what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Ion > Ion General
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 11-06-2009, 12:41 PM   #1
notion
notion is on a distinguished road
notion's Avatar
2004 ION-2 Quad Coupe
Default Car tops out at 110?
Whenever I hit 110mph (bad idea I know) the car cuts out and "hesitates". This is a safety feature I'm sure. But it also does it when I accelerate to quickly and lose traction. I hope this is a safety feature and it's supposed to do this, but it's given me many close calls when trying to beat traffic. Is there any way to disable this?
Add to notion's Reputation
Rate the quality of this post and help notion reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
notion is offline   Reply With Quote
Old 11-06-2009, 01:24 PM   #2
plato
plato is on a distinguished road
2005 ION-2 Sedan
1996 SC2
Default Re: Car tops out at 110?
as far as the speed limiter, yes it's a safety thing based on your tires features. As far as cutting out while accelerating hard it means that you're loosing traction and the traction control is kicking in. Are you tires getting old?
Add to plato's Reputation
Rate the quality of this post and help plato reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
plato is online now   Reply With Quote
Old 11-06-2009, 03:22 PM   #3
notion
notion's Avatar
probably about 20K on the tires. Is every Ion outfitted with traction control? There's no actual traction control button but I'm guessing that it has full time traction control.
Old 11-06-2009, 04:17 PM   #4
RoadIon
RoadIon will become famous soon enough
RoadIon's Avatar
2007 ION Red Line
2007 ION-3 Sedan
No button no traction control, you are likely hitting the rev limiter when you lose traction.
Add to RoadIon's Reputation
Rate the quality of this post and help RoadIon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RoadIon is online now   Reply With Quote
Old 11-07-2009, 12:10 AM   #5
notion
notion's Avatar
Is there still a rev limiter on an auto? Also it seems like the revs are at about 3-4K, no more than normal highway acceleration.
Old 11-07-2009, 11:02 AM   #6
plato
2005 ION-2 Sedan
1996 SC2
yes, there is a rev limiter on pretty much any car/engine. I forget the exact figure for the ion, but I'd guess it's around 6K RPM.
Did you confirm if you indeed have TC? It's a button on your dash, next to the hazard lights. On the ion TC and ABS came together as a package.
If you have no TC and you are having a loss of power around 3-4K RPM then there is something else going on. Just brainstorming here, but it could be your intake manifold needing a good cleanup, new air and fuel filter, worst case a clogged cat converter.
Old 11-07-2009, 12:13 PM   #7
RoadIon
RoadIon's Avatar
2007 ION Red Line
2007 ION-3 Sedan
If your reving in park or neutral the rev limiter will not let you go above 4,000 or 4,200 rpms. As your driving the shift points are set at around 6,500. If you put it in say in first gear the car will hit the rev limiter again around 6,500.
Old 11-07-2009, 05:12 PM   #8
notion
notion's Avatar
My ion does not have traction control for sure. The way it's reacting, it would seem as though it does. It only happens when I lose traction, and I kept an eye on it today and it did it between the 1.5K mark and the 2.5k mark while the tires were spinning.
Old 11-07-2009, 06:18 PM   #9
RoadIon
RoadIon's Avatar
2007 ION Red Line
2007 ION-3 Sedan
Keep spinning the tires........maybe something else will happen.
Old 11-07-2009, 06:29 PM   #10
notion
notion's Avatar
ha. So no one elses ion does this?
Car and Driver: Astra tops in safety PaulGraz Astra General 6 08-22-2007 10:07 PM
Shuts off at 110 MPH Patchrick Ion Tech 4 12-30-2006 11:23 PM
Only 110 MPH rich2103 Ion General 66 02-01-2006 10:15 PM
110 Volt power supply Jammer Mods and Performance 8 12-23-2003 12:22 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
