Old 04-02-2012, 12:24 AM   #1
davinj918
davinj918 is on a distinguished road
Default erratic idle with high rpm
just got finished taking out then replacing the transmission in my 99 sl2. when i got everything back together and started it the idle was very low then all of a sudden spikes to 4000 rpms or more. wats going on here?
Add to davinj918's Reputation
Rate the quality of this post and help davinj918 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
davinj918 is offline   Reply With Quote
Old 04-02-2012, 01:11 AM   #2
Default Re: erratic idle with high rpm
When dropping an engine or xmission, many parts are removed for access.
A sudden very high rpm idle might be the large vacuum hose falling off that feeds to the brake vacuum boost unit. Lots of old vacuum hoses will crack or dry out and disintegrate from simple handling. Check all vacuum lines.
Erratic Idle Tom64 S-Series Tech 2 12-02-2007 10:59 PM
Erratic Idle gone. (for now??) mr.mangosteen S-Series General 0 01-21-2007 11:32 PM
Erratic Idle taosd L-Series Tech 6 12-25-2006 07:03 PM
erratic idle wytygr S-Series Tech 1 12-29-2005 09:32 PM
Erratic Idle with 95 SL2 Dr. Bob S-Series Tech 1 03-02-2001 08:47 AM
