Old 02-02-2012, 01:43 PM   #1
acemanrocks
acemanrocks is on a distinguished road
Dizzy Low MPG with 2008 3.6L XR AWD
I just purchased a used 2008 3.6L XR AWD Vue and was very disappointed to see that I am consistently getting only 15.5 mpg in this thing. Driving is 50/50 city to Highway. I have been careful to drive conservatively and the MPG stays the same.
What are other getting from your similar Vue?
Add to acemanrocks's Reputation
Rate the quality of this post and help acemanrocks reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
acemanrocks is offline   Reply With Quote
Old 02-02-2012, 02:01 PM   #2
far2grumpy
far2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to allfar2grumpy is a name known to all
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
Default Re: Low MPG with 2008 3.6L XR AWD
What kind of mileage were you expecting?
Normal - according to USG - indicates around 18 mpg combined city and highway.
Do you use ethanol mix fuel? If yes - that could reduce mileage by 1.5 to 2.0 mpg. Do you run engine for warmth at all? MPG is zero when setting still.
More info here: http://www.fueleconomy.gov/feg/bymake/Saturn2008.shtml
Not a professional mechanic - advice and data are free - PM email address if I'm not logged on.
Old 02-02-2012, 02:33 PM   #3
acemanrocks
I guess I was expecting fall between the 16 and 22 due to the style of driving. Obviously there is a shock from switching from and 28mpg Impala to the Vue. I just was hoping to hit the median. Wanted to see if others were getting better results and if there be reason to dig further into the poor results.
Old 02-02-2012, 04:24 PM   #4
onefunkar
onefunkar has a spectacular aura aboutonefunkar has a spectacular aura about
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
friend has an 08 xr vue awd. after i saw this i asked them what they get for mileage because i know they keep track. they said they get between 18 and 2o for 50/50 mix of driving. biggest problem is unusually small gas tank on the awd only so they have to fill up alot. think its only 16 gal.
Add to onefunkar's Reputation
Old 02-02-2012, 04:48 PM   #5
olds362
olds362 is on a distinguished road
Watch your tire pressure, I run my tires at about 35psi, not what the sticker recommends. Don't let it sit idling for extended periods. Use the cruise control whenever possible, and set it at about 60 or so if on the highway. I have a fwd XR and I am able to get anywhere from 23 to 28(summertime, highway only) driving very carefully and keeping it around 60 on the highway. Mileage drops quickly driving faster than 60.
Add to olds362's Reputation
Rate the quality of this post and help olds362 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
olds362 is offline   Reply With Quote
Old 02-02-2012, 06:26 PM   #6
col_dude190
col_dude190 will become famous soon enough
2006 VUE Red Line
2004 VUE Red Line
Not to be negative, but I've have read many reviews and owner comments about getting poor gas mileage on the 3.6 High Feature V6. This seems to be across the board for everything from the Outlook/Traverse/Acadia/Enclave crowd to Malibu/Aura and the '08+ Vue and Equinox Sport. The 3.6 V6 is a great engine with great power, but it seems like no matter how you drive it, it struggles to get those EPA estimates. Its just not a very efficient powerplant.
Add to col_dude190's Reputation
Rate the quality of this post and help col_dude190 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
col_dude190 is offline   Reply With Quote
Old 02-02-2012, 06:55 PM   #7
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
interesting about tire pressure. 2008 was the only year vue with 30 pounds recommended. 2009 and 2010 was 35 pounds. that will help mileage.
Old 02-02-2012, 07:43 PM   #8
simple2me
simple2me is on a distinguished road
Pull the motor out and put it in a CTS. That's what I done. I put an 08 VUE 3.6L into my 06 CTS and i'm getting about 22-26MPG's depending on how I'm driving and that all depends on the music I'm listening too. LOL!
Add to simple2me's Reputation
Rate the quality of this post and help simple2me reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
simple2me is offline   Reply With Quote
Old 02-02-2012, 09:33 PM   #9
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
I got about 17 mpg with the same model VUE driving around Baltimore. There wasn't much freeway use. Maybe 70/30 city/highway...
Make sure your tire pressures are around 35 psi, running them around 30 could cost you 1 mpg.
2006 Black VUE Red Line
Add to BobbyP's Reputation
Rate the quality of this post and help BobbyP reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-03-2012, 05:46 AM   #10
olds362
It all depends on your driving habits, my XR V6 has no problem achieving the EPA estimates and exceeding them. I believe the estimates on my FWD XR were something like 17 city/23 highway and I have no problem getting that kind of mileage. In warm weather with summer blend gasoline, highway only I have gotten as high as 27-28mpg. I try to take the expressway as much as possible and will generally set the cruise about 58-60mph. We have 70mph speed limits here in Michigan and I found out that mileage drops quickly above 60mph. I can see how the larger Acadia/Traverse would get lower mileage, it is larger and heavier with the same engine.
Old 02-04-2012, 12:15 AM   #11
John
John is on a distinguished road
John's Avatar
2008 VUE 3.6L
Arrow Re: Low MPG with 2008 3.6L XR AWD
Originally Posted by onefunkar View Post
. . . biggest problem is unusually small gas tank on the awd only so they have to fill up alot. think its only 16 gal . . .
Correct. According to the manual it's 16.7 gallons for the AWD and 19.2 for the the FWD.
I've always said the AWD fuel economy is the one major dislike with our VUE but those of us who have had one for a while I guess it's sort of just accepted (although that doesn't make it right ). It is a fairly heavy vehicle for it's size.
My wife is the daily driver and she is very good about driving "consistently" and gets 16MPG with 90%/10% city/highway.
If we drive the other way 5%/95% (like on I-70 to visit family) I'd say we get 23MPG or so.
Add to John's Reputation
Rate the quality of this post and help John reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
John is offline   Reply With Quote
Old 04-03-2012, 03:57 PM   #12
revues
revues is on a distinguished road
2008 VUE 3.6L
I just purchased this model 2 months ago and was really surprised at how often I have to fill it up! I drove a 2002 Ford Escape for 10 years and just thought the mileage would be in the "ball park". Not so! I am getting about 18-19 around town and hope to get more on a long haul. The Escape V6 was getting me 23-24 around town....lesson learned.
Add to revues's Reputation
Rate the quality of this post and help revues reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
revues is offline   Reply With Quote
Old 04-03-2012, 04:38 PM   #13
Sweepspear
Sweepspear is on a distinguished road
Sweepspear's Avatar
2008 VUE 3.6L
My Wife gets 18-19 combined with our '08 VUE XR. It's a 3.6 FWD model.
Dale
I’m no longer going to pursue my dreams. I’m just going to find out where they are going and hook up with them later.
Add to Sweepspear's Reputation
Rate the quality of this post and help Sweepspear reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sweepspear is offline   Reply With Quote
2008 Sky AlCherry Sky General 1 11-03-2011 10:48 AM
2008 VUE mpg LUISMOND 2008 Vue 16 09-18-2011 01:52 PM
A/C in 2008 Vue... WebToker 2008 Vue 12 06-26-2008 06:33 AM
2008 Vue Mpg kpauley 2008 Vue 6 09-04-2007 10:34 AM
2008 Mix davidsky 2008 Vue 9 08-15-2007 09:19 PM
