Old 11-12-2009, 11:04 PM   #1
james
james is on a distinguished road
james's Avatar
Default How To: Changing the Oil in a Saturn Outlook
A new story entry has been added:
Here is a step-by-step how-to guide that I put together after changing the oil in my 2009 Saturn Outlook with GM's 3.6L Direct Injection (DI) V6. The procedure should also work for anyone with who owns a GMC Acadia, Buick Enclave, and Chevrolet Traverse. This process worked for me, but I cannot accept any responsibility for the procedure or provide any guarantees.
'09 Outloook XE FWD - Midnight Blue
'00 Camaro Z28
Add to james's Reputation
Rate the quality of this post and help james reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
james is offline   Reply With Quote
Old 11-13-2009, 01:09 AM   #2
Doug C
Doug C's Avatar
2008 Outlook XE
Default Re: How To: Changing the Oil in a Saturn Outlook
Thanks !
nite, doug c
Add to Doug C's Reputation
Old 11-13-2009, 06:10 AM   #3
emg77
emg77 has a spectacular aura aboutemg77 has a spectacular aura aboutemg77 has a spectacular aura about
emg77's Avatar
2008 Astra XR
Nice write-up.
One comment I will make is that this is the worst and most messy oil change I have ever done. GM did not design the placement of this oil filter very well at all. It is in-accessible from the bottom end of the engine and it is not easy to get to from the top. Oil goes everywhere. It might be slightly different on the Outlook, (since I have a Traverse), but my Traverse made me want to take it in someplace to get the oil changed, and I haven't done that in over 10 years. My Astra on the other hand is the easiest and cleanest change ever. It has a top loading cartridge filter and the oil can be drained without even lifting the car.
My write-up on changing the Astra oil is here:
http://www.saturnfans.com/forums/sho...d.php?t=137477
Drives: 2014 Volt, 2017 Acadia
Past Cars: 08 Astra, 15 Acadia, 12 Enclave, 09 Traverse, 05 Vue, 04 Grand Prix, 00 Alero, 97 LeSabre, 72 Cutlass S
Add to emg77's Reputation
Rate the quality of this post and help emg77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emg77 is offline   Reply With Quote
Old 11-13-2009, 02:57 PM   #4
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
i put a rag under the oil filter before io take it off and that seems to get most of the oil drip. the first time i changed it i didnt do that and there was oil everywhere and it burned off for a while. aksi i dont see why you have to take off the engine cover. i havnt done that
Add to onefunkar's Reputation
Old 11-14-2009, 12:02 AM   #5
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
also one other important thing. reset olm
Old 11-14-2009, 12:03 AM   #6
Wingmn
Wingmn is on a distinguished road
Wingmn's Avatar
1993 SL2
2009 Outlook XR
I just accomplished my first oil change on my 09 Outlook - I've been reading up on issues and paid particular attention to the oil filter change with the oil leaking down onto the motor mount. I was concerned about this and thought I'd try a little improvising to prevent the oil spill, and wanted to share my success.
I used a cut out empty 1 qt oil bottle, a small funnel, and a tube attached to the funnel.
Placed the cut out bottle directly underneath the oil filter deflection plate - bottle top facing forward, and placed the funnel directly under the bottle opening. I placed a 12 inch hose on the end of the funnel to make sure the oil made it down to the drip pan (found out while looking at the pictures that it wasn't really necessary unless the wind is a concern).
I had NO oil escape my improvised oil "channel"
Here are a few pictures.
File Type: jpg Close up of bottle under metal deflector.jpg (135.0 KB, 103 views)
93 SL2a (My work shuttle) 225k
09 FWD Outlook (Wife's vehicle) 82k
13 Ford Fusion Hybrid (New family shuttle) 31k
Add to Wingmn's Reputation
Rate the quality of this post and help Wingmn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Wingmn is offline   Reply With Quote
Old 11-14-2009, 11:20 AM   #7
djhhjd
djhhjd is on a distinguished road
djhhjd's Avatar
2009 Outlook XR
Nice job! Is that orange ring in your pic the gasket for the old filter? That happened to me when I did the first oil change on my 09' OUTLOOK. When I took a rag to wipe off the engine surface where the filter goes it did'nt feel quite right and then I looked @ the old filter and BINGO the gasket was'nt on it. I think at the factory they install the filters super tight and dry.
Member of the "discontinued" club!
Add to djhhjd's Reputation
Rate the quality of this post and help djhhjd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
djhhjd is offline   Reply With Quote
Old 11-14-2009, 11:57 AM   #8
emg77
emg77's Avatar
2008 Astra XR
I'll give that a shot. Nicely done. My usual trick of putting a disposable plastic cup over the filter doesn't work because of the angle of the filter.
