Astra General Photos
by Charlie
2008 - Automobile Magazine Advertising Supplement
13 photos
1 comments
by Charlie
2007.5 - Opel Astra
5 photos
0 comments
by ad_astra
Astra - Member Photos
229 photos
77 comments
by fotc13
229 photos
77 comments
Old 12-17-2011, 06:10 PM   #1
fershy
fershy is on a distinguished road
fershy's Avatar
Default rear turn signal bulb #?
Ok, so the canbus is telling me I have a rear signal light bulb out. No problem I figure. I take it out and see that the filament is indeed burnt out. I try to stick a 1156 in there but no go. A few more 1156's later I figure it must be a specific bulb. Sure enough, 1129 is the number on the original OEM bulb. Head over to Napa and pick one up. Plug it in and nothing. Now I switch out the OEM reverse bulb and it works just fine. Still nothing out of the NAPA bulb. OK pick up a couple more 1129 from a different supplier. Again nothing. When I switch the two remaining OEM bulbs to different sockets, they all light up. I note that the OEM 1129's have what looks to be a resistor inside the bulb. The aftermarket bulbs do not. Anyone else run into this problem? Do I need to buy the bulb at a dealer or what? Weird.
fershy
09 Saturn XR5
07 Saturn Sky RL
Add to fershy's Reputation
Rate the quality of this post and help fershy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fershy is offline   Reply With Quote
Old 12-17-2011, 08:01 PM   #2
bdshaffer
bdshaffer is on a distinguished road
bdshaffer's Avatar
2008 Astra XE
Default Re: rear turn signal bulb #?
Did you cycle ignition? If the bulb is out, the controller switches the circuit off. It tries again next time you start the car.
Add to bdshaffer's Reputation
Rate the quality of this post and help bdshaffer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bdshaffer is offline   Reply With Quote
Old 12-17-2011, 11:00 PM   #3
fershy
fershy's Avatar
Yes, I switched the ignition on and off between bulb changes as I did notice the canbus was not responsive to changes until the ignition was cycled.
09 Saturn XR5
07 Saturn Sky RL
Old 12-19-2011, 04:50 PM   #4
fershy
fershy's Avatar
Well, it turns out 1156 is the correct bulb after all. The 1156's I tried must have been dead. The 1129 is actually a 6V bulb and they don't last too long in the Astra!
Problem solved,
fershy
09 Saturn XR5
07 Saturn Sky RL
turn signal indicator bulb replacement ebshumidors S-Series Tech 2 10-05-2008 06:40 PM
Right Front Turn Signal Bulb? Ruben Alonzo Relay Tech 2 12-27-2007 07:09 PM
Front Turn Signal Bulb ygor Relay Tech 2 01-23-2007 10:28 PM
Turn Signal Bulb Smokey Relay Tech 1 11-07-2006 09:45 PM
Turn Signal Bulb Problem k-dee Ion General 10 05-17-2004 09:51 PM
