#1 | ||||
![]() Join Date: Mar 2012
I tried to look up this before i posted, sorry if I missed it...
Anyway, I was driving down the Highway today and all of the sudden I lost all but the smallest amount of power while, at the same time, my check engine light and another light that looks like the check engine light with a down arrow came on. Car info: 2004 Redline 102xxx I assumed because the loss of power was so large that me car had stalled, but it hadn't. All the power functions (steering, brakes, stereo) where working fine. I thought it was my clutch at first, I'm about due, but it wasn't. the car was sputtering very badly and would hardly respond to acceleration in addition to jerking around (sudden loss and gain of the little power it was putting out). It never actually died, but the tach was not steady. I have not had the car but for a few months so I'm a little anxious to find the problem
#2 | ||||
The loss of power you experienced was the computer putting the car into "low power mode" because it detected a problem. That in itself is not a big deal, although it sure is scary the first time it happens, isn't it?
It could just be a sensor or something else relatively minor, but you should get the error code(s) read. Advance Auto Parts I know will read the codes for free.
#3 | ||||
![]() Join Date: Apr 2012
2006 ION Red Line
I'm not sure if you have fixed it yet. But I just purchased a 2006 Redline and it did the same thing when I driving. It took my mechanic two weeks too figure out that it was the Cam/Crank sensor. After that fix it has been running great since. I would have them check that out. The mechanic will have to put a tester directly on the sensors to test them right. But the sensor was only like 40 bucks and labor for 2 hours. So not a terribly pricey fix. Hope that helps!
#4 | ||||
You'll find you also need to clean the throttle body at least every couple of years (depending on how much you drive), or you will experience the same thing.
#5 | ||||
You did something to make it think something was wrong or something is wrong
... 2007 Saturn Ion 2 2003 Chevrolet venture lt trifecta dealer for the U.P. and WI. There is no two door ion. Proudly driving one of the last saturns produced before gm killed the brand.
| Thread Tools | |
| Display Modes | |
| Check Engine Light/Trouble Starting | theCTgrower | Astra Tech | 9 | 07-23-2011 01:25 PM |
| 2003 4cyl Rough Idle, power loss, check engine light flashing | mariopalumbo | Vue General | 4 | 08-29-2010 10:19 PM |
| Big trouble:Check engine light | louis5 | Ion General | 11 | 08-05-2009 08:35 AM |
| Transmission trouble and check engine light | Mannya | S-Series General | 1 | 01-15-2005 12:17 AM |
| Check Engine Light - Invalid Trouble Code | AxeMan | S-Series Tech | 24 | 10-17-2002 06:29 AM |
