Old 03-24-2012, 11:28 PM   #1
Dpickens
Dpickens is on a distinguished road
Dazed 95 sc2 Auto to standard swap problems
I recently started an auto to standard swap on my 95 SC2. long story short I finished it up yesterday, and it wont even crank when I turn the key.... I checked everything and its fine, I crawled under and I used a screwdriver to jump the terminals on the starter and it gets juice, however it just sounds like its spinning in the soliniod. so I have 2 problems. Why is there no juice running to the starter when I use my key and when it gets juice why is it not engaging the flywheel? oh I have the ECU from the donor car (same year, and same options except it being a 5 sp) and my starter was working perfectly before the swap, is there some sort of clutch switch I have to install? or is there a way to bypass? or did I miss a connection? sorry for this long post
1995 Black SC2 Automatic 5 Speed Swapped
Add to Dpickens's Reputation
Rate the quality of this post and help Dpickens reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dpickens is offline   Reply With Quote
Old 03-24-2012, 11:53 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
Default Re: 95 sc2 Auto to standard swap problems
Solenoids don't spin, they click. Did you take care of the neutral safety switch wiring (aka stick a fuse in the harness)? (While we're asking wiring questions, did you wire up the reverse lights? Those are the 2 electrical bits to take care of, aside from the PCM.)
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 03-25-2012, 12:00 AM   #3
Dpickens
neutral safety switch? witch wire is that one and where is it coming from? and how do i wire up the reverse lights?
Old 03-25-2012, 12:02 AM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
I'm assuming you kept the auto's wiring harness under the hood?
Old 03-25-2012, 12:16 AM   #5
Dpickens
yes I did... I hope that isnt bad.......
Old 03-25-2012, 12:49 AM   #6
Gold Saturn
Gold Saturn is on a distinguished road
2000 SC1
This is exactly what you need to do:
You might not have the connector that goes to the reverse switch (did you get a donor car or did you buy these parts seperately?), that can be sourced and spliced in easily enough later. It's the brown connector in the pic.
Anyways, the connector with the 2 purple wires....Jam a 30 amp fuse in there just like the pic shows and either zip tie it in or cover the whole thing with electrical tape, or both. You should be golden after that. That connector attaches to the neutral safety switch on your automatic transmission. That switch only gets continuity in either neutral or park (I think...) and will not allow the car to start if there's no continuity i.e. in gear. Keep in mind you can also hook the wires up to the clutch pedal safety switch if you wanna do that (Car won't start unless clutch pedal is depressed) but if you just put the fuse in there the car will start no matter what (Just make sure you're in neutral or your clutch pedal is in...I've forgotten about that one a few times myself...but the car only lurches forward enough to embarrass me but not damage anything.
2000 SC1, 5 spd swapped @ 133k, totaled by drunk driver @ 165k, RIP
Add to Gold Saturn's Reputation
Rate the quality of this post and help Gold Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gold Saturn is offline   Reply With Quote
Old 03-25-2012, 12:58 AM   #7
Dpickens
I didn't get a donor car, I bought the parts off of a guy parting out a SW2 and the car is long gone.
Now I still had the problem when I jump the starter... any ideas? or will installing that fuse solve the problem also? because when I use a screwdriver to test it, the starter will spin but not engage the flywheel
Old 03-25-2012, 05:09 AM   #8
fetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nice
1996 SC2
Sounds like a bad starter being masked by the lack of a fuse in the neutral safety switch plug.
My collection of S-Series info: "https://drive.google.com/folderview?id=0B5D8XfJgavxrdE5mcHBlMG5rbUU&usp=sharing" (copy & paste between quotes)
Old 03-25-2012, 01:51 PM   #9
Dpickens
The starter worked fine before the swap... It would be my luck that it quits while I'm working on it
Old 03-25-2012, 01:58 PM   #10
Gold Saturn
2000 SC1
Stupid question but are the teeth meshed with the flywheel? If they are then yeah your starter must be busted....
Old 03-25-2012, 02:27 PM   #11
ssicarman
ssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to all
ssicarman's Avatar
Which termminals are you jumping on the starter?
To test it you should be going from the larger red wire to the smaller purple wire (on the solenoid). This should cause the starter to crank the engine. If you go from the larger red wire to the larger wire out of the solenoid to the starter motor you will only get the starter motor spinning.
Add to ssicarman's Reputation
Old 03-25-2012, 08:17 PM   #12
madpogue
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
1996 SW2
You did remove the flexplate from the engine and replaced it with a flywheel, right?
Add to madpogue's Reputation
Old 03-26-2012, 12:16 AM   #13
Dpickens
I figured it out.... as soon as I put the fuse in, it fired right up. but thanks for all the help on this guys... SHE LIVES AGAIN!!!!!!
Old 03-26-2012, 04:58 AM   #14
Gold Saturn
2000 SC1
Nice, good to know it wasn't anything serious.
Unless there's some good junkyards around your area OR if you can find this on ebay instead here's the part number for the pigtail that plugs into the reverse light switch on top of your transmission that you can splice into your auto harness like shown above so you can get your reverse lights working.
P/N 12085485 for the connector pigtail. It's about $15, rather expensive for a connector, but here in CT we don't really have the luxury of Pick N' Pulls, so I'm usually forced to purchase stuff new...
2001 SW2 auto to manual swap BIG problems silverslug S-Series Tech 33 06-01-2011 11:25 PM
Auto trans problems post swap - yes I also searched... Thee_Antic S-Series Tech 3 07-25-2010 08:36 PM
Has anyone Put 95 Saturn sc 1.9 soc engine standard in a 94 Saturn SL1 1.9 Auto Tran umaccor S-Series Tech 1 01-10-2009 06:23 AM
Standard Problems Listing DeGauss S-Series General 2 02-27-2006 10:52 AM
Auto into Standard? cormor S-Series Tech 19 09-05-2003 07:06 AM
