Old 04-09-2012, 09:23 PM   #1
Oilonly
Oilonly is on a distinguished road
Default grind on front right wheel - bearing?
My 2000 SL2, 76,000 miles, was suffering thumping symptoms of a warped rotor and was also grinding while slowing to a stop with the brakes applied - both a mild noise and a thrumming feeling through the steering wheel.
Today I replaced rotors, pads, and pins, rotors were cleaned with brake cleaner before installation, lubed everything appropriately with caliper grease during reassembly, and the warped rotor symptoms are gone (and the braking is much better).
The car is still thrumming through the steering wheel as it finishes braking to a stop, speeds about <10 mph with the brakes lightly applied. No difference whether turning or going straight; no grinding or vibrations when turning without brake pressure applied, no grinding or vibration when coasting to a stop.
Could this be a wheel bearing issue, or are there other suggestions?
Add to Oilonly's Reputation
Rate the quality of this post and help Oilonly reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Oilonly is offline   Reply With Quote
Old 04-09-2012, 09:40 PM   #2
bluesl2
bluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of light
bluesl2's Avatar
Default Re: grind on front right wheel - bearing?
Most likely that is the abs system activating. Check the reluctor wheels on the outer cv joints and make sure they are not cracked,usually this does not cause the abs light to activate.
Add to bluesl2's Reputation
Rate the quality of this post and help bluesl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bad front wheel bearing? dbaier S-Series Tech 13 05-06-2010 03:13 AM
Front wheel bearing help Kegabeer S-Series General 6 04-02-2010 11:07 PM
Front wheel Bearing mgordon1100 S-Series Tech 53 01-06-2010 10:47 PM
Front Wheel Bearing: DIY or not? BryanF Vue General 2 04-10-2009 05:26 PM
Front Wheel Bearing mike Miscellaneous Tech 18 10-24-2004 11:42 PM
