Old 04-06-2012, 09:58 PM   #1
Leroy
Leroy is on a distinguished road
Default idle problem
I have a 1992 Saturn sc but has come up with a new problem. I cannot figure it out. Any advise would be appreciated. Here are the symptoms,
Idles fine until brakes are applied then idles down and dies
When you turn the right turn signal on, the left signal comes on also but does not blink, the right side stops blinking
When you press on the brake pedal, both turn signal indicator lights will faintly light up
Add to Leroy's Reputation
Rate the quality of this post and help Leroy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Leroy is offline   Reply With Quote
Old 04-06-2012, 11:31 PM   #2
Default Re: idle problem
Three areas to consider; wrong replacement bulbs in either the turn signals or brake lights, very old corroded/loose wiring in the main fuse box or console junction box, worn out alternator/loose belt tensioner.
Old 04-06-2012, 11:31 PM   #3
adventureoflink
adventureoflink's Avatar
Sounds like you may have a circuit unintentionally completing somewhere...
also, before you apply the brakes next time, I'd advise removing both brake light bulbs and try again.
Are any of your turn signal bulbs burned out?
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive & Well
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, prolly needs front driver strut
Add to adventureoflink's Reputation
Rate the quality of this post and help adventureoflink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-07-2012, 07:43 PM   #4
Leroy
I took the brake lights out and the car would not start. reinstalled and the car started, sound weird. Also discovered that the brake lights on the drivers side or dimmer than the right. all of the lights were good, considering replacing the turn signal flasher, just to see what happens, possibility it is shorting out.
Old 04-07-2012, 08:13 PM   #5
Is the turn signal flasher original or a replacement? Wrong replacement part?
You'll have to be more descriptive. "Car would not start" can mean no starter sounds or the engine turns over but doesn't fire up. Two different descriptions of "the car won't start"....................
Old 04-07-2012, 08:22 PM   #6
adventureoflink
Yeah, you've definitely got quite a few circuits crossed... the starting circuit has NOTHING to do with the brake lights...
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 04-08-2012, 08:55 PM   #7
Leroy
the car would not start, but will turn over. I replaced the turn signal flasher, that was not the problem. Also discovered that when I turned on the headlights, the left signal started blinking faster.
Old 04-08-2012, 09:34 PM   #8
With several problems possible, starting up may be a primary concern unless you're interested in fixing the turn signals first.............
Presuming you'd like the engine running first, checking two major items nay help - fuel and spark. See if fuel sprays out the fuel test valve with ignition ON and test for spark with coil wires removed and cranking the engine. These two tests are described many times in other threads.
Expect issues with a '92 that's 20yrs old; a worn out fuel pump and corroded/faulty ignition system. Throw in a worn out alternator if it hasn't been replaced.
Old 04-09-2012, 08:23 AM   #9
BV22
BV22 will become famous soon enough
2002 SC1
This sounds like another recent thread and at least one much older one. Saturns have a common ground pack for all the lights in the back of the car. The fuel pump also grounds here. When this ground pack corrodes, lights in the back of the car do weird things, and often the fuel pump cuts off when the brake lights are on. The recent poster had an SW, and the ground pack was in the well behind the left rear tire. On SC's and SL's it is under the package shelf between the rear seat and rear window. The ground pack is a black box about the size of a smart phone with a bunch of wires coming out of it.
Not certain if this applies to a '92, but worth a look as the symptoms are identical.
BV22
2002 SC1 5M
209k Mar 2013
Add to BV22's Reputation
Old 04-09-2012, 08:05 PM   #10
davidt321
davidt321 is on a distinguished road
1995 SL
Sounds like the current is searching for a ground.Check all your grounds for corrosian and of course check your battery under load.Any burnt electrical oddors?When you took out the brake light bulbs and car would not start I think that was some of the current finding a ground/enough to be the straw that broke the camels back.If it was all the current going thru the bulbs for starting to find a ground it would have burned the small wires and or the bulbs.Check the big wire grounds.What happens when you turn your head lights on?
Add to davidt321's Reputation
Rate the quality of this post and help davidt321 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
davidt321 is offline   Reply With Quote
idle problem walterjonesw Ion General 9 07-01-2011 04:06 PM
idle problem rudedog23 S-Series General 8 04-12-2010 10:36 PM
rough idle problem/idle problem sc2dohc94 S-Series Tech 8 08-10-2008 11:31 AM
94 sc2 idle problem dswade5696 S-Series Tech 11 10-11-2007 09:49 AM
Idle problem Damins S-Series Tech 3 09-13-2006 04:25 PM
