#1 | ||||
![]() Join Date: Sep 2009
2004 ION-2 Quad Coupe
Whenever I hit 110mph (bad idea I know) the car cuts out and "hesitates". This is a safety feature I'm sure. But it also does it when I accelerate to quickly and lose traction. I hope this is a safety feature and it's supposed to do this, but it's given me many close calls when trying to beat traffic. Is there any way to disable this?
#2 | |||||
![]() Join Date: Mar 2006
2005 ION-2 Sedan
1996 SC2
#3 | ||||
probably about 20K on the tires. Is every Ion outfitted with traction control? There's no actual traction control button but I'm guessing that it has full time traction control.
#4 | ||||
![]() Join Date: Jul 2004
2007 ION Red Line
2007 ION-3 Sedan
No button no traction control, you are likely hitting the rev limiter when you lose traction.
#5 | ||||
Is there still a rev limiter on an auto? Also it seems like the revs are at about 3-4K, no more than normal highway acceleration.
#6 | |||||
2005 ION-2 Sedan
1996 SC2
Did you confirm if you indeed have TC? It's a button on your dash, next to the hazard lights. On the ion TC and ABS came together as a package. If you have no TC and you are having a loss of power around 3-4K RPM then there is something else going on. Just brainstorming here, but it could be your intake manifold needing a good cleanup, new air and fuel filter, worst case a clogged cat converter.
#7 | ||||
2007 ION Red Line
2007 ION-3 Sedan
If your reving in park or neutral the rev limiter will not let you go above 4,000 or 4,200 rpms. As your driving the shift points are set at around 6,500. If you put it in say in first gear the car will hit the rev limiter again around 6,500.
#8 | ||||
My ion does not have traction control for sure. The way it's reacting, it would seem as though it does. It only happens when I lose traction, and I kept an eye on it today and it did it between the 1.5K mark and the 2.5k mark while the tires were spinning.
#9 | ||||
2007 ION Red Line
2007 ION-3 Sedan
Keep spinning the tires........maybe something else will happen.
#10 | ||||
ha. So no one elses ion does this?
| Thread Tools | |
| Display Modes | |
| Car and Driver: Astra tops in safety | PaulGraz | Astra General | 6 | 08-22-2007 10:07 PM |
| Shuts off at 110 MPH | Patchrick | Ion Tech | 4 | 12-30-2006 11:23 PM |
| Only 110 MPH | rich2103 | Ion General | 66 | 02-01-2006 10:15 PM |
| 110 Volt power supply | Jammer | Mods and Performance | 8 | 12-23-2003 12:22 PM |
