Outlook General Photos |
· · · 2007 - Model Year Brochure 34 photos 0 comments |
· · · 2007 - Press Photos 37 photos 0 comments |
· · · 2006 - NYIAS Photos 52 photos 1 comments |
· · · 2007 - Outlook XR Road Test 81 photos 1 comments | ||||||||
Thread Tools | Display Modes | |||
#1 | ||||
![]() Join Date: Feb 2011
2008 Outlook XE
After reading this blog - http://www.zdziarski.com/blog/?p=1270 - it appears that OnStar will now obtain your driving data and/or habits and sell them to 3rd parties...EVEN IF YOU DON'T USE THEIR SERVICE!
So, since I do not subscribe to OnStar anyway and do not desire for them to make money from my private data, how do I physically disconnect the OnStar system? Thanks. ... 2008 Saturn Outlook XE - Purchased 2/16/2011
#2 | ||||
![]() Join Date: Jun 2011
1996 SW2
I agree. It's an uninvited invasion of your privacy. I recently purchased a new Chevrolet that was OnStar equipped (free trial time).
I also own a data collecting device that plugs into the OBD-II port under the steering wheel. Just to check a few pieces of data I had my 'chip' plugged into my new car for a few days. OnStar contacted me and said that I 'must have something connected to my OBD-II port' and it was stopping them from collecting the data they have the ability to collect. I knew what I had and very soon afterward removed the 'chip' so OnStar could collect data. They were then happy. I considered leaving my 'chip' installed in the port but was led to believe they could influence the new car warranty by notifying the dealership after notifying me. BIG BROTHER #&%!@ FYI: the chip I have had for a few years and is from Davis Instruments (not giving them a plug) and is called DriveRight Car Chip E/X. Don't remember what it cost but collects around 12 to 15 data goodies from the computers. If interested you should be able to BING or GOOGLE to find on net. As far as a physical disconnect, I have no idea. By the way, I only kept OnStar for about 3 months. Didn't like OnStar, liked SIRRUS Radio. ... 1999 SL2, My first Saturn. GONE 1996 SW2, My second Saturn
#3 | ||||
![]() Join Date: Apr 2007
2007 Outlook XR
There's also at least one "connect your iPod / iPhone to your car" device that replaces the OnStar module on the market. These are the ones that make a bluetooth connection to your device, and let you use the radio controls, steering wheel buttons to control your device, and the car speakers and microphone also.
If I can find it again I'll attach a link - a search through the forums here should certainly turn up references if you can't wait for me ![]()
#4 | ||||
Most, if not all, OnStar components consists of the OnStar module, the vehicle communications interface module (VCIM) that connects to the radio and other modules. I'm guessing that locating and disconnecting power to it will render it disabled and unable to xmit any signal.......................
Left pic - Ions, right pic - Vues. I do not know where it is located in Outlooks. ... *The CPS is the heart of the entire EFI system. No cps = dead EFI system* *There's more to a/c than just a few cans of refrigerant* *There's more to brakes than just replacing parts*
#5 | |||||
2008 Outlook XE
OK, after searching for a while I came across another forum and found out where the OnStar module is located.
So, I will try to disconnect it soon and see what happens. Anyone know if this will cause any issues with anything else? Thanks. ... 2008 Saturn Outlook XE - Purchased 2/16/2011
#6 | ||||
![]() Join Date: Dec 2006
Just pull the fuse for the onstar module (VCIM), or you could unplug all connectors that plug into it. Fuse is easier. It cant work if it has no power. It will not cause any problems. If you still had service it would just give you a red led light next to the onstar button.
... Saturn Tech 2007 Ion 3 2.4L ---custom intake, HP tune, stock Redline coil springs 94 SW2-my daily, custom intake and ported throttle body
#7 | ||||
![]() ![]() Join Date: Nov 2008
2008 Outlook XE
'Carbon did ya pull the fuse yet ? Any unforeseen complications that "saturn tech" had not heard of ...
nite, doug c ![]()
#8 | ||||
2008 Outlook XE
...later in evening i chkd my manual which i had accidentally brought inside.
Referencing pg 5-98 (and next) a fuse (allegedly) found in the "InstrumentPanelFuseBlock", designated "Onstar/Vent" ! Usage: emissions Who is going to test it doug c
#9 | |||||
2008 Outlook XE
I also noticed the fuse description in the manual and decided not to pull that fuse. The only thing I have done is to disconnect two black cables that I believe to be antennas. There are two other connections to that module that have multiple smaller wires of various colors. I am debating on removing those as well, but I'm not sure if this will cause any other issues. I guess I'll just have to test it and see. ... 2008 Saturn Outlook XE - Purchased 2/16/2011
#10 | ||||
2008 Outlook XE
Looked back at your earlier post, and see that the onstar mod' is within the jack well.
Will look at it also when i go in there after the jack in a week or so when I'm swapping out summer' for winter set. I would think that if the blacks' look like antennaes ya should be okay now The others (multi-wires) are likely the leads from various linked components. imho nite, doug c
#11 | ||||
2008 Outlook XE
FYI, after I swapped out my summer for winter set of tires before packing things back into the compartment, I grunted/swore and groaned before finally popping off the wto antannae (sp?) looking wires from the bottom of the shiny metal unit. I left the multi-wire connects alone.
In the couple wks since no warning bells or whistles, although I haven't pressed the phone symbol on my visor to chk if the connection to onstar was shutdown !! ie. at least 3 months ago even though I ceased the service (like 2 yrs back, freebie fini) I had pressed the button to try out a contest entry offer it did work at that time and I was chatting with one of their CSRs !! nite, doug c
| Thread Tools | |
| Display Modes | |
| 03 Vue 3.0 Fuel Line Disconnect (pic) | ashbyj | Vue Tech | 2 | 08-02-2011 09:17 AM |
| Security System dead after battery disconnect | smalltownjava | S-Series General | 15 | 10-28-2007 10:40 AM |
| Battery disconnect..... | Audiguy | S-Series Tech | 3 | 08-01-2007 10:58 PM |
| Onstar Phone System Question | TXVue04 | Vue General | 14 | 08-01-2004 08:41 AM |
