Old 12-01-2009, 03:52 PM   #1
builtsl1tough
builtsl1tough is on a distinguished road
Default tps connector
This is my first post, but I've been using this forum for quite a while now. This site is awesome, and all of your posts have helped me work on my saturn.
I have this intermittent high idle problem. At a stop light the engine sometimes idles at approximately 1100 rpm in drive and over 2000 rpm in neutral, but if I restart the car it idles smoothly at 650 - 700 rpm.
This is what's be done so far:
The ECTS was changed years ago
I checked for leaks using carb cleaner - nothing
I cleaned the throttle body and IAC
I tested the TPS - voltage and resistance increases smoothly
I tapped on the TPS when it was idling high - nothing
Wiggling the TPS connector brings the idle back down to normal.
So I called my local saturn dealer today and a tps connector for my saturn is $56.10. I was surprised since I've found GM 3-pin tps connectors for $6 - $12. Are they the same thing or where else can I get a saturn TPS connector? Are they simply 3-pin weatherpack connectors? Because these are available at electrical supply stores for pennies.
Thanks again for all your help over the years.
2000 sl1
Add to builtsl1tough's Reputation
Rate the quality of this post and help builtsl1tough reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
builtsl1tough is offline   Reply With Quote
Old 12-01-2009, 05:43 PM   #2
bluesl2
bluesl2's Avatar
Default Re: tps connector
You could get a connector from a salvage yard possibly, while you are there I would get the tp sensor too just in case. I have seen bad tp sensors cause that problem.
Add to bluesl2's Reputation
Old 12-01-2009, 07:22 PM   #3
I would add this; if you're sure its the connectors to the tps and can buy either the junk yard complete set (tps and both connectors) or new connectors from rs-autosport.net, try the tps or simply eliminate the original three-pin connector and solder all the wires. Shrink wrap the connections for weatherproofing and drive. If the existing tps works and only needs a replacement set of three-pin connectors, adapt the junk yard set. A used tps may work just as well.
Dealer parts are simply marked up; its business, nothing personal. Its always "buyer beware".
Old 12-02-2009, 12:25 PM   #4
builtsl1tough
Thanks for your suggestions. I'll go to the junk dealer here in town and see what i can find.
2000 sl1
Tps electralux S-Series Tech 7 08-12-2009 05:38 PM
TPS CE light, replaced TPS, light came back! DJboozeAlot S-Series Tech 6 07-13-2009 01:18 AM
Tps devolic S-Series Tech 5 07-25-2007 09:21 AM
Tps? quiksc2 S-Series Tech 3 06-22-2007 02:17 PM
TPS Connector KevinVarnes S-Series Tech 4 04-14-2007 09:45 PM
