Old 06-25-2010, 02:22 PM   #1
partlycloudee
partlycloudee is on a distinguished road
partlycloudee's Avatar
1994 SL2
Default Draining gas tank
Can someone tell me the easiest way to remove the gas from my tank?
I have a '95 SL2 DOHC
Add to partlycloudee's Reputation
Rate the quality of this post and help partlycloudee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
partlycloudee is offline   Reply With Quote
Old 06-25-2010, 03:17 PM   #2
Default Re: Draining gas tank
Crawl under and remove the fill and vent line and then use your oklahoma credit card(siphon hose) to drain the gas out. Check for any anti siphon devices and do not get the hose stuck. If the fuel pump works just uncouple the discharge line and power up the pump. You can either jumper out the fuel pump relay or disconnect the plug and power it locally.
Old 06-25-2010, 04:39 PM   #3
partlycloudee
1994 SL2
ok....thank you. I'll try that
Old 06-25-2010, 11:04 PM   #4
RobertGary1
RobertGary1 is just really niceRobertGary1 is just really niceRobertGary1 is just really niceRobertGary1 is just really niceRobertGary1 is just really nice
1996 SC2
Even easier is to just use a syphin bulb with a long hose on it. Put the hose down the filler neck and then start the syphin. You don't need to take anything apart. These cars don't hold much gas. I usually have 2-3 10 gal cans around the garage so its pretty easy to drain even a full tank.
-Robert
Old 06-25-2010, 11:37 PM   #5
There is an anti siphon device in some of the years and it will capture your hose. That is why you take it apart. Some have it and some do not. 98 and newer it is part of the fill pipe. The older models it is not mentioned.
Old 06-26-2010, 03:21 PM   #6
Low Saturn
Low Saturn is a splendid one to beholdLow Saturn is a splendid one to beholdLow Saturn is a splendid one to beholdLow Saturn is a splendid one to beholdLow Saturn is a splendid one to beholdLow Saturn is a splendid one to beholdLow Saturn is a splendid one to behold
Low Saturn's Avatar
2000 SC2
Are you trying to do this because the pump is dead?
Mike
-1991 Turbo SL2 - Gone, but not forgotten.
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 11-15-2011, 07:46 AM   #7
Bernie
Bernie is on a distinguished road
1998 SL1
I wasn't aware that the fuel pump was rated to run continuously or prolonged periods of time like in emptying a full tank.
Add to Bernie's Reputation
Rate the quality of this post and help Bernie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bernie is offline   Reply With Quote
Old 11-15-2011, 10:12 AM   #8
magtec
magtec will become famous soon enough
1995 SW2
my 95 sw2 has the anti-siphon device.
Add to magtec's Reputation
Rate the quality of this post and help magtec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magtec is offline   Reply With Quote
Old 11-15-2011, 10:18 AM   #9
steelmanwy
steelmanwy is on a distinguished road
Fuel pump runs continuous while driving or idling.
Kurt
Add to steelmanwy's Reputation
Rate the quality of this post and help steelmanwy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
steelmanwy is offline   Reply With Quote
Old 11-15-2011, 01:40 PM   #10
Bernie
1998 SL1
Steelmanwy that's good to know. I never looked into it before and thought the pump brought the system under pressure and kept it there by intermittently turning on /off. It seemed logical based upon hearing the pump run upon initial ignition and rarely thereafter.
Old 11-15-2011, 03:58 PM   #11
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
1996 SW2
2003 VUE 2.2L
Bernie - I've pumped out many a gas tank by jumpering the passenger fuse block and powering up the pump. I use a piece of hose that the fuel line connector will fit in then run it to my gas can.
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Old 11-15-2011, 04:46 PM   #12
PlasticCarsRock
PlasticCarsRock's Avatar
1995 SL2
The fuel pump will work fine to empty the tank. It is always running when driving. With the car not running, it will only run for a few seconds, then it is turned off to prevent draining the battery.
However, you should be careful to turn it off as soon as the tank is empty. The pump is cooled by the fuel running through it--it will very quickly overheat once the tank is empty. This is why it's bad to run completely out of gas. As long as there's fuel going through the pump you're fine (contrary to some people claiming that anything below 1/4 tank will ruin the pump).
Add to PlasticCarsRock's Reputation
Rate the quality of this post and help PlasticCarsRock reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Battery Draining - Don't know why Neophyte Ion General 12 05-11-2009 11:52 PM
oil not draining sally S-Series Tech 7 10-12-2008 11:01 AM
Coolant draining arunsam3000 S-Series General 12 01-13-2006 02:04 AM
A/C cycling/draining 9TWOSC Miscellaneous Tech 5 05-07-2003 01:00 PM
Draining fuel tank bryan_johnson Miscellaneous Tech 11 04-23-2003 10:40 AM
