what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn S-Series > S-Series Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 02-09-2010, 12:10 AM   #1
sw2dude
sw2dude is on a distinguished road
Default Compression rings
So whats the consensus on the upper compression ring? Whats the better choice 1.20mm or 1.50mm?
I should add, Im planning a rebuild on a 95 dohc. It seems like you can go either way with this year. Your thoughts?
Add to sw2dude's Reputation
Rate the quality of this post and help sw2dude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sw2dude is offline   Reply With Quote
Old 02-09-2010, 12:36 AM   #2
OldNuc is a glorious beacon of lightOldNuc is a glorious beacon of lightOldNuc is a glorious beacon of lightOldNuc is a glorious beacon of lightOldNuc is a glorious beacon of light
Default Re: Compression rings
Depends on where you live and if you have emissions inspections. The secret is to check the dimension of the piston crown to the top of the top ring grove and go with the one with the greatest dimension. If they are identical then the 1.5mm is considered a stronger ring. The minimum top dimension and thin ring is the lower emission setup.
The manufacturers catalog for the pistons has these dimensions. I am jumping to the conclusion that you are looking at the Federal Mogul Sealed Power pistons.
Old 02-09-2010, 07:59 AM   #3
sw2dude
Sorry for not being more detailed in my original post. Yes, thats correct, sealed power wh845cp .50mm have a 1.2mm top ring and the wh846cp .50mm have a 1.5mm ring, these will both work for me I'm just not sure of the benifit of th 1.5mm ring. The mid 94 and later models all have 1.2mm top rings, did saturn figure something out in 93-94 and make design change to the thinner ring for a reason maybe??? I have read that the distance from the top ring land to the top of the piston is beefer on the 1.5mm pistons. Also I'm going for a mild build maybe a 2nd intake cam. Its going to be a DD. This is why I'm not sure which ones to go with but I'm leaning towards the h846cp 1.5mm pistons.
RING KITS: wh845cp .50mm=E933K wh846cp .50mm=E932K
Old 02-09-2010, 08:53 AM   #4
sdowney717
sdowney717 is on a distinguished road
thinner rings equals less friction.
I would use chrome moly anytime i can get them.
http://www.hotrod.com/techarticles/e...ech/index.html
The impetus for these changes has been OEM requirements to reduce friction for improved gas mileage and better sealing for emissions reduction
chrome moly are really good rings last and last.
Add to sdowney717's Reputation
Rate the quality of this post and help sdowney717 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sdowney717 is offline   Reply With Quote
Old 02-09-2010, 09:16 AM   #5
The thinner ring allows decreasing the crown height and this reduces the amount of unburned fuel that is exhausted. It is an emissions issue. The thinner ring reduces the stress on the thinner top of the piston. I have the cam mod and like it and I used the 1.5mm rings. As long as you do not have the tail pipe Nazis to deal with then build it up a bit.
rings cause oil consuption??? eric02SC2 S-Series General 6 05-31-2006 07:05 AM
Detecting proper seating of new rings by compression check? roswell998 S-Series Tech 4 10-29-2004 12:27 AM
Has anyone done piston rings on their car? bbarbulo S-Series Tech 23 07-30-2004 02:57 PM
Changing rings. ProDarwin S-Series Tech 13 12-07-2002 01:41 PM
Oil! Rings or Guides? Doug_E_95_SL2 Miscellaneous Tech 7 12-15-2001 06:53 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
