#1 | ||||
![]() Join Date: Apr 2012
I have a 2003 Saturn Ion sedan.
On the way to work this morning the car started making a clicking noise which seemed to be correlated to acceleration. It would be steady at idle and increase frequency as I accelerated. When I pulled into the parking lot, it was much worse and I left the car on and stepped out to get a better chance to listen to it, it sounded like there was also some type of grinding noise. Now I went out to start the car and it will not. All i get is a whirring noise. The battery seems to be okay because the headlights do no dim when trying to start the car. Any idea what could have happened?
#2 | ||||
Check your oil level recently?
#3 | ||||
Nope, I am due for a change
#4 | ||||
related?
#5 | ||||
:facepalm: not the oil quality, the oil level.
sounds like you had a starter or engine failure, tow it to a reputable shop. ... 2007 Saturn Ion 2 2003 Chevrolet venture lt trifecta dealer for the U.P. and WI. There is no two door ion. Proudly driving one of the last saturns produced before gm killed the brand.
#6 | ||||
that really sucks, thanks for your help
#7 | ||||
Hope it turns out OK.
Did you double check the Oil Level yet? If it's good... suppose it might have been a failure with the Oil Pump. But be it Oil pressure or level I'd have figured you might have seen an Oil Warning Light if it was low enough.
#8 | ||||
The oil was very low, must have a leak. I live in a condo development so i'm not always in the same spot, so i must have missed a leak or something.
I added oil, still won't start. When trying to start i did notice a quiet tapping noise inside the top of the engine.
#9 | |||||
#10 | ||||
call around for prices on a gently used engine from an 03-04, sounds like you toasted yours
| Thread Tools | |
| Display Modes | |
| whirring noise when heat is on... | paul780 | Aura General | 10 | 10-20-2009 07:46 AM |
| Whirring noise..? | amina516 | S-Series General | 5 | 02-28-2006 04:50 AM |
| Whirring Noise | chris_warner | S-Series General | 9 | 02-27-2006 02:56 PM |
| Whirring Noise | chris_warner | Ion Red Line | 1 | 02-13-2006 09:15 AM |
| Whirring noise as I'm slowing down.... | Blue Goose | Vue General | 13 | 12-02-2004 06:23 AM |
