#1 | ||||
![]() Join Date: Apr 2012
I am having issues with my 05 2.2 AWD. It has roughly 87,000 on it and is starting to have issues. Recently I have noticed a power loss in the car and it idles somewhere near 600 rpms. I understand that this can usually be a result of a bad throttle sensor but not likely in the case of the Vue. I did some disconnecting of the black vacuum hose that runs from the front of the engine passenger side to the driver side and down towards the gas tank. I disconnected the hose for an unknown unit and found that there was no suction coming from intake side of the unit when the car is idling. Once i remove the hose from the exhaust side of this unit the car seems to idle around 800 rpms. Could this part be the issue? If so, what is this part called and where can I get a fresh one?
See attached image for reference. Thank You, Othermark Last edited by Othermark; 04-07-2012 at 12:32 AM.. Reason: accuracy in information
#2 | ||||
I'm not very familiar with the VTi transmissions, but I'm hoping this isn't some sign of failure lurking in the near future.
Stalling when fan is on... is the AC on, or heat, defrost or bilevel? Those will trigger the AC compressor to turn on. If the strain on the engine is only happening when the AC compressor is kicking in, I would suspect the compressor is your problem. Let's hope so, as replacing that would be cheap compared to fixing the VTi (CVT variable) transmission. ... Avid Apple, car and vacuum enthusiast. Don't hate! ;) Current: '04 FWD 3.5L Previous: '05 AWD Red Line '02 L200 http://www.facebook.com/SaturnFansNorthEast
#3 | |||||
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2008
2005 VUE 3.5L
2007 VUE 3.5L
I'm not familiar with the 2.2 engine but could guess the hose you mention is the purge hose for the EVAP system. Fuel tank fumes are retained in a carbon filled canister and are frequently "sucked" into engine for burning. AFAIK - it isn't normal to note vacuum on the disconnected hose. Its also normal for the purge valve to cycle periodically, so a properly operating valve wouldn't have constant vacuum. I believe yours is the first post I've read from a member with a 2005 2.2 with AWD. I'd heard a few were made but your post confirms it for me. ... Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
#4 | ||||
Thank you for your input.
I have taken a rag to the throttle plate and gave it a good rub down but no change. In regards to the cabin fan causing the car to stall, It happens regardless of AC being on. If the fan is turned on the car will stall. The shop i took the car to suggested that the alternator is going out and the idle is due to a bad throttle sensor. I will take that the alternator is having issues but i am skeptical about the throttle sensor. Thanks again for the input. Last edited by Othermark; 04-07-2012 at 03:56 PM.. Reason: Information accuracy
#5 | ||||
Idle Air Control Valve? Either dirty or bad.
I assume it doesn't stall if you apply throttle, correct? ... 2012 Ford Escape V6 Limited AWD 2004 VUE 2.2L 5 speed 1997 Ford Explorer XLT 4x4
#6 | |||||
2005 VUE 3.5L
2007 VUE 3.5L
Regarding stall when cabin fan is on - I missed that first time by. Does the engine stall regardless of fan speed selected? Will the fan operate in all speeds if you maintain RPM with accelerator? Have you noticed any check engine and/or reduced power lights? The throttle actuator control (TAC) system uses the ECM to maintain idle RPM regardless of load. Its true the TAC will act strange if the electrical system is having problems. Do you have a voltmeter? A test across battery terminals with engine off should indicate around 12.5 volts if the battery is fully charged. It could go higher 13.5 - 14.5 with engine running around 1,000 RPM. If battery is original - its well beyond expected useful life - the alternator should last several more thousands of miles. ... Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
#7 | ||||
"Idle Air Control Valve? Either dirty or bad.
I assume it doesn't stall if you apply throttle, correct?" This is correct. The car only stalls when idling and it will stall regardless of fan speed. I see a significant dip in idle speed the more power I draw from the engine (wipers, radio, mirrors, windows) but the fan throws it over the edge. Regarding the Idle Air Control Valve, is that what I have circled in the image on the original post? could you point it out on the 05 2.2 ? Regarding a volt meter, I do not have one at the moment, I am looking to invest in one that would cover all the bases from testing the battery to testing fuses and other electronic devices on a car. Would you have a recommendation for one? Thanks again for the good input, Othermark
#8 | |||||
2005 VUE 3.5L
2007 VUE 3.5L
I mentioned using a voltmeter ... they're commonly available (with instructions) at almost all retail merchants. I've posted a link to one (of many) offered by Walmart: http://www.walmart.com/ip/Performanc...ndingMethod=rr ... Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
#9 | ||||
The Idle Air Control valve might be a relic of "old school" throttles that are controlled by a cable connected to the gas pedal. VUEs are smarter and use electronics and electrical wires to convert your foot position to throttle position.
Follow F2Gs advice above about the multi-meter. ... 2012 Ford Escape V6 Limited AWD 2004 VUE 2.2L 5 speed 1997 Ford Explorer XLT 4x4
#10 | ||||
Yes, after my reply I had googled what this air control vale was in relation to the vue, ironically it took me back to your thread.
I removed the air box and noticed how unusual the throttle looked( Solenoid assembly attached to the butterfly and wired back to the computer). doing a little more research I did not come across any information suggesting these devices fail very often and when they do it can get expensive quick. Back on the topic of the cars current condition, as I make trips in its current condition I notice the battery light come on and off. I am starting to wonder if the issues with the idle are directly related to the alternator or perhaps the voltage regulator, as I know the alternator it self should not go out at 86K. I will invest in a multimeter soon and give feed back on what I come up with. As always thanks, Othermark
#11 | ||||
Like f2f asked: how old is the battery? Car batteries should be replaced every 6 years or so. If you wait until the battery goes bad, they can sometimes add increased strain on the alternator, which causes the alternator to fail prematurely.
If the battery is old, I'd get it tested ASAP. I'd also get a voltmeter between the battery terminals with the engine running and see if the alternator is supplying enough voltage. ... 2012 Ford Escape V6 Limited AWD 2004 VUE 2.2L 5 speed 1997 Ford Explorer XLT 4x4
#12 | ||||
2005 VUE 3.5L
2007 VUE 3.5L
Tom ... I'm frequently reminded of the familiar adage - "you can lead horses to water but can't make them drink".
On the other hand - I understand why some folks are reluctant to check voltage ... until they realize its almost as simple as taking a child's temperature - orally, of course. ... Not a professional mechanic - advice and data are free - PM email address if I'm not logged on. Last edited by far2grumpy; 04-11-2012 at 09:32 AM..
| Thread Tools | |
| Display Modes | |
| 94 sc1 cabin vibration at startup and at idle | gman41 | S-Series Tech | 5 | 11-14-2011 10:16 PM |
| SC2 shakes and stalls at idle | ALANSD | S-Series Tech | 8 | 07-27-2009 12:13 PM |
| Stalls when idle or come to stop... | Aztek_SC2 | S-Series General | 6 | 12-10-2007 06:48 PM |
| stalls low idle | chleo05 | S-Series Tech | 6 | 07-07-2006 11:08 AM |
| help? stalls out, cold idle | bob o | S-Series Tech | 1 | 05-23-2004 02:20 PM |
