Old 01-18-2012, 08:24 PM   #1
Ilovesaturncars
Ilovesaturncars is on a distinguished road
2001 SL2
1996 SC2
Dizzy 2001 horn not working
I am trying to figure out why the horn on my new(old) 2001 sl2 wont work. I've pulled the horn off , put power and ground to it and it beeps fine. I removed the air bag and checked the switches with an ohm meter and they work. I switched the horn relay with the one next to it with no change(Im assuming they are both good now) where too next ? anybody have this one before?also the horn will not sound when the doors are locked/un locked or the panic button is pressed (the lights, flash)
thanks
Add to Ilovesaturncars's Reputation
Rate the quality of this post and help Ilovesaturncars reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ilovesaturncars is offline   Reply With Quote
Old 01-19-2012, 11:38 AM   #2
bluesl2
bluesl2's Avatar
Default Re: 2001 horn not working
Check at the horn connector itself and see which you are lacking, power or ground, then go from there.
Add to bluesl2's Reputation
Old 01-20-2012, 12:17 AM   #3
Ilovesaturncars
2001 SL2
1996 SC2
Thumbs Up Re: 2001 horn not working
after allot of testing and ruling out I figured out the problem. I used a short wire to jump power from the horn fuse (after the fuse, so its fused) to the leg of the horn relay.The horn honks. On the back of the under hood fuse block I discovered the underside leg of the fuse had no wire plugged into it and the relay also had no wire plugged into it. strange as it sounds. I need the wiring diagram for the UHFB for a 2001 saturn sl2.Can someone post it for me please.
thanks
Old 01-20-2012, 12:25 AM   #4
Did you check your other post?
Old 01-23-2012, 11:44 PM   #5
Ilovesaturncars
2001 SL2
1996 SC2
hi the horn wiring diagram you posted for me helped allot to get me where I was, but I also need a diagram for the under hood fuse block now. I am trying to figure out where the wires that are not there now went to(ya that does sound strange) either they were removed or I am missing something big, but the diagram would help.
thanks
Horn Not working gdlvnman S-Series General 8 11-16-2011 12:30 PM
02 Vue Horn not working Andyec Vue General 1 03-28-2011 09:37 PM
Hi....Q on a non-working horn DrEvil S-Series General 10 11-29-2010 04:14 PM
Horn not working hlp plz! Salsa88 S-Series Tech 12 12-27-2007 11:38 PM
Horn not working gunny S-Series Tech 10 08-28-2002 12:52 PM
