Old 04-07-2012, 11:32 AM   #1
ShawnV
ShawnV has a spectacular aura aboutShawnV has a spectacular aura aboutShawnV has a spectacular aura about
ShawnV's Avatar
1996 SW2
2000 SW2
Default 96 SOHC ETCS - no connector?
I picked up a 96 SW1 from Cottmann transmission yesterday. They had taken the tranny out and completely disassembled it to "diagnose the problem." Anyway, I bought the car by paying off the $400 for the "work they had done" and paying the PO a couple hundred. I got the car home and installed a tranny, but there are two ETCSs and only one connector. What gives? Is this normal?
shawn
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Old 04-07-2012, 11:42 AM   #2
fetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nice
1996 SC2
1997 SW2
Default Re: 96 SOHC ETCS - no connector?
Sounds perfectly normal when they have put a '93-'95 motor in a '96-'02.
Either take both out to check which is the 2 wire or assume it's the bottom one like it's supposed to be.
My collection of S-Series info: "https://drive.google.com/folderview?id=0B5D8XfJgavxrdE5mcHBlMG5rbUU&usp=sharing" (copy & paste between quotes)
Old 04-07-2012, 12:13 PM   #3
OldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud of
The sensor in the correct one is isolated from ground so an ohmmeter will detect the correct sensor and the ECTS connector is not supposed to fit on the gauge sensor. The correct position is the lower hole.
Old 04-07-2012, 01:25 PM   #4
ShawnV
ShawnV's Avatar
1996 SW2
2000 SW2
Interesting. So I have a gen 1 SOHC? Is this good, bad, or neutral? The tranny I installed was a 2001 and the wagon drives real nice.
Old 04-07-2012, 01:40 PM   #5
adventureoflink
adventureoflink's Avatar
actually, more like gen-2 SOHC, unless they fabricated the PCM and injector wiring, as well as the fuel system. Remember, the first gen SOHC only had 85 HP and used TBI. Everything after that was 100 HP and MPFI.
Amazing that a third gen transaxle was used, unless you have a manual... (SOHC trannies, regardless of auto or manual, had three generations; only thing that changed between gen 1 and 2 was a bigger first gear. DOHC trannies had two generations. http://www.differentracing.com/tech_...gearratio.html)
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive & Well
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, prolly needs front driver strut
Add to adventureoflink's Reputation
Rate the quality of this post and help adventureoflink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
adventureoflink is online now   Reply With Quote
Old 04-07-2012, 02:56 PM   #6
ShawnV
ShawnV's Avatar
1996 SW2
2000 SW2
Yea, I used a 2001 Auto in it and it drives very well.
shawn
Old 04-07-2012, 03:31 PM   #7
It will function just fine, as you found out. What did you do about the right hand axle seal to the intermediate shaft?
Old 04-07-2012, 03:32 PM   #8
96 is Gen-2... first year.
Old 04-07-2012, 03:46 PM   #9
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
Depends on what part you're talking about. He's referring to the engine, indicating that '91-'94 would be the first design of SOHC, '95+ the MPFI second design.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Rate the quality of this post and help PurdueGuy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-07-2012, 05:19 PM   #10
It is the PCM, not engine that determines what trans is going to function correctly.
Old 04-07-2012, 05:20 PM   #11
The head is Gen-1 but you will have to locate the block number to see what the block is as it may only be a head transplant.
Old 04-08-2012, 01:10 AM   #12
madpogue
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
1996 SW2
Must be a '95 head. TBI SOHC head won't work with an MPFI intake. To your "good thing / bad thing" question, if the original engine didn't run and this one does, it's a "good thing".
Add to madpogue's Reputation
Old 04-08-2012, 08:30 AM   #13
ShawnV
ShawnV's Avatar
1996 SW2
2000 SW2
I had the car at my GF's house and I just got it back to take some pics:
She's deciding if she wants to drive it instead of the gold 98 sc she's been driving.
It's pretty clean and in good shape. It had a baseplate on it and still has the wiring from being TOAD'd. I'm not a huge fan of the green though. I have a 2000 SW2 also that I just transplanted an engine into, but it's green as well
Old 04-08-2012, 11:47 AM   #14
madpogue
1996 SW2
Yuh, gotta be a '95 head. You could look at the engine number; engine and tranny numbers are right next to one another, along the engine/tranny seam up front by the igntion module. Last six digits should match those of the VIN. That'll tell you if it's an engine transplant or a head transplant. And it looks like either they plugged the ECTS connector into the wrong sensor, or they put an actual ECTS into that gauge sender hole in the head. What does the temp gauge do?
Isn't green an appropriate color for a TOAD?
Old 04-09-2012, 11:54 AM   #15
alordofchaos is a jewel in the roughalordofchaos is a jewel in the roughalordofchaos is a jewel in the rough
1997 SC2
Need MOAR saturns in driveway!
What's up with the sticker on the airbox? Never seen one of those before.
...Wait, what, I actually won that eBay auction?
Guess I now (12/2008) own a 1998 SL2, silver 5 spd :p
And now (7/2010), a Craigslist 1997 SC2 5 spd
Old 05-01-2012, 09:49 PM   #16
ShawnV
ShawnV's Avatar
1996 SW2
2000 SW2
So she decided she liked this 96 SW1 better than the 97 SC2 she's been driving. My question is should I be looking at 1995 SW1 parts for it? I wanted to do plugs and wires but I'm not sure WTF it is...
The car's got Cruise but manual locks. I'm wondering about adding power locks. Does anyone know if it's already wired up and I can just install the locks and new PCM?
shawn
Old 05-01-2012, 10:18 PM   #17
madpogue
1996 SW2
Power locks don't work through the PCM. You'd need an RKE module. IIRC, Low Saturn recommends wiring an aftermarket power lock system, but using the factory door switches and actuators.
As for the engine, since it's running in a '96 car, it's most likely running the original '96 fuel system, ignition, PCM, etc., so parts replacement would be '96.
Old 05-01-2012, 11:42 PM   #18
cityhawk
cityhawk will become famous soon enough
cityhawk's Avatar
1993 SW2
2001 L-Series 3.0L Wagon
Not just Saturns, but more Saturn wagons!
Saturns:
1993 SW2 MT
2001 LW300
Gone but not forgotten: 1999 SW2 MT
Project cars:
1966 Corvair Monza convertible
1928 Ford Model A Tudor Sedan
Add to cityhawk's Reputation
Rate the quality of this post and help cityhawk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cityhawk is offline   Reply With Quote
When ETCS goes bad... Fingolfin S-Series Tech 8 08-26-2011 03:17 PM
Etcs MM96 S-Series Tech 9 11-06-2007 12:11 AM
temporary ETCS fix, 95 SL1 Al Scott S-Series Tech 1 05-09-2007 07:07 PM
ETCS bad after 5 months? shecky S-Series General 11 10-31-2006 05:15 PM
Etcs maliblu S-Series General 3 11-04-2005 07:30 PM
