#1 | ||||
![]() Join Date: Nov 2010
I want to send out my dohc head out and get it machined down a little and raise compression.
when i took it off I see there are small indentations in the piston for 2 of the valves. can this head be machined a little to raise compression, or will ir cause the piston to hit the valves? if there is some clearance, how much? the shop can do 1/1000th, or 50/1000ths, or anywere in between, etc etc.
#2 | ||||
.020"-.040" I believe is what people usually do. The more you shave the head, the more shaving the timing cover the same amount becomes a good idea.
Verify the head and block haven't already been cut down. You don't want to find out the hard way the block's been cut down and cut down the head...pretty sure someone recently had that happen ... My collection of S-Series info: "https://drive.google.com/folderview?id=0B5D8XfJgavxrdE5mcHBlMG5rbUU&usp=sharing" (copy & paste between quotes)
#3 | ||||
does this apply to our dohc saturns? or are you saying a general rule?
I'm just nervous about this specific motor after having seen those 2 indentations in each piston. that seems to indicate that the valves go into those indentations when the piston is at the top. do I still have enough clearance between the piston top and the valves to grind off .020"-.040" on this specific engine?
#4 | ||||
Back when SDA sold performance DOHC head's they gave the option of .020", .030" and .040" decking/shaving. Much more then .040 and your getting close to the service limit of ~.060".
I believe the indentations are more of a "just in case" rather then every revolution thing. If you can think of it to ask(about modifying), somebody already has...a couple of times, on here: www.sixthsphere.com ... My collection of S-Series info: "https://drive.google.com/folderview?id=0B5D8XfJgavxrdE5mcHBlMG5rbUU&usp=sharing" (copy & paste between quotes)
#5 | |||||
that would apply to european vehicles like my fwd volvos and saab. they're a man made pain in the neck the saturns are so simple and straightforward in comparison never mind the parts are so much cheaper
#6 | ||||
I wonder if I could get away with machining the head like .015 or so and still use regular gas?
#7 | |||||
![]() Join Date: Dec 2011
1993 SL1
i guess it depends on how hot this mod makes the engine doesent it? ... 1998 saturn sc2, 175,000 miles. 1993 saturn SL1 sedan, at least 560,000 miles before a cracked cylender head blew. 1994 nissan 300zx t top, 90k miles. currently restoring.
#8 | |||||
With a mild shave like .015" you might be able to save money with regular fuel, but it would depend on a lot of factors (climate, driving style, fuel quality, etc, etc). With anything more significant than that, it's often more economical to use premium. If you want to maximize power, you need premium. Even with the stock compression ratio, premium fuel will sometimes get you a bit more power by allowing more aggressive timing (technically it doesn't increase power, just prevents you from loosing it due to knock retard). ... High compression build: .033" shaved/ported head, flat-faced valves; gen3 rods, pistons, tie-plate; OE header, custom CAI, SDA street cams with adjustable sprockets, WBO2, SAFCII, LSD. ASE A1-A8+L1
#9 | ||||
With a fresh rebuild and the dual intake cam mod premium costs less per mile than 87 and there is no contest with 89 even with the 5 cent Iowa discount, the 89 is a looser.
#10 | ||||
How about blending in some e85 to up the octane?
... 1993 SL2 AT - 97k - G-Oil diet running G-Oil/Mobil Super HM + Fram HM3600 :-) Adding TC-W3 to the gas with positive results (-: ......... Choose the red pill
#11 | ||||
The 89 fuel is E-10 and the BTU difference is sufficient to drop fuel mileage sufficiently to make it not cost effective to use.
| Thread Tools | |
| Display Modes | |
| sending head out for machining | fixityourselfer | S-Series Tech | 0 | 03-29-2012 07:47 AM |
| GM sending out letters | 2NDSOUT | General Saturn Discussion | 98 | 01-06-2010 12:41 PM |
| Where Is The Oil Sending Unit 93 Sl1 | johnholl | S-Series Tech | 1 | 10-09-2007 11:28 AM |
| Head gasket, head bolts and other head related foolishness… | Quagmire | S-Series Tech | 9 | 09-12-2007 09:08 PM |
| machining flywheel(and lightening) | mkosem | Mods and Performance | 6 | 09-29-2003 01:55 AM |
