Old 03-29-2012, 01:30 AM   #1
BassHypnotist
BassHypnotist is on a distinguished road
2000 SW2
Default Temp Gauge Was In The Red Today...Just Changed ECTS
Over the weekend I changed the spark plugs and the ECTS which had already been changed prior to me buying it, but I didn't know until I pulled it out and figured I might as well change it since it was cheap. Today while sitting for 5 - 10 minutes with the air conditioner on I realized the temp gauge was in the red. It is the first time I've sat for that long with the A/C on so I don't know if the issue was there prior to me changing the ECTS. I turned the A/C off and put the heat on and the temp came down in a couple minutes. The gauge is usually at the 3/8ths mark during normal driving, both before and after the ECTS change. The coolant level in the reservoir was just below the low mark which is obviously low but not crazy low so I don't think that was the issue. I am constantly refilling it which is another issue although possibly connected. It isn't leaking fluid but still goes through a quart of water/anti-freeze every week or so. It has about 94,000 miles on it of which I've only put on about 12k. Not sure if the thermostat was changed prior to me getting it.
Your thoughts? Thanks for your help.
Add to BassHypnotist's Reputation
Rate the quality of this post and help BassHypnotist reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BassHypnotist is offline   Reply With Quote
Old 03-29-2012, 03:30 AM   #2
fdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud of
Default Re: Temp Gauge Was In The Red Today...Just Changed ECTS
You may have more than one issue; possibly a worn out cooling fan, thermostat and either a radiator or water pump leak. Losing coolant either leaks out or is getting by a blown head gasket. The transmission cooler fittings are a likely point of worn radiators leaking coolant. The other is the water pump otherwise its loose hose clamps or old hoses cracking from bulging.
The cooling fan runs at one speed and should be running strong, not wimpy. A sign of a worn out fan is if it runs less than loud. If your a/c works then the fan should run at the same time. Check to be sure it runs and runs strong. A weak or worn out fan won't blow with sufficient force to cool off the hot condenser coil and radiator, letting the coolant over heat. Usually when the a/c runs the coolant temp drops since the fan is needed to blow through two sets of coils.
*The CPS is the heart of the entire EFI system. No cps = dead EFI system*
*There's more to a/c than just a few cans of refrigerant*
*There's more to brakes than just replacing parts*
Old 03-29-2012, 06:42 AM   #3
Signmaster
Signmaster is just really niceSignmaster is just really niceSignmaster is just really niceSignmaster is just really nice
First and easiest test is the fan. If movement above approx 10-15 mph brings the temp back down then the radiator is not too clogged and the thermostat is open. If you let the car get hot again and the cooling fan won't cool it down, it's likely gone. The fan should come on any time the AC is on.
Signmaster is online now   Reply With Quote
Old 03-29-2012, 08:42 AM   #4
madpogue
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
1996 SW2
It's leaking. Or it's boiling out, which is another form of leak. Make sure the mix is AT LEAST 50% anti-freeze, up to 60% is better. If you still lose coolant, replace the reservoir cap. Also consider a cold pressure test, to see if there's a marginal leak somewhere, esp. the left radiator tank.
Was the cooling fan running while you had the A/C on?
Add to madpogue's Reputation
Old 03-29-2012, 11:36 AM   #5
SC2Sick
SC2Sick is on a distinguished road
1997 SC2
Check your thermostat / water pump. I had mine leaking and couldn't figure out where it was leaking from for the longest time (the first time.. not the dozens of other times on other cars).
http://www.sc2sick.com
Add to SC2Sick's Reputation
Old 03-29-2012, 06:34 PM   #6
brags
brags will become famous soon enoughbrags will become famous soon enough
1996 SL1
keep an eye on the temp gauge saturns are not forgiving if overheated they
will damage the head gasket.. in no time.!
" Any man that doesen"t share his knowledge in cars is wrong to do !"
