Old 04-10-2012, 10:24 PM   #1
Shadow_tek001
Shadow_tek001 is on a distinguished road
Shadow_tek001's Avatar
Default What's this fuse for????
Hello all...
I had to replace my Horn, so my Vue now sounds like a 93 isuzu trooper
But when I was diagnosing the issue, I got a bit confused over which fuse was for the horn - I quickly realized that the word "HORN" is written under the horn fuse and not above it, so then that raises the question what the heck is the Fuse marked * * for??? it's right underneith the horn fuse and It does not say anywhere in my manual what it's for.
Edward.
Add to Shadow_tek001's Reputation
Rate the quality of this post and help Shadow_tek001 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Shadow_tek001 is offline   Reply With Quote
Old 04-11-2012, 06:27 AM   #2
RedGeminiPA
RedGeminiPA will become famous soon enough
RedGeminiPA's Avatar
2004 VUE 3.5L
Default Re: What's this fuse for????
What year is yours? I'm not sure if my fuse boxes are the same, or I'd check it out.
You could always pull it out and see what stops working...
Avid Apple, car and vacuum enthusiast. Don't hate! ;)
Current:
'04 FWD 3.5L
Previous:
'05 AWD Red Line
'02 L200
http://www.facebook.com/SaturnFansNorthEast
Add to RedGeminiPA's Reputation
Rate the quality of this post and help RedGeminiPA reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RedGeminiPA is offline   Reply With Quote
Old 04-11-2012, 09:17 AM   #3
far2grumpy
far2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to all
far2grumpy's Avatar
Originally Posted by Shadow_tek001 View Post
... that raises the question what the heck is the Fuse marked * * for??? Edward.
Edward ... the explanation should be on underside of the fuse/relay cover ... the * * denotes emission fuse (HO2S heating circuit).
The boxes can be used with 4 or 6 cylinder engines ... so the fuse will be 10A for the 4 and 15A for V6.
Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
What Fuse Is This?? coreymichael L-Series General 5 09-13-2011 04:36 PM
Dome/trunk light fuse = same fuse? stoke21 L-Series General 5 10-29-2010 07:15 PM
Best 12v Switched Fuse For Interior Fuse Box? 803scdantes S-Series Tech 2 03-11-2010 05:25 PM
Missing fuse in fuse box middleman L-Series Tech 2 01-31-2010 08:58 PM
Supply Spare Fuse in Fuse Box mazzmn Suggestion Box 3 12-05-2004 09:14 PM
