#1 | ||||
![]() Join Date: Apr 2012
1994 SL2
Code 76 shows unstable ATS sensor. Where is it and what is it . 1994 sl2. Thanks !!!
#2 | ||||
![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005
2003 VUE 3.0L
2007 VUE 3.5L
I'm thinking that's a tranny Information Flag . . .
#3 | ||||
Check this code list. https://www.saturnwiki.com/wiki/inde..._Trouble_Codes
#4 | ||||
2003 VUE 3.0L
2007 VUE 3.5L
You probably want to check the resistance on that 4th Gear Solenoid . . .
http://www.youtube.com/watch?v=1tDmBlKn2jI I'm thinking you have an open in that circuit (blown TRS Fuse, burned out Solenoid or bad connection somewhere).
#5 | ||||
1994 SL2
Chaz , you are AWESOME !!!! I checked the fuses and the Trs 4 was blown! No wonder there was erratic shifting. Replaced the fuse , shifts great and code is gone!!!! Not too many lookers nor responses to my question ( maybe too technical? ) but yours was the one I needed. Thanks !!!!
![]() Last edited by 1960vw; 04-21-2012 at 11:12 PM.. Reason: spelling
#6 | ||||
![]() ![]() ![]() Join Date: Apr 2009
And now you have to figure out why the fuse blew to begin with....
... 97 SL2 DOB: 3/19/97 Date Obtained: 5/30/07 Status: Alive & Well 2004 Merc G.Marquis GS DOB: 2/4/04 Date Obtained: 7/6/12 Status: Alive, prolly needs front driver strut
#7 | ||||
Fuses that are subjected to pulsed current tend to suffer metal fatigue over time and crack. This is a "blown fuse" to most observers as it is open circuit. Well known in industry and is addressed by periodic wholesale fuse replacement and other arrangements. For this phenomena to be a real problem the peak of the repetitive current pulses have to be reproaching the nominal rating of the fuse.
| Thread Tools | |
| Display Modes | |
| Codes: cylinder 3 miss fire, camshaft position sensor. Transmission range sensor | Puck head | S-Series Tech | 13 | 01-12-2012 06:52 PM |
| Bad Crank Sensor/02 sensor/fuel pump help!! | Olegoat | Vue Tech | 4 | 09-05-2011 05:23 AM |
| error code 1137- O2 sensor bank 1, sensor 2 location? | jwox | L-Series General | 3 | 03-08-2011 10:06 PM |
| PO133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) | Donny | L-Series Tech | 5 | 02-15-2007 11:21 PM |
| Does anyone now if the sensor on the transaxle is the same as the coolant temp sensor | BigDaddyDrex1 | S-Series General | 4 | 05-27-2005 02:29 PM |
