#1 | ||||
![]() Join Date: Aug 2011
1998 SL
Does anybody know of anything online i can buy? I know people will say go look in junk yard but is there anything ou there anyone knows of? I replaced the sensor but the cap is corroded and is giving bad reading sproatically
#2 | ||||
![]() Join Date: Mar 2012
If you have any old unused computers laying around you can open it up and look on the lower right side of the motherboard and you'll see the front header for the led's and power/reset switches. these connections are almost a perfect fit for the ECTS sensor connector. just make sure you solder and heat shrink the leads together to avoid future problems. I think richpin has a video on youtube detailing this too.
As far as an actual replacement, I'm not sure if you can get a new factory connector for it or not.
#3 | ||||
![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005
Apparently this is the Pt. No. > 12117087
But do you really want to pay $23.15? http://www.trademotion.com/splash/in...?siteid=214643
#4 | ||||
Wow that's a lot for a small two prong connector :O I think you'd be better off with my suggestion lol.
#5 | ||||
Or save the trip to the junkyard and PM Lowsaturn. He has a bunch of used units he has grabbed over the years.
I don't think I'd pay over $20 for one.
#6 | ||||
1998 SL
I did pm low saturn, he is fresh out, any link to the u tube vid? I searched around couldnt find anything, ya it might be worth 20-30$ cause the temp needle takes a dive every other day and trips check engine light and runs like crap until i pop hood and wiggle it
#7 | ||||
| Thread Tools | |
| Display Modes | |
| Coolant temp sensor connector? | sbguy06 | S-Series General | 8 | 08-09-2012 05:17 AM |
| Part number connector for coolant temperature sensor | smp7015 | S-Series Tech | 8 | 03-07-2009 10:41 PM |
| Temp Sensor Connector Part # | Dsell | S-Series Tech | 9 | 09-05-2008 06:44 PM |
| Help: coolant temp sensor connector | tataat | S-Series General | 2 | 07-21-2005 06:00 AM |
| Does anyone now if the sensor on the transaxle is the same as the coolant temp sensor | BigDaddyDrex1 | S-Series General | 4 | 05-27-2005 02:29 PM |
