Old 01-17-2011, 10:17 PM   #1
Catholic
Catholic will become famous soon enough
1992 SL1
Default 1992 SL1 instrument cluster LEDs
Hello,
Would anyone know what LEDs would work for a 1992 SL1 for the illumination lights inside the instrument cluster. The lights in my car are #GE73 and there are 10 of them in a blue base. I have looked on Superbrightleds.com and am unsure what base would match mine. Thank you for any help that you could give.
Add to Catholic's Reputation
Rate the quality of this post and help Catholic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Catholic is offline   Reply With Quote
Old 01-17-2011, 10:37 PM   #2
Default Re: 1992 SL1 instrument cluster LEDs
bulb #161,#73 & #74. Not sure which on specifically but leaning towards 73 & 74.
http://www.sylvania.com/ConsumerProd...placementGuide
Old 01-18-2011, 12:18 AM   #3
Catholic
1992 SL1
Thanks fetchitfido,
My SL1 has the GE73 for 8 illumination lights and also for the Panel Dimmer Light and for the Rear Window Defogger Switch Light. The GE74's are for the 14 Instrument Panel Warning Lights. The 161's are for the Ashtray and the PRND32 Shift Indicator Light. My owners manual also has a 73, not a GE73, for the Cigar Lighter Ring Light.
I think that this post saturnfans.com/forums/showthread.php?t=115575 uses the T1.5 LED Twist Lock Lamp, superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=/specs/74_t15.htm, so I think that that is the route that I will go.
I just wish that there was another LED that had a wider dispersion of light and was still plug and play.
LEDs for '95 SL1 instrument cluster FrozenPilot S-Series Mods 6 04-18-2011 10:24 AM
instrument cluster LEDs andysouza3235 S-Series Mods 84 10-20-2008 02:20 PM
help! instrument cluster LEDs dorisSL S-Series Mods 15 10-07-2008 09:29 PM
What LEDs do I need for 2002 SC2 instrument cluster? bigtoque S-Series General 16 09-22-2008 03:56 PM
replacing instrument cluster leds pauledwards03 S-Series General 7 05-17-2005 07:28 AM
