Old 01-29-2010, 08:29 PM   #1
phoenixx
phoenixx is on a distinguished road
Default Replaced EGR & ECTS - Still No Fix
I am new to the board and this is my first post. Let me say first that I am glad to have stumbled on this site.
I have a 97 SL that just last week turned 100k. I am sad to say that my problem has existed for about 6 months now but thought it would take more $ to fix.
I have replaced the EGR valve and just an hour ago put on a new brass ECTS but the following symptoms still remain.
When car starts cold it the temp gauge will immediately go to the 1/2 way point (it hasn't measured the actual temp in months) and then within about 1-3 miles the needle slams to COLD but will jump between the two for a couple of miles. The RPMs jump to about 2k-2.5k and will hard downshift while the RPMs jump during the downshift.
When it is warm I will have to turn the heat on for a few minutes then flood the engine to get it to start up again. I've had to keep the heat on high to keep it from overheating as well (even during summer).
It shows all the symptoms of a bad ECTS which is now new. I took it to Auto Zone and they put their reader on it and it showed no codes. The guy there said maybe a bad PCM.
I am at my wits end on this. Looking for anyone with a clue to what my Sat may be needing.
Will check back in the morning.
Add to phoenixx's Reputation
Rate the quality of this post and help phoenixx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
phoenixx is offline   Reply With Quote
Old 01-29-2010, 08:44 PM   #2
johnny95sl2
johnny95sl2 will become famous soon enough
johnny95sl2's Avatar
Default Re: Replaced EGR & ECTS - Still No Fix
Did you change the connector for the ECTS?
Add to johnny95sl2's Reputation
Rate the quality of this post and help johnny95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnny95sl2 is offline   Reply With Quote
Old 01-29-2010, 10:05 PM   #3
bluesl2
bluesl2's Avatar
My guess is a bad ect connector or corrosion in the socket.
Add to bluesl2's Reputation
Old 01-29-2010, 10:44 PM   #4
phoenixx
I'd rather clean it before I replace it. Money's tight. Is there a cleaner that you can recommend?
Update: I've googled, I've eBayed, I've Amazoned but can't even find a supplier for the connector. I'll check out Auto Zone, NAPA, & O'Reily's tomorrow.
Any thoughts just in case that doesn't do the job?
Oh, by the way... I did disconnect the battery for about 5 minutes to reset the PCM, but didn't pull the fuse. Is that something I should do also?
Old 01-29-2010, 11:25 PM   #5
The two-wire connector is faulty; the temp needle going to the 1/2 mark is indicating an open/failed connection and then when it does connect it sends incorrect signals to the pcm, messing with the computer. Either try cleaning it (someone mentioned baking soda solution?) or replacing it with the intake air temperature connector from a junked car. You can always use a two-pin pc connector and splice the wires onto the harness. Then silicone the connections for a waterproof seal.
The coolant sensor works on signals less than 5v so any corrosion on the electrical connections will skew the signals to the pcm. You already see that in the temperature needle in the wrong place. Although cleaning the connections isn't recommended (because of the very small terminals), you can try as a last resort before replacing the connector.
Repair the ects connections as the next suggestion may help things overall.
When the ects is fixed and you see a good temperature indication/improved starting, if the temp needle stays near the 1/4 mark, replace the thermostat. They wear out by runnning cooler. Buy the 195F one. You'll also be rewarded with a hotter heater for the winter.
Old 01-30-2010, 09:48 AM   #6
DonP
Electrical contact cleaner may work for you depending on how bad the connector is messed up. If you do replace the connector, be sure to solder the connections to ensure good contact.
If all else fails you could substitute the IAT connector from you car, and use the PC-type connector for the IAT.
Note it is possible (but not likely) that you got a new but defective sensor.
If you replace the ECTS with a 220 ohm resistor you should see the temp gauge read around 3/8 scale. With a cold engine (room temperature) the ECTS should measure around 2500 ohms, higher if it is colder.
Add to DonP's Reputation
Rate the quality of this post and help DonP reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-31-2010, 02:54 PM   #7
phoenixx
Well, I cleaned the ECTS connector and even rotated it 180 degrees to see if by chance there was a difference as to how it connected, disconnected the battery again to reset the PCM, and viola... oops - no difference.
I even pulled the PCM B fuse up under the hood just in case - but no luck.
I don't want to modify the connector with a different part so I guess I will visit the junk yard and see if I can cut one there and take my soldering iron and put it on.
Will update when it's complete.
Old 01-31-2010, 09:37 PM   #8
Greg1
Greg1 is on a distinguished road
Greg1's Avatar
The intake temp. sensor and the ECTS have identical connectors so getting the intake one is the best way to go.
97 SW2 5-Sp 273k -mine
02 SC2 5-Sp 67k - best friend's
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Greg1 is offline   Reply With Quote
Replaced ECTS and now... Insulator S-Series Tech 3 04-04-2009 09:03 AM
Replaced my ECTS.. Infinitrium S-Series General 2 11-01-2008 11:21 PM
Replaced ECTS, Now What? aa4lr S-Series General 6 10-03-2008 10:58 PM
Replaced ECTS, now what? Derekleu S-Series Tech 15 12-06-2005 07:05 PM
replaced ects... etbardensc2 S-Series General 3 03-08-2005 06:04 PM
