what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Astra > Astra General
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Astra General Photos
by Charlie
2008 - Astra Road Test
86 photos
6 comments
by Charlie
86 photos
6 comments
by Digency
Astra - Member Photos
184 photos
56 comments
by astraglide
184 photos
56 comments
Old 11-03-2009, 10:07 PM   #21
internetjunkee
internetjunkee is on a distinguished road
internetjunkee's Avatar
2008 Astra XE
Default Re: Single halloween photo
Is the color more brown in person? They look black in the pic, which looks freakin awesome, but I really liked the color you had in your photoshop. Either way, fantastic looking car. Are you using spacers?
I don't have any halloween pics of my car but i do have crappy iphone pics of the treats i got this weekend:
I'll start a new thread when i have some updates
Mods: Window Tint (45% Front/18% Back), Blacked Out Badges, Silverstar Ultra Headlights, Stubby Antenna, Spoiler
Add to internetjunkee's Reputation
Rate the quality of this post and help internetjunkee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
internetjunkee is offline   Reply With Quote
Old 11-04-2009, 12:38 AM   #22
mdcclxxvi
mdcclxxvi is on a distinguished road
2008 Astra XR
Are you running the VMRs with adapters or wobble bolts?
I also looked at the FSDs, but they were meant more for stock height vehicle performance, and not lowering performance
The wheels are brown in direct light and fade to dark charcoal in the shade.
Project 8888
www.usAstra.com
Add to mdcclxxvi's Reputation
Rate the quality of this post and help mdcclxxvi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mdcclxxvi is offline   Reply With Quote
Old 11-04-2009, 09:04 AM   #23
Larry_va
Larry_va is on a distinguished road
2008 Astra XR
I had to use hub rings on my wheels when I installed them to get the wobble out. Just a plastic ring that goes on my wheel and fits the hub properly. You'll have to get the wheel and the hub mic'd to get the right size you'll need.
Add to Larry_va's Reputation
Rate the quality of this post and help Larry_va reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Larry_va is offline   Reply With Quote
Old 11-04-2009, 12:30 PM   #24
mdcclxxvi
2008 Astra XR
pretty much any wheel that's not OEM will need those rings, just to adapt the hub sizes so they mate up nice and snug.
Project 8888
www.usAstra.com
Old 11-04-2009, 01:10 PM   #25
internetjunkee
2008 Astra XE
From what I've read the FSDs can handle a slight drop perfectly fine. Koni's website even suggests pairing the FSDs with the Eibach Pro-Kit. Nothing lower than that though. The main reason I went with the FSDs is to maintain a decent ride comfort level after the drop. This is my daily driver so performance wasn't my number 1 priority, but I'm sure I'll still see a significant performance improvement over my stock XE suspension.
I got the wobble bolts.
Old 11-04-2009, 01:57 PM   #26
mdcclxxvi
2008 Astra XR
did you have to get them from overseas? I havent seen too many places in the US that have the variable PCD bolts in the 12x1.5 size, only the 14x1.5.
Project 8888
www.usAstra.com
Old 11-04-2009, 02:56 PM   #27
internetjunkee
2008 Astra XE
Got them from Charlie at serpentautosport.com. He's based somewhere in Los Angeles. I didn't know the Astra needed the 12x1.5 size, he's the one that told me. He had them in stock.
Old 11-04-2009, 06:25 PM   #28
szylak66
szylak66 is on a distinguished road
2008 Astra XR
  • front rebar needs to be modified to fit the bumper, rear rebar needs to be replaced with the European one
  • The foglights have to be toyed with to still use the US wiring harness
  • Obviously the exhaust has to be custom done to fit the turbo bits to it, including adding the center hanger
  • Need to drill the mounting holes in the frame for the underside of the sideskirts
Thanks for the info. I have someone who could get me a rear rebar. Do you happen to know the part # I should be looking for. Does it have to be an '08 or will a earlier model do...say '04-'08. Thanks for the help
Add to szylak66's Reputation
Rate the quality of this post and help szylak66 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
szylak66 is offline   Reply With Quote
Old 11-04-2009, 06:28 PM   #29
mdcclxxvi
2008 Astra XR
I dont think the structure changed at all for pre-facelift to post-facelift, so any 3-door Astra H rear rebar should work.
Project 8888
www.usAstra.com
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
