what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Ion > Ion Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 11-03-2009, 03:10 PM   #1
johnk
johnk is on a distinguished road
2005 ION-3 Sedan
Default Swaybar Size
The one part I neglected to change when I did the struts and control arm bushings was the sway bar bushings and now I need to do them. I'm looking at doing the Prothane bushings, but how in the world do I determine what size swaybar is installed in my 2005 ION3 with a MT? I called my local dealer and their response was to just buy the rubber replacements from them because they will fit. My response was I'd rather only replace them once.
Does anyone know how to tell the size other than getting under the car with a micrometer and doing a measurement?
Add to johnk's Reputation
Rate the quality of this post and help johnk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnk is offline   Reply With Quote
Old 11-03-2009, 07:54 PM   #2
RoadIon
RoadIon will become famous soon enough
RoadIon's Avatar
2007 ION Red Line
2007 ION-3 Sedan
Default Re: Swaybar Size
Measure with a micrometer.
Add to RoadIon's Reputation
Rate the quality of this post and help RoadIon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RoadIon is offline   Reply With Quote
Old 11-03-2009, 08:15 PM   #3
RoadIon
RoadIon's Avatar
2007 ION Red Line
2007 ION-3 Sedan
PS: Not sure of the sizes but remember there are two front swaybars for the standard ION, FE1 suspension and FE2 suspension then you have the FE3 thats Redline only. So I'd jack up the front of the car and measure as close to the bushing and cap as possible.
Old 11-04-2009, 08:37 AM   #4
johnk
2005 ION-3 Sedan
Thanks for the responses. I'll measure it tonight so I can get the new bushings on order.
Old 11-04-2009, 09:49 PM   #5
jeepinwi
jeepinwi is on a distinguished road
My ION3 with the FE2 suspension has a 22mm front swaybar. Lift up the carpet in your trunk, and you'll see a sticker with all the RPO codes for your car. Find the one that has "FE_"...that's your suspension package. If FE2, it's likely a 22mm front swaybar. FYI, I made a set of Prothane bushing work for my swaybar. I had to grind the bracket 1/8", and they bolted in perfectly. Part number for the 22mm bushings was 9.5108R.
Add to jeepinwi's Reputation
Rate the quality of this post and help jeepinwi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jeepinwi is offline   Reply With Quote
Old 11-05-2009, 07:50 AM   #6
johnk
2005 ION-3 Sedan
Off to the trunk at lunch. Need to pick up a micrometer today as well. Thanks for the heads up on the Prothane bushing bracket.
04 Ion3 QC front swaybar size jeepinwi Ion Tech 6 09-14-2009 05:44 PM
where to get swaybar 96 irondiezl3 S-Series Mods 1 05-29-2007 11:32 PM
17" Konig Unknown, size? tire size? 92[SL2] S-Series Tech 1 05-14-2007 11:45 PM
Vue and Vue Redline Reer Swaybar size? Racer RS X Vue General 1 08-16-2005 12:17 AM
SPS swaybar + hard driving = broken swaybar mount :p Tycho Mods and Performance 11 06-19-2003 02:51 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
