Old 07-14-2011, 07:51 AM   #1
someone
someone is on a distinguished road
Default low traction warning
2004 Saturn Ion 3, takes 205/55/16.
I put 215/60/16 on the back last night, after being assured by 2 tire dealers that it would not affect anything. The front has the original size tires.
Got it out on the road and low traction warning light comes on and stays on only when going up an incline, and when speeding up to change lanes.
Any ideas what the problem might be?
Add to someone's Reputation
Rate the quality of this post and help someone reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
someone is offline   Reply With Quote
Old 07-14-2011, 08:05 AM   #2
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
Default Re: low traction warning
my guess is tires are turning at different speeds because of different size tires so the car thinks tires are slipping because they are turning faster than the other two.
Add to onefunkar's Reputation
Old 07-14-2011, 08:12 AM   #3
brapple
brapple is on a distinguished road
you need to have the same size tire on all four corners. you would want 215/50R16 to have a very close match to 205/55R16 tires.
http://1010tires.com/TireSizeCalcula...?action=submit
there is a 5% tire diameter difference between the 205/55 and the 215/60. where as the 205/55 to 215/50 is 1.65%
2004 Ion 3 Sedan
2k Ford SVT Contour
99 Ford Contour - 3L+turbo
99 Ford Contour Se Sport
Add to brapple's Reputation
Rate the quality of this post and help brapple reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brapple is offline   Reply With Quote
Old 07-14-2011, 10:10 AM   #4
rklein
rklein is on a distinguished road
brapple is absolutely right. The reason for this is that the wheel speed sensors (that are also used by the ABS) sense that the different-diameter tires are spinning at different speeds, so it concludes that two of the wheels must be sliding. That's a problem. The traction control system may start cutting engine power to try and stop the "skid." Changing tire size slightly from stock isn't usually a problem, but you need the same size tires on all four wheels to avoid screwing up the ABS/TCS computer.
Add to rklein's Reputation
Rate the quality of this post and help rklein reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rklein is offline   Reply With Quote
Old 07-14-2011, 10:11 PM   #5
2006 ion2
2007 ION-2 Sedan
why would you put the wrong size tire on the car, anyways? put the right size on the back, problem solved.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 07-16-2011, 01:21 PM   #6
06_Ion2
06_Ion2 is on a distinguished road
06_Ion2's Avatar
2006 ION-2 Quad Coupe
I have diff sized tires, it dont matter unless you have traction controll.
VISIT MY CARDOMAIN --> http://www.cardomain.com/ride/2259877
s256 turbo, vulcan intake, exedy clutch, 8.9:1, camed, eagle rods, 2.4 tb, B&G coilovers, patriot head, stage 2 axels 418whp 2.2 :)
Add to 06_Ion2's Reputation
Rate the quality of this post and help 06_Ion2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
06_Ion2 is offline   Reply With Quote
Old 07-16-2011, 03:26 PM   #7
2006 ion2
2007 ION-2 Sedan
except, once again, why would you? it's not like it's a hard size to find.
2007 Saturn Ion 2
Old 07-16-2011, 04:10 PM   #8
06_Ion2
06_Ion2's Avatar
235/50R16 DR's are on front
Old 07-16-2011, 05:02 PM   #9
2006 ion2
2007 ION-2 Sedan
and that wide a tire doesn't wear unevenly from being put on a 6.5" or 7" (can't remember which it is) rim?
2007 Saturn Ion 2
Old 07-16-2011, 05:34 PM   #10
06_Ion2
06_Ion2's Avatar
its on a 7in rim. It gets driven about 2500 miles a year, and almost eats them up durring those miles so I buy new ones every year.
Brake warning and ABS warning lights 1tuffref S-Series Tech 16 01-06-2008 08:00 PM
traction wingit S-Series General 35 03-10-2007 10:46 PM
My VUE's lack of traction, "Traction Control" skijay Vue General 16 12-23-2005 11:17 PM
01 SC1 EVO w/ABS+Traction jaypfeiffer Classifieds 3 09-08-2005 10:19 PM
Traction Tmac General Saturn Discussion 18 02-22-2003 12:35 AM
