Old 12-22-2010, 09:51 AM   #1
USAAF01
USAAF01 is on a distinguished road
Default 2001 SC2 Fog Light & Dimmer Switch Replacement
My fog lights quit periodically, and the fog light push button switch does not work, meaning it does not engage. Simple fix right? Where can I find a replacement switch? I have the housing that includes both the fog light push button switch and the instrument panel light dimmer switch that is the likely culprit.
Thanks and Merry Christmas!
Raymond
Add to USAAF01's Reputation
Rate the quality of this post and help USAAF01 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
USAAF01 is offline   Reply With Quote
Old 12-22-2010, 10:11 AM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: 2001 SC2 Fog Light & Dimmer Switch Replacement
Raymond
Junkyard, www.saturnparts.com or www.getsaturnparts.com
Mike
-1991 Turbo SL2 - Gone, but not forgotten.
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 12-22-2010, 11:06 AM   #3
SLCraig
SLCraig is on a distinguished road
1996 SL2
2000 SW2
I have found the 3rd gens are less common to come with foglights than 2nd gens, but I have seen the odd foglight dimmer switch out in my local yard. They are there, just not tons of them it seems. that is where you have to go... Wreckers.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLCraig is offline   Reply With Quote
Old 12-22-2010, 07:30 PM   #4
ruley73
ruley73 is a name known to allruley73 is a name known to allruley73 is a name known to allruley73 is a name known to allruley73 is a name known to allruley73 is a name known to all
ruley73's Avatar
2007 ION-2 Quad Coupe
Raymond
The fog light switch is not available as a separate part. It only comes as one piece along with the I/P dimmer knob as you described.
Junkyard is the best bet since new parts are getting harder to obtain by the day. This part from a 2000+ SC2, SL2, SW2 will work. If you can find a 2000+ SC2 that is the best bet since fog lights were standard equipment on all 1997-2002 SC2s. However, the 1997-1999 models have the 2nd gen interior, and thus don't have the part you need.
2007 Ion 2 Quad Coupe 5-speed manual 176K miles
2007 Chevy Equinox LT 176K miles
Add to ruley73's Reputation
Old 11-14-2014, 11:04 AM   #5
wileyone123
wileyone123 is on a distinguished road
apparent fix/repair:
my 01 SC2 fog lights have intermittently not been working. sometimes they wont come on when button is pushed....sometimes wont shut off...sometimes come on/off randomly w/o even being touched........wth!
upon removal of the switch and carefully opening it up, i polished the male terminals/pins where both connectors plug into with a small round wire brush.
i then very carefully used a tiny flat blade screwdriver to bend the stainless steel tangs/wipers out....only about .060"(using the other untouched wiper as a reference to distance). then, bending the other tang out to match the 1st one bent. this only applies more pressure to the circuit board.
Recommendation: spreading the current grease on the board back onto the contact area, or applying some more dielectric grease to the area where the wiper contacts.
i also carefully polished the small grid with the wire brush, where the push-button contacts to turn on the fog lights.
i previously read of corrosion being inside the switch...causing poor contact.
i live in Michigan, and my switch did not appear to hv any of this.....only possibly on the connector terminals(which were polished).
so far, no more random ops w my fog lights
Add to wileyone123's Reputation
Rate the quality of this post and help wileyone123 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wileyone123 is offline   Reply With Quote
Dimmer Relay Buzzing? Dimmer Switch? HELP!? bhoard L-Series Tech 9 03-11-2010 09:45 PM
Help Installing Dimmer Switch 95c2 S-Series Mods 1 01-29-2006 03:25 PM
Dimmer/Fog light switch trouble after MP3 install 9LIVEZ Vue Tech 6 12-01-2005 07:54 AM
FS: new S-series dimmer switch kmix99 Classifieds 1 04-26-2005 11:44 AM
wiring to dimmer switch the_skin_eater Mods and Performance 0 01-10-2005 12:09 PM
