View Poll Results: What is the best set of Headers to buy.
OBX Ceramic Headers 1 50.00%
Pacesetter Headers 0 0%
OBX Performance Headers 1 50.00%
Voters: 2. You may not vote on this poll
Old 05-12-2010, 12:54 AM   #1
bcdad007
bcdad007 is on a distinguished road
Attention Timing Help on 98 SC2!!!!!!!!!
I just bought a 98 SAturn SC2 with a 1.9L DOHC. the motor came to me without a cylinder head attached!! how do i line up the camshafts and cranks so that the engine runs in time correctly¿?¿?¿ Also does anyone have any advice on increasing airflow to the cylinders? thanks
_
alex
Add to bcdad007's Reputation
Rate the quality of this post and help bcdad007 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bcdad007 is offline   Reply With Quote
Old 05-12-2010, 02:49 AM   #2
Default Re: Timing Help on 98 SC2!!!!!!!!!
Search the threads as there are enough pictures for help with timing a dohc. As to improving airflow, there won't be any more improvement unless you have lots of money; the dohc means four valves per cylinder, the best you can have minus the turbo or NOS set-up. Saturns aren't base level race engines. These are cars for the daily drive. Anything you spend money on to improve on power will be little with more money spent on few gains that are mostly seat of the pants guesses and not done on a dyno to tell all.
Old 05-12-2010, 07:36 AM   #3
_
alex
Its more than just a picture. Itf you do not do it correctly you bend the valves.
With the chain off and the cam Journal bolts backed off till all valves are closed you turn the crank to the 9:00 position with #1 just passing TDC. This is where it should have been positioned when the chain was removed. If not you may already have a bent valve in that engine. If you PM me I will get you the full procedure.
Old 05-12-2010, 02:41 PM   #4
bcdad007
Wrench Re: Timing Help on 98 SC2!!!!!!!!!
Thanks and about the intake i am not trying to make a little sports car or nothing i just have to replace the entire intake setup from the intake to the throttle body and was wondering if their was something better i could buy to improve on some mpgs and such
Old 05-12-2010, 04:31 PM   #5
bumpdraft
bumpdraft's Avatar
1998 SW2
...and was wondering if their was something better i could buy to improve on some mpgs and such
mpgs are pretty good as is!
A steady foot at 55 to 75 mph will get you close to 38 mpg (CooperMini commercials brag about 38)
Some S_2 people get much better.
Add to bumpdraft's Reputation
Old 05-12-2010, 05:51 PM   #6
adventureoflink
adventureoflink's Avatar
having cruise control set to this is fine too
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Add to adventureoflink's Reputation
Rate the quality of this post and help adventureoflink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Help! - Timing Belt L81 - AC Delco -Rock Auto Kit - Timing Mark Question oldvue Vue Tech 5 09-16-2010 03:55 PM
Timing Chain or Timing Belt SL1/SL2 MikeJeffcoat S-Series Tech 1 06-21-2006 08:02 PM
timing chain or timing belt? burnoutking S-Series General 2 05-12-2006 09:00 AM
Timing belt or timing chain? tedsmith S-Series General 7 08-09-2005 11:17 PM
Timing Chains, Timing Belts and Design Arrogance manualman General Saturn Discussion 82 03-04-2002 03:04 PM
