#1 | ||||
![]() Join Date: Jul 2011
1996 SL2
I am rebuilding my 2002 SL2, 1.9L DOHC and have a dilema. I purchased a Fel-Pro head gasket set and it has 8 o-rings in it. The problem is that I have no idea where they go. Any help??? I have looked at the manuals and not found any help.
#2 | ||||
![]() ![]() ![]() Join Date: Jul 2005
Are they all the same size? Post a pic if you can.
#3 | ||||
1996 SL2
They are all the same size. I will try to get a pic and post later.
#4 | ||||
![]() Join Date: Feb 2012
2002
thats odd i just did my head gasket and i had the same brand as you but i didnt have any 0 rings?
#5 | ||||
I got O rings as well with the set I bought. Didn't use them but I was thinking they were for a couple bolts on the timing chain cover. Or maybe the water pump, they were in the same bag as the WP gasket.
... My collection of S-Series info: "https://drive.google.com/folderview?id=0B5D8XfJgavxrdE5mcHBlMG5rbUU&usp=sharing" (copy & paste between quotes)
#6 | ||||
1996 SL2
One of the guys at work thought maybe two for each of four fuel injectors? What do you think?
#7 | ||||
Why would they put injector o-rings, which you'd have no reason to touch, in with a head gasket? They may as well put a new set of lug nuts in the kit; they're about the same relevance.
#8 | ||||
![]() Join Date: Jan 2011
2001 SC1
I got the Fel-Pro head gasket kit (~$90) for the SOHC engine, my car is 2001 SC1
i have the same o rings, all same size, 4 of the 8 match the ones where the injectors go in the fuel rail, but the ones that go where the injector goes into intake manifold are little thinner; seem to be same OD but i don't think will even fit... I think I had the same issue with the fel-pro head gasket kit when I had to partially rebuild my sister's '99 VW Golf with a similar-ish engine. rather than make a fuss, I went to the parts store (auto-zone) and just got the injector o-rings alone, and they were right. This time for my Saturn they didn't sell them alone... either have look again tomorrow, or to use old ones.... ... 2001 Silver SC1, from craigslist in Clifton, NJ 2011/01/21, with 70k miles, $3K, 27 normal (winter 25 mpg) / 37-40 highway (just have to watch oil a bit... seems to be 3/4 qt in 1000 miles, )
| Thread Tools | |
| Display Modes | |
| 1999b (air) dohc to a 2002 dohc swap question | Bamm | S-Series Tech | 4 | 08-20-2011 10:03 PM |
| 2002 DOHC into a 98 SW2 w/DOHC anything to watch out for? | BIGGUNDOCTOR | S-Series Tech | 3 | 05-15-2011 04:08 PM |
| 2002 SC2 DOHC Engine | ridnmo | S-Series Tech | 5 | 12-28-2010 10:53 AM |
| gaskets, where they go 97 sc2 dohc | jayblock | S-Series Tech | 8 | 01-23-2009 09:19 PM |
| 94 DOHC block, engine parts, gaskets.... | JPDucketts | Old Classifieds | 3 | 11-30-2005 03:47 PM |
