.5L
I like the "V-Tec V6" on the tailgate!....where did you find it?
2004 Saturn Vue AWD.
Add to Thundercat's Reputation
Rate the quality of this post and help Thundercat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Thundercat is offline   Reply With Quote
Old 04-12-2012, 09:08 PM   #4
emsvitil
emsvitil has a spectacular aura aboutemsvitil has a spectacular aura about
emsvitil's Avatar
I don't think you'd have any stability issues.
You might have rubbing issues up front..........
With current tires, turn the front wheels back and forth and see how close the tire comes to rubbing anything (inner fender plastic).
From that you can see how much larger in diameter you can go.
Ed
Add to emsvitil's Reputation
Rate the quality of this post and help emsvitil reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emsvitil is offline   Reply With Quote
Old 04-12-2012, 09:50 PM   #5
RedGeminiPA
2004 VUE 3.5L
Thanks. I found the "VTEC" badge on eBay... the V6 is stock.
I think they were around $9 each... decent, but the finish is getting goofy already.
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
Old 04-12-2012, 10:03 PM   #6
RedGeminiPA
2004 VUE 3.5L
The 235/70/17 would be fine, considering my 245/65/17 doesn't rub at all. There's a little room left.
235/70/17 = 164.5mm sidewall height
245/65/17 = 159.25mm sidewall height
5.25mm difference won't mean much, when 235/70/17 is 10mm more narrow than mine.
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
Old 04-12-2012, 10:17 PM   #7
Tom92SCm
Tom92SCm will become famous soon enoughTom92SCm will become famous soon enough
Tom92SCm's Avatar
BIG tires on VUEs:
http://www.saturnfans.com/forums/sho...d.php?t=178920
http://www.saturnfans.com/forums/sho...d.php?t=147440
http://www.saturnfans.com/forums/sho...d.php?t=161594
2012 Ford Escape V6 Limited AWD
2004 VUE 2.2L 5 speed
1997 Ford Explorer XLT 4x4
Add to Tom92SCm's Reputation
Rate the quality of this post and help Tom92SCm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tom92SCm is offline   Reply With Quote
Old 04-12-2012, 10:49 PM   #8
RedGeminiPA
2004 VUE 3.5L
The second link is interesting...
"The Problem : The stock P235/60SR17 tire is as big as you can safely go without rubbing your lower front strut braces
The Fix: Add wheel spacers. You can find them on google shopping Keyword search “5x4.5 Wheel Spacers”. Only Add a 1.5 inch spacer or bigger spacer. Any less will not be sufficient for bigger tires. However it is true only the front 2 tires need spacers. I encourage you to purchase a set of 4. It gives the Vue a mild aggressive stance that stands out."
I haven't looked that close at my '04's clearance concerning the strut. I thought there was still a good 3/4" (or so) left with my 245/65/17s. If I remember, I'll check it tomorrow. Granted, my tires aren't new, but they still have very good tread left. I haven't had a front wheel off of it yet, but I feel certain there aren't spacers on it.
He is referring to the bottom plate for the spring on the strut, right? Above-the-tire clearance?
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
Old 04-17-2012, 04:22 PM   #9
RedGeminiPA
2004 VUE 3.5L
Here's a pic of the spacing left with these tires:
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
Old 04-17-2012, 05:25 PM   #10
djb383
djb383 is on a distinguished road
djb383's Avatar
I'm not to sure about the 235/70/17 tire.....that's a 30" tall tire, mathematically and stock 235/60/17 is 28" tall.
Add to djb383's Reputation
Rate the quality of this post and help djb383 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
djb383 is offline   Reply With Quote
Old 04-17-2012, 06:30 PM   #11
RedGeminiPA
2004 VUE 3.5L
Going by my tires, 5.25mm more would rub, and mine do not have spacers on them. My pinky barely fits between the tire and lower spring plate on the strut (pictured above).
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
Tire Size Help (widest tire on OE wheel) Noodles1985 S-Series Tech 11 03-28-2011 06:31 AM
Would this tire size fit on a SL2? importfanatic66 S-Series General 8 03-01-2011 05:08 AM
higher mpg with 'larger' tire? abinder S-Series General 12 12-10-2008 05:43 AM
17" Konig Unknown, size? tire size? 92[SL2] S-Series Tech 1 05-14-2007 10:45 PM
Offroading adventure number 4 for my sc2 rugersc2 S-Series General 13 05-24-2006 12:59 PM
