Old 09-11-2011, 04:45 PM   #1
richbrad08
richbrad08 is on a distinguished road
Default High Idle 00 Saturn Sl2
So i noticed i will have a high idle when i drive around town. I notice this because when i am at a stop light and put the car in neutral it goes to 1800 or 2k RPMS. ANy idles on what the cause? I cleaned the Throttle Body, Linkage, Iac and inside the intake.
Add to richbrad08's Reputation
Rate the quality of this post and help richbrad08 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
richbrad08 is offline   Reply With Quote
Old 09-11-2011, 04:51 PM   #2
TXSaturn02
TXSaturn02's Avatar
Default Re: High Idle 00 Saturn Sl2
Automatic or manual transmission? Does it do it all the time or is it intermittent?
New owner As of 01/01/18: 225,000 Miles
As of 03/20/18: 46,135 Miles
Old 09-11-2011, 10:01 PM   #3
richbrad08
intermittent and its auto.
Old 09-11-2011, 10:42 PM   #4
td1238
td1238 will become famous soon enoughtd1238 will become famous soon enough
If you can reset the idle by turning the key off and then back on, then the TPS needs replacing. Be careful where you purchase your TPS from, as some stores have the numbers confused. For instance, you are driving a '00. I drive a '99, but O'Reilly Auto recommends the TPS that's supposed to be used on your car for my car.
If idle is usually high, consider your temperature gauge, which should typically read 3/8 after at least 15 minutes of driving. If it always reads low, you may need a new thermostat (more likely) or a new ECTS (less likely...this is more likely to cause erratic or sporadic gauge readings).
Add to td1238's Reputation
Rate the quality of this post and help td1238 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
td1238 is offline   Reply With Quote
Old 09-12-2011, 09:03 AM   #5
Clintw
Clintw is on a distinguished road
Other suggestions:
1. Clean throttle body using lacquer thinner
2. Clean or replace idle air solenoid (IAC) using lacquer thinner. Be careful not to force the cone type valve. Replace it for about $30 if still high idle.
Add to Clintw's Reputation
Rate the quality of this post and help Clintw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Clintw is offline   Reply With Quote
Old 09-13-2011, 10:30 AM   #6
DIYguy
DIYguy's Avatar
1997 SC2
Wrench Re: High Idle 00 Saturn Sl2
Most likely it is the TPS or IAC issue as previous posters have said, but it may be worth checking the following items as well-
You didn't mention checking the PCV elbows, line and valve. The elbows and lines can crack and will cause a high idle. It can come and go because the IAC motor will try to compensate for the leak but will get out of range so it resets itself and tries again (it isn't very smart). The PCV valve itself can be stuck open now and then. That can easily cause a high idle that comes and goes. Replace it with a fixed orifice type such as a PCV1009 instead (there are several other threads on this subject).
Also check for a bad seal on the MAP sensor. Make sure it is not split and that it has some spring to it (not hardened). And check for crud built up in the passage into the manifold that feeds it. If it is plugged it will cause a sluggish MAP response, or a completely false one. That will cause all sorts of issues.
DIYguy
Quando Omni Flunkus Moritati
97SC2 Saturn, Cruze Eco, Chevy SS P/U, Honda VT1100C
Add to DIYguy's Reputation
Rate the quality of this post and help DIYguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2000 Saturn SL1 High Idle mfoster670 S-Series Tech 5 12-16-2013 09:18 PM
High idle 02 saturn sl2 trombleydc S-Series General 1 01-17-2011 01:16 PM
2000 Saturn L high idle Maxine L-Series Tech 1 02-27-2010 09:55 PM
95 Saturn SC2 5sp 144k with a high idle? fritcr S-Series Tech 35 01-22-2009 10:22 PM
98 Saturn SC1 SOHC, HIGH IDLE Jerz3455 S-Series Tech 13 11-26-2007 05:25 PM