Add to brags's Reputation
Rate the quality of this post and help brags reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brags is offline   Reply With Quote
Old 03-29-2012, 10:28 PM   #7
BassHypnotist
2000 SW2
You guys called it right. Checked the fan when the A/C was on and it wasn't running. I replaced the radiator a few months ago because the top water line was leaking at the housing. While I could have messed something up, or left something unplugged, I don't think I did. I checked the fuses under the hood and they were good. The connector looks plugged in and clean but I will check it again tomorrow when the engine is cool. Is there somewhere or something else I should check before assuming the fan itself is dead?
As for the coolant disappearing, I have never found a leak or seen fluid under the car. Is it possible that it is leaking/evaporating in a way that doesn't leave a trace? I just assumed it was an issue with the head or something and it was getting sucked into the pistons.
RickyHarris.com
Songwriter, Country Artist
2000 Saturn SW2 w/120,000 miles
New radiator, radiator fan motor, ECTS, TPS, NGK plugs, PCV valve, ACDelco plug wires, front O2 sensor, muffler...
Old 03-29-2012, 11:40 PM   #8
adventureoflink
adventureoflink's Avatar
There is always hot wiring the fan to run through the battery.. there's a video in the new/returning S-series owners' checklist that covers this..
Also, this is why you replace the reservior cap.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive & Well
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, prolly needs front driver strut
Add to adventureoflink's Reputation
Rate the quality of this post and help adventureoflink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-30-2012, 12:34 AM   #9
Check the fan fuse, fan relay, then the fan connector. Carefully spin the fan by hand. Sometimes, corrosion prevents a good electrical connection and 'exercising' the connection by disconnecting/connecting scrapes away corrosion for better electrical conduction. If the fan still won't turn on with the a/c turned on then try wiring the fan directly to the battery; if the fan won't run or runs slowly, replace it.
With a dead fan not running when needed, the cooling system may have overheated and vents out the coolant cap as it automatically relieves pressures above (approximately) 18psi. Once the fan issue is fixed, monitor the coolant level; if no more coolant is lost then it was the dead fan causing the coolant to overflow out the pressure cap vent.
Old 03-30-2012, 01:44 AM   #10
madpogue
1996 SW2
Quickest test - disconnect the fan, put a voltmeter on the connector of the harnes, start the engine, turn on the A/C. If you get voltage, everything up to that point is good and it's new fan motor time. If not, you get to start looking "upstream" (wiring, fuse, relay, PCM trigger, etc).
Old 03-30-2012, 08:13 AM   #11
alordofchaos is a jewel in the roughalordofchaos is a jewel in the roughalordofchaos is a jewel in the rough
1997 SC2
system is pretty well sealed - I don't think anyone lost coolant in the first 5 years when the cars were new. As mentioned, could be boiling out. Did you look around the water pump? I've no experience with this myself but have read about a seal that will weep small amounts of coolant there
...Wait, what, I actually won that eBay auction?
Guess I now (12/2008) own a 1998 SL2, silver 5 spd :p
And now (7/2010), a Craigslist 1997 SC2 5 spd
Old 03-30-2012, 10:07 AM   #12
Bernie
Bernie is on a distinguished road
1998 SL1
After replacing my thermostat there was a very tiny leak whose source was impossible to determine accurately. It that was either at the thermostat housing seal or hose clamp. The O-ring that came with the Stant thermostat looked awfully thin and fit very loosely within the housing groove. I torqued the mounting bolts and the hose clamp a bit more and everything sealed. But, like I said, it was impossible to know where it was leaking from, though I suspected the O-ring and hose clamp.
Add to Bernie's Reputation
Rate the quality of this post and help Bernie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bernie is offline   Reply With Quote
new ECTS, Temp gauge still hovering at the 1/4 mark chinkey1234 S-Series Tech 4 03-25-2012 07:26 AM
Changed coolant, temp gauge reads warmer mr18436572 S-Series Tech 10 11-25-2009 07:58 AM
ECTS Temp Gauge Issue Questions Katmack7 S-Series Tech 17 08-22-2008 10:09 PM
New ECTS...still have Hot Temp Gauge 2NDSOUT S-Series Tech 6 05-22-2008 09:20 AM
ECTS and Temp Gauge Sensor Wiring WingsOfSaturn S-Series Tech 7 10-22-2005 09:45 PM
