#1 | ||||
![]() Join Date: Mar 2011
I really need your help guys on this one. I have a 1995 Saturn SL1 4 door 5-speed sedan with 130k miles. The car has been well maintained over the years. Yesterday I noticed hearing the engine missing so the first thought was I had dropped a cylinder or had a burnt valve. I did a compression test on all 4 cylinders and to my surprise I got 150 psi on all four cylinders. I then tested the coils, ignition module, spark plugs, and spark plug wires. I even tested the fuel injector electric plugs with my multimeter on all four plugs to make sure I was getting voltage to all lines and it was getting 10.4 volts on each. All those other things checked out fine. I then said it have to be a bad fuel injector for cylinder #3 so I went out and purchased a new fuel injector and installed it. Still, the car is missing on cylinder #3. The bottom line on this is the engine starts right up but for some reason injector #3 is not spraying fuel into the cylinder. There are no check engine light but cylinder 3 is not getting fuel. Its getting great spark but no fuel. Does anyone know why the injector is not spraying fuel into cylinder 3? Is there any other componet that needs to be replaced that tells the fuel injector to spray?
P.S. There is a green plug-in at the end of the fuel injector harness lines that plugs into a little square box on the opposite end of the throttle body. Im not sure what that little box is for but it is connected to the fuel injector harness wires. Could that cause this problem?? I really need your help on this guys because I have done everything that I know to do to get fuel to that cylinder with no luck.
#2 | ||||
1-Fuel injectors should have 12v on either wire to each injector. The pcm switches ground to pulse each injector on/off.
2-Is this green plug connected to the throttle position sensor or not? The tps is opposite the throttle lever/cable and should have an electrical connection to the harness. No connection means the pcm has no idea of throttle position. 3-What's the fuel pressure? Measure it with a fuel pressure gauge as guessing is not an option at this point in troubleshooting. Maybe Autozone has one for loan? ... *The CPS is the heart of the entire EFI system. No cps = dead EFI system* *There's more to a/c than just a few cans of refrigerant* *There's more to brakes than just replacing parts*
#3 | |||||
#4 | ||||
What componet controls and tells the fuel injectors to work? Im think that may be my problem??
#5 | ||||
The PCM fires the injectors by grounding them, as said above. If the engine is running, the odds of a PCM failure are millions to one. Most likely it's the switched ground wire between that injector and the PCM.
Did you have the throttle wide open when you did that compression test? All plugs out? Fairly warm engine? Fully charged battery? If so, the compression is below the service limit of 180 psi.
#6 | |||||
#7 | ||||
![]() Join Date: Mar 2010
Could you perhaps have a bad intake or exhaust lifter? I'm not sure how this would affect compression. I'm guessing that it might lower it, as it would restrict the intake of air. If the exhaust were failed, this wouldn't restrict the intake of air, so it wouldn't likely affect compression numbers, but it would prevent the expulsion of exhaust gasses, and would probably destroy combustion during actual operation.
What makes you think that the #3 cylinder is misfiring? Does the plug look different than the rest. Is there no change when the plug or injector for #3 is disconnected? 150psi is low, but the engine should run. Are you sure that you have the plugs connected properly? Should be 4,1,2,3.
#8 | |||||
#9 | |||||
#10 | ||||
I un pluged all of the injectors except for cylinder number 3 and tested it individually since it was the only cylinder not working. I could see a mist of fuel spraying from the injector. But as I stated for some reason when I plug everything up cylinder number 3 does not get fuel.
#11 | ||||
One more time. Turn the key to ON or START? What did the other injectors do when the ignition switch was turned ON? START?
If I recall correctly, injectors do not spray until the engine is turned over. Simply turning ON the ignition should not have any injector spraying at all. If you insist on dwelling on just injector #3 without testing or assessing how the other three injectors work will tend to give you tunnel vision. ... *The CPS is the heart of the entire EFI system. No cps = dead EFI system* *There's more to a/c than just a few cans of refrigerant* *There's more to brakes than just replacing parts*
#12 | |||||
#13 | ||||
Observe all injectors and compare.
Might also be a good idea to remove the valve cover and observe the valves while turning the engine over slowly, either with the crank motor or with a socket (do not leave socket on engine while cranking electrically). Make sure that exhaust valves open and close.
#14 | ||||
Also try moving spark plugs around, or try a new set of wires. Perhaps one of the plugs is shorting out under high tension (perhaps there is a fine crack that you can't see, etc.).
Try swapping ignition coils. Maybe one of the coil terminals is shorting or arcing to ground.
| Thread Tools | |
| Display Modes | |
| Torque peak, cylinder presure, and fuel economy??? | redcannon | S-Series General | 1 | 07-27-2008 07:34 PM |
| Saturn Aura Expands Range With Fuel-Efficient Four Cylinder Model | BobbyP | Aura General | 24 | 09-22-2007 10:50 AM |
| the real scoop: fuel economy 2.2 4 cylinder versus 3.5 6 cylinder | bxd20 | Vue General | 89 | 06-04-2007 08:25 PM |
| Fuel Tank Capacity of ION Sedan? | LeftyBob | Ion General | 23 | 04-06-2005 10:39 AM |
| Loaded ION 3 Sedan vs. Base L300 sedan | Caprice | General Saturn Discussion | 32 | 02-26-2004 01:29 PM |
