Old 04-05-2012, 02:00 PM   #1
legaspi89
legaspi89 is on a distinguished road
2003 L-Series 2.2L Sedan
Default Feeling a light amout of heat inside?
When I was driving my car the other day. I feel like if the heater was lightly on and I didn't have the heating or cooling system on at all that day. My brother who was in the passenger seat said he felt the heat coming from the upper part of the floor. What can the problem be?
Add to legaspi89's Reputation
Rate the quality of this post and help legaspi89 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
legaspi89 is offline   Reply With Quote
Old 04-05-2012, 02:13 PM   #2
Default Re: Feeling a light amout of heat inside?
Well, for one thing, engine heat always radiates back through the firewall and the heater core can never be shut off as a shut off valve doesn't exist so hot coolant is always circulating through. The key to keeping heat from entering is using the temperature selector dial/knob to adjust a temperature blend door; this door selects how the HVAC box flows outside air through the a/c evaporator coils, the heater core or both. Usually its not bothersome for most but selecting the coldest temperature closes off air flow through the heater so incoming air isn't warmed as it flows through the heater core. All outside air will flow through the condenser coil whether the a/c is on or not.
Old 04-07-2012, 10:31 PM   #3
legaspi89
You always pull through fdryer. I'll definitely trying adjusting the heater to colder temperature. Doesn't it bother me that much. But I just like to have a good maintaining car. lol
Thanks again.
Old 04-08-2012, 07:18 PM   #4
born again
born again is on a distinguished road
2000 L-Series 2.2L Wagon
The cable is actually adjustable where it connects to the temperature control flap. If you still get heat at the minimum setting you may need to adjust the cable to completely close the flap. You should feel a bit of resistance in the knob as the flap closes.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
No Heat! Fix inside... kickarse L-Series Tech 3 08-09-2011 03:25 PM
temperature light and little box with what looks like water inside with an arrow onto edmonpierre S-Series Tech 11 07-14-2011 11:06 PM
98 SL1 burning massive amout of oil asstchief72653 S-Series Tech 13 03-22-2007 10:28 PM
98 SL1 burning massive amout of oil asstchief72653 L-Series Tech 1 03-20-2007 09:12 AM
Dust on inside of sealed light housing? Sky Pilot L-Series General 9 03-17-2006 12:08 PM
