Old 04-07-2012, 01:29 PM   #1
katekev04
katekev04 is on a distinguished road
Default Saturn Vue 2004, burning oil
Hi everyone, back again!
I recently had the timing chain replaced on my 2004 vue, after it broke, which also damaged the engine head so that it also was redone. Then catalytic converter went, so in the month of jan/feb, I sunk about 3000 into my car.....then we were in an accident where we were rear ended.....
Anyway came back after collision repair, ticking engine.....no oil.....replaced 5 quarts after about 2000 miles......checked oil at around the 700 mile mark, and needs almost another 5 quarts....no oil in driveway, no blue smoke.....what gives?
Any answers?
Katie
Add to katekev04's Reputation
Rate the quality of this post and help katekev04 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
katekev04 is offline   Reply With Quote
Old 04-07-2012, 03:38 PM   #2
far2grumpy
far2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to all
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
Default Re: Saturn Vue 2004, burning oil
If it isn't leaking - and is not being mixed with coolant - it must be part of combustion mixture.
One way to check if the engine crankcase ventilation system is creating vacuum is to remove the oil dipstick and run engine at 1500 RPM. There should be a vacuum at dipstick hole (use a gauge of piece of paper).
I've also pasted service manual extract regarding oil consumption:
Oil Consumption Diagnosis
Excessive oil consumption, not due to leaks, is the use of 0.9 L (1 qt) or more of engine oil within 3 200 kilometers (2,000 miles). The causes of excessive oil consumption include the following conditions:
 External oil leaks Tighten bolts and/or replace gaskets and oil seals as necessary.
 Incorrect oil level or improper reading of oil level indicator With the vehicle on a level surface, allow adequate drain down time and check for the correct oil level.
 Improper oil viscosity Use recommended SAE viscosity for the prevailing temperatures.
 Continuous high speed driving and/or severe usage
 Crankcase ventilation system restrictions or malfunctioning components
 Valve guides and/or valve stem oil seals worn, or the seal omitted Ream guides and install oversize service valves and/or new valve stem oil seals.
 Piston rings broken, improperly installed, worn, or not seated properly Allow adequate time for rings to seat. Replace broken or worn rings as necessary.
 Piston improperly installed or mis-fitted
Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
2003 Saturn Ion 2 burning oil bethrw Ion General 8 12-27-2011 02:23 AM
97 Saturn Sl2 Burning Oil kickinazz S-Series Tech 22 11-17-2008 05:22 PM
How To Get Your Saturn To Stop Burning Oil!!!!!!!!!!!!!!!!!!!!!!!!!!!!! livingproofofit S-Series Tech 11 07-18-2008 09:51 AM
1994 Saturn Sc2 Burning oil. Racer93 S-Series Tech 15 04-04-2008 05:17 AM
oil burning saturn woonyboi02895 S-Series General 8 03-09-2008 10:21 PM
