#1 | ||||
![]() Join Date: Dec 2011
2006 VUE Red Line
2006 ION-3 Sedan
i have a 06 saturn vue red line with factory rims and my i been noticing that my lug nuts get loose between every 2 weeks or so, could the aluminum wheels be the cause of it? getting hot and cold,(meaning how aluminum expands when hot and shrink when cold)does anybody else has this problem or just somebody wants me dead!!! lol
#2 | ||||
How are you tightening them (ie with the vehicle on the ground or while the vehicle is in the air)? Are you torquing them? If so, to what?
In short, aluminum wheels can have a tendency to loosen the lug nuts due to the heating as you described. But usually not to the point of being noticeably loose- they just loosen by 15-20 ft-lbs or so and retorquing them once should be good. ... 2012 Ford Escape V6 Limited AWD 2004 VUE 2.2L 5 speed 1997 Ford Explorer XLT 4x4
#3 | ||||
2006 VUE Red Line
2006 ION-3 Sedan
im just using a 4 way on the ground, no torque wrench im not sure whats the torque rating at....
#4 | ||||
I believe it's 100 ft-lbs.
... Avid Apple, car and vacuum enthusiast. Don't hate! ;) Current: '04 FWD 3.5L Previous: '05 AWD Red Line '02 L200 http://www.facebook.com/SaturnFansNorthEast
#5 | ||||
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2008
RGPA - spot-on ... according to service manual the torque is 100 ft pd - tightened in a star pattern - if they loosen again after being torqued - the lug-nuts should probably be replaced (don't even want to think about the studs).
... Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
#6 | ||||
And it's a really good idea to mount the wheel and tighten all the lug nuts while the vehicle is in the air. I don't torque them in the air, but I can usually wedge my foot under the tire enough to keep it from spinning too much while I tighten the lugs- in a star pattern. And when I do set it on the ground and do the final torqueing, I'm usually no more than 1/2 turn away from the torque spec.
#7 | ||||
2006 VUE Red Line
2006 ION-3 Sedan
thanks for the info everybody...
| Thread Tools | |
| Display Modes | |
| Bumper Coming Loose | sl1driver | S-Series General | 12 | 08-28-2009 12:57 AM |
| Heat shield coming loose. | harley2003 | S-Series General | 9 | 11-22-2008 07:15 AM |
| Lettering coming loose? | ToledoEngineer | Sky General | 11 | 07-03-2008 04:19 PM |
| Batter cables keep coming loose. | oldgoat | S-Series General | 5 | 12-15-2005 09:43 PM |
| Door Panel Coming Loose | wfyoung3 | S-Series General | 2 | 10-14-2005 11:40 PM |
