Old 04-07-2012, 10:26 PM   #1
saturn_owner68
saturn_owner68 is on a distinguished road
2003 L-Series 2.2L Sedan
1996 SL1
Default Check engine light on P0128
The check engine light came on in my 96 saturn, and the code came up P0128 according to the book it says Thermostat rationality error detected. However the car is not overheating. Any ideas on what could cause this code to come up?
Add to saturn_owner68's Reputation
Rate the quality of this post and help saturn_owner68 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturn_owner68 is offline   Reply With Quote
Old 04-07-2012, 10:33 PM   #2
OldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud of
Default Re: Check engine light on P0128
There is no P128 for a 96 Saturn. Try another code reader or go to a parts store and get it read.
Old 04-07-2012, 10:48 PM   #3
adventureoflink
adventureoflink's Avatar
that explains why when my thermostat last epic failed (it would sit between C and 1/4 on the highway on a cold winter's day ) the service engine soon light didn't illuminate...
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive & Well
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, prolly needs front driver strut
Add to adventureoflink's Reputation
Rate the quality of this post and help adventureoflink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-08-2012, 06:42 PM   #4
saturn_owner68
1996 SL1
I did take the car to the autoparts store, but they got P0128 to,but they said the computer is giving a false code, is this possible? I also got 2 new codes P0301 and P0303 that would mean misfire is detected, but the car is not misfireing, could replacing the pcm be in the future? BTW as far as the thermostat, the temperature gauge in the car goes to the 1/2 way mark.
Old 04-08-2012, 07:01 PM   #5
brags
brags will become famous soon enoughbrags will become famous soon enough
1996 SL1
hows your coolant level? is it full? and as far as the codes go wether there
lagit or not. i would reset the computer not with the scanner but taking off
both battery cables right off the battery and touching them together wrap
a small clamp around them to keep them tight and touching together for
1 hour doing it this way will drain down all voltage from the capaciters and
reset your computer totally. try that and post back
" Any man that doesen"t share his knowledge in cars is wrong to do !"
Add to brags's Reputation
Rate the quality of this post and help brags reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brags is offline   Reply With Quote
Old 04-08-2012, 07:37 PM   #6
Do not pull battery cables. Just pull the power to the PCM fuse, PCM B in the fuse box, location diagram is in the lid.
You may have misfire codes and never feel the misfire so do not assume that they are bogus.
What brand and type of spark plugs are you using? Cylinder 1 and 3 fire on the same polarity and this sounds like an ignition issue.
The PCM does not generate false codes, it is a scanner software issue.
Does the temp gauge increase to 1/2 as the engine warms up or go immediately to 1/2?
Old 04-08-2012, 08:02 PM   #7
brags
1996 SL1
he could have a computer glitch just like home computers get glitches
and when You reset it by turning it off and back on again it clears itself. and oldnuc whats wrong with taking the battery cables off and touching them together for an hour to reset it that way? just to see if it will clear the engine light after all its a fresh start for the PCM.
Old 04-08-2012, 08:08 PM   #8
saturn_owner68
1996 SL1
As far as spark plugs I've got bosch platnum spark plugs I put those in at 200,000 miles so the spark plugs have 26,000 miles on them. As well as the spark plug wires. As far as the temperature gauge it goes to 1/2 slowly as the engine warms up.
Old 04-08-2012, 08:17 PM   #9
Change the plugs and wires to NGK BKR5ESA-11 plugs and that will fix the misfire.
Find the vacuum leak. Whoever is reading the codes is using defective software... I would bet the correct code is a P507.
Old 04-08-2012, 08:50 PM   #10
saturn_owner68
1996 SL1
Thanks for the help, who would of thought napa autoparts would be wrong. I see you can get the spark plugs you mentioned from Amazon, so I will try those. As far as a vacuum leak I will look for that.
Old 04-08-2012, 09:26 PM   #11
Plugs and wires will get rid of the 301 & 303 and finding and fixing the vacuum leak will get rid of the high idle and probably the other incorrectly read code. Pull the PCM B fuse after the plugs and wires are changed and see what comes back. Be sure to clean off the aluminum coil tower terminals as well. Use something like a damp kitchen combination scotch-brite and sponge.
Old 04-09-2012, 02:59 PM   #12
adventureoflink
Advance Auto also carries NGK spark plugs... see if you can go to one without having to wait nearly a week with shipping and such..
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 04-11-2012, 01:17 AM   #13
saturn_owner68
1996 SL1
I took the car to autozone and had them read the codes, their machine gave a P0404 code and P0350 code, so I replaced the EGR valve and coil pack so far the check engine light went out and has not come back on. Even though the check engine light is out, it probably would be a good idea to change the bosch spark plugs to NGK ones.
Old 04-11-2012, 06:18 AM   #14
I would suggest that action as the Bosch plugs are probably responsible for the ignition system failure. Aftermarket ignition parts are not real reliable and used JY parts have better life so if you have coil-ICM problems in the future use JY parts.
There is no P350 either so I take that as either a typo or more bad scanner data.
Steady Check Engine Light (Low Engine Power?) labelcd6 Vue General 1 06-25-2012 10:16 AM
What is Saturn's equivalent of "Check engine light"? Smog won't pass bulb check. harmono S-Series General 5 02-28-2012 09:17 AM
check engine light and coolant level light stuck on saturn/chev S-Series General 13 11-22-2011 07:20 PM
check engine light and antitheft light 2004 L300 jonus311 L-Series Tech 2 01-31-2009 07:55 AM
Check Engine Light W/ Reduced Power light saturnfreak01 L-Series Tech 5 01-24-2004 10:04 PM