Old 11-14-2009, 03:07 PM   #9
Wingmn
Wingmn's Avatar
1993 SL2
2009 Outlook XR
yeah it was part of the old gasket - I removed it thanks to those pictures I wouldn't have noticed it.
Old 11-14-2009, 08:33 PM   #10
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
When a hurricane is approaching the quick oil change vendors are swamped with customers requiring their oil changed before evacuating.
One of them changed a friends oil and left the gasket on the engine. They made it about 30 miles away, and had to abandon their car in the path of the storm.
I can't stress enough to any car owner to stay away from these "Shake and Bake" oil change facilities.
2006 Black VUE Red Line - Now running iOS 11
Add to BobbyP's Reputation
Rate the quality of this post and help BobbyP reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-19-2009, 10:33 PM   #11
Accordionjohn
Accordionjohn is on a distinguished road
2009 Outlook XE
Super writeup. I was getting ready to change oil this Saturday on our new '09 Outlook and did a google search and low and behold - perfect procedure for doing so posted on this website. Thanks so much for taking the time to post this, James.
Add to Accordionjohn's Reputation
Rate the quality of this post and help Accordionjohn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Accordionjohn is offline   Reply With Quote
Old 12-08-2009, 01:57 AM   #12
SaturnTech122
SaturnTech122 is on a distinguished road
1996 SL2
Just how we do it in the dealer
Add to SaturnTech122's Reputation
Rate the quality of this post and help SaturnTech122 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnTech122 is offline   Reply With Quote
Old 12-13-2010, 06:26 PM   #13
Doug C
Doug C's Avatar
2008 Outlook XE
Dizzy Re: How To: Changing the Oil in a Saturn Outlook
"I can't stress enough to any car owner to stay away from these "Shake and Bake", oil change facilities. "
SHUCKS even the GM dealerships ya got to watch out for after my experience Saturday at our 'area' one !
Paid the bill walking over to the vehicle and noticed extra chrge for another 1/2 litre ($1.87) I thought that is odd but possibly a new cash grab due to the economy !!? Anyways I turned around to confirm why . . . . my origninal CSR was unavailable but another stated (w/o knowing my vehicle) it obviously needs more than 6 lts which the base oilservice chrge covers Hmmmm, that means 6.5 litres into my engine which doesn't sound right I'm pretty sure not more than 5.5 is spec. out to my vehicle pull the manual find the specs pg. " 5.2lt. " Into service desk request a $1.87 refund and extraction of appropriate amount of oil. This original CSR (who should have known better) proceeds to belittle me and announces over PS sytem that car owner wants $1.87 of oil sucked out of engine all the while lookin' at me with daggers and she says I've never had a customer come bk in with a vehicle manual (thank goodness i did or she would have been stuck on her statements of defence, "it probably needed more" "they put in what is reqd" NOT listening to me say BUT spec. is 5.2lts not 6.5 !! . . . . . . I've noticed in past shop visits this is one who has issues and if they don't loose one customer per month due to her attitude I wouldn't be surprised !!
Anywho . . got to chat with (that same ass't re: tires/rims findings) service manager who quickly chkd things out. He came back with a combo of reasons; new computerized dispensing machine seemingly not calibrated properly ( i presumed they punch in the vehicle name for oil dispensing) and the tech had just done a larger engine which required close to 7lt . . . . {duuuuuh wakee wakee !!} ?
45 min later $2 refund and ass' service mgr saying he'll be having a chat with the CSR about her attitude towards customer.
A negative experience ya would think to only have at a " Shake and Bake, oil change facility"
Thank goodness I review my invoice for oddities in service done and price quoted otherwise this could have meant a blown seal (?) on the next road trip !!
doug c
p.s. if a 'third strike' may actually have to chk out another GM dealership 15min. further away !
Old 12-13-2010, 08:25 PM   #14
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
people with 3.5 v6 aura take 4 qts and more times than not get 5.5 qts. have a relative that has happen three oil changes in a row. different places.
oil filter change without changing the oil? davesaturn Ion Tech 22 12-26-2009 03:22 PM
Change Oil Filter WITHOUT Changing Oil? Supermarine Vue General 5 10-21-2009 04:00 AM
changing clutch oil? tranny oil? bboynowee S-Series General 9 06-27-2009 07:12 PM
Changing oil in Manual Trans, 03 Saturn Ion. JH6 Ion Tech 6 10-25-2007 02:48 PM
Help: Changing oil on 1998 saturn sl2 matt_duffy S-Series General 2 08-07-2005 03:39 PM
