#1 | ||||
![]() Join Date: Aug 2008
2004 ION-1 Sedan
Is it everyones or just mine that revs up high when it is first started and then will clunk into gear hard if I shift into gear fast at start up when the RPMs are up. Also it makes a funny noise sometimes at start up, about 50% of the time. I will try and record it and post a video link. It has been doing if for eight months or so and everything seems normal besides start up.
... 2004 Ion1 2.2 DOHC, Aisin 5 Speed Auto with 146,500 Miles 2004 Chevy D-Max/Ally with 114,000 Miles
#2 | ||||
![]() Join Date: Jul 2009
2006 ION-3 Quad Coupe
Sounds like it could be a sensor issue, fuel pump, etc. Hard to say. Is it throwing a code, and what year is your car? Try removing the negative battery cable for 30 minutes. That will reset the computer.
#3 | ||||
2004 ION-1 Sedan
It is the 2004 in my sig.
I will try to battery thing. Thanks ... 2004 Ion1 2.2 DOHC, Aisin 5 Speed Auto with 146,500 Miles 2004 Chevy D-Max/Ally with 114,000 Miles
#4 | ||||
![]() Join Date: Feb 2012
2004 ION-2 Quad Coupe
I've had my Saturn 2004 IOn2 for about 2 weeks now and noticed this same thing. Specifically unusually high rev at start up for about a second. The idle quiets down pretty quickly and is normal after that. Just wondering if that is normal.
Calirider did the battery suggestion work? Thanks
#5 | ||||
![]() ![]() Join Date: Nov 2001
Mine runs fast too. I know what my problem is though. My power brake booster won't hold a vacuum for very long. So whe I start up the brake booster acts like a big vacuum leak. It puts a lot of air into the motor and that makes it race a little on startup.
#6 | ||||
Thanks Jim. How did you determine that was the issue?
PS. what year is your car and how many miles
#7 | ||||
It's an 04 with 167K miles. I lose brake assist within 2 minutes of shutting the motor off. this means that the vacuum in the booster can has gone away ( not from using the brakes either). So when I start the car the engine has to suck all of the air out of the booster can and that acts like a partially open throttle (lets more air in) so the engine races a bit. I also have a Ford Ranger that does the same thing even though I have replaced the booster unit twice. Runs normally, brakes OK, just revs a little on startup.
#8 | |||||
Thanks Jim. This car only has 55K miles So I hope you don't mind this newbie question but what do you mean that you lose brake assist AFTER you shut off the car (what's the symptom?).
I tried disconnecting the battery for 30 minutes, didn't do anything. Did learn two interesting things: 1. if you try to start the car with the battery disconnected. The key cannot be removed. Had to use the little plunger under the steering column. 2. I did not lose my radio pre-wet stations (which was nice) Perhaps it's supposed to rev at startup. Quote:
#9 | ||||
disconnecting the battery does very little. they lose brake assist less than 2 minutes after shutting off the engine, this is self explanatory. sounds like they need a new brake booster.
... 2007 Saturn Ion 2 2003 Chevrolet venture lt trifecta dealer for the U.P. and WI. There is no two door ion. Proudly driving one of the last saturns produced before gm killed the brand.
#10 | ||||
ION2 I know it's an old thread but earlier in the thread someone suggested disconnecting the battery to see if it would fix a high rev condition at startup. My reference was to that. I tried that and it didn't do anything. I'm starting to think maybe that's just the way this Saturn starts.
I still don't know what losing brake assist means
| Thread Tools | |
| Display Modes | |
| Starting to troubleshoot - questions | saturnhouse | S-Series Tech | 9 | 09-20-2009 04:59 PM |
| Questions about electrical problems - starting Vue | FlimFlam | Vue Tech | 6 | 10-22-2007 11:12 PM |
| Rough starting...now not starting | schultp | S-Series Tech | 20 | 06-02-2007 01:59 AM |
| She's got lots of problems and questions...starting with the oldest...(long) | GFsSL2 | S-Series General | 10 | 05-31-2006 05:06 PM |
| Couple of questions: Starting and 02 sensor | monkeysl2 | S-Series General | 6 | 11-23-2004 06:08 PM |
