Old 08-12-2009, 11:47 PM   #21
eRic 02sc2
eRic 02sc2's Avatar
Default Re: Need Major Help With Mods sl2 dohc
Originally Posted by plastic torpedo View Post
LOL, an intake/exhaust combo will not give you 10-15 hp. More like 2-3 hp.
an intake/exhaust combo will give 10-15 hp depending on what intake and exhaust system you've installed and the condition of your Saturn before the upgrade. I've seen the dyno results from SPS (the "21" kit) and from S3 magazine when they did a AEM CAI and Thermal RD cat back on an SC1 that was incorrectly identified as a SC2. I talked to the dude that ran S3 magazine before it was sold and moved to point that out to him. S3 sponsored some karting nights at kart2kart and handed out free issues to us in attendance. I think I actually paid for the few issues where they installed parts on their Saturn SC1. That was one of the reasons I got a AEM SRS and Thermal RD on my 02 SC2. I didn't get the CAI because it involves cutting a hole for the intake pipe and that's not legal in the ST class that I'm running in for Solo events. also my 92 SC gained 2 hp from turning the screw on an aftermarket adjustable fuel pressure regulator after the intake and exhaust systems were installed. we actually made it more lean at full throttle compared to the stock fuel pressure. Saturn used to dump way too much fuel at full throttle. my 96 SC2 had a factory adjustable FPR and we tuned a bit more hp from it too. it didn't run quite as rich as the 92 though.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 08-12-2009, 11:52 PM   #22
eRic 02sc2
eRic 02sc2's Avatar
Originally Posted by PurdueGuy View Post
Which is helpful for those 3 miles before you have to pull over to avoid overheating.
my car only "overheats" (the fan comes on) when it's pulled over. keep moving! I use Redline Water Wetter and my fan almost never comes on unless I'm stopped in traffic for long periods of time. during track events my coolant temp is steady and the fan doesn't need to turn on.
eRic 02sc2
Old 08-13-2009, 01:17 AM   #23
Diezeltitan08
Diezeltitan08 is on a distinguished road
Diezeltitan08's Avatar
2002 SL1
Originally Posted by dorisSL View Post
let me get this straight...
you took out your cooling fan to save weight and space... then you put a wing on a front wheel drive car?
just checking.
haha no i still have the factory wing and i like the way it looks thats all...i know its strictly cosmetic but hey im not worried bout it...lol but i was running hot today in traffic...i was stuck in Woodward dream cruise traffic behind a 1970 cuda lol
Add to Diezeltitan08's Reputation
Rate the quality of this post and help Diezeltitan08 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Diezeltitan08 is offline   Reply With Quote
Old 08-13-2009, 10:09 AM   #24
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
I was thinking more along the lines of someone stuck in stop & go traffic, and having to pull over & shut the car off. The fan won't even run at highway speeds generally.
Of course, I don't have to worry about all of that, as I have an all-aluminum radiator with 2 slimfans. The car will warm up a little past normal on test & tune days where I'm doing runs almost back to back for a little bit, but it doesn't reach the point of turning the fan on.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 08-13-2009, 10:20 AM   #25
OnDaGround
OnDaGround has a spectacular aura aboutOnDaGround has a spectacular aura about
OnDaGround's Avatar
1993 SC2
I am sooo glad I never opened this thread until now. I see: fail, BS, retards, some mo' fail, some mo' BS, and countless useless posts.
OP: just remove the saturn engine and swap in a 13B, it's a direct swap and bolts right in.
Saturnless...
Add to OnDaGround's Reputation
Rate the quality of this post and help OnDaGround reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OnDaGround is offline   Reply With Quote
Old 08-13-2009, 10:55 AM   #26
Originally Posted by Diezeltitan08 View Post
Im not trying to start any kind of arguments thats not what im about.
That's the spirit!
and some lower profile tires for better acceleration)
Will help with cornering, but negligible acceleration for a street car. If you are only interested in acceleration (and it sounds like you are) you can swap your 15" tires for 14". This changes your effective gearing to give you some acceleration at a cost of fuel efficiency.
saturns are pretty good about not overheating without a fan long as its not like 90 and ur standing still but i live in Michigan so i dont have to worry about that lol.
Wait, do we live in the same state? It's going to be 89 tomorrow... and with all the orange cones and barrels, standing still is a given. Depends on where you live, though.
Only bad news is ived lightend up in the front so much i hope it still works nice in the snow...
Tip #1: weigh everything before you take it off, weigh everything before you put it on. I'll bet your custom exhaust weighs more than your fan - at least twice as much.
but im open for mods/tricks that anyone knows, im hoping for a 14/15 sec car that i can drive every day...
Haven't tried racing the saturn, but your first problem will be traction followed by lack of power as you go down the 1/4 mile.
Nothing is free - everything is a trade-off. Adding weight over the driven wheels will help, but you're adding weight. Sticky tires will help, but you're giving up tire life and mpg, etc.
Tip # 2: decide what you want out of the car before you start modding. Sounds like you are entirely interested in dragging, but also want to keep your mpg and reliability. This sets some limits around how far you can go.
Tip # 3: research. this is, IMO, the best overall saturn forum, but for performance mods, take a look at:
http://www.differentracing.com
http://www.sixthsphere.com
Also, read through the first two stickies in this forum
Old 08-13-2009, 10:56 AM   #27
welcome to the interwebz, lol, whut?
Old 08-13-2009, 03:10 PM   #28
dorisSL
dorisSL is on a distinguished road
dorisSL's Avatar
1995 SL
+1. i did it, but shortly after totalled the car
1995 SL, born 12/23/94, manual, WAI 190,500, "Doris"
(I'm Ben, the car is Doris)
you can't mulch at those speeds man, that's too fast
Add to dorisSL's Reputation
Rate the quality of this post and help dorisSL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dorisSL is offline   Reply With Quote
Old 08-13-2009, 03:12 PM   #29
OnDaGround
OnDaGround's Avatar
1993 SC2
It was too fast for you...
Saturnless...
Old 08-13-2009, 05:04 PM   #30
ruley73
ruley73 is a name known to allruley73 is a name known to allruley73 is a name known to allruley73 is a name known to allruley73 is a name known to allruley73 is a name known to all
ruley73's Avatar
2007 ION-2 Quad Coupe
Going from stock 195/60/15 to 205/50/15 won't knock 3 seconds off your 1/4 mile times, but the car is noticeably quicker since the RPMs increase and reach the powerband quicker. Fuel economy in theory should decrease, but for me the opposite was true. I was regularly getting 31-33 MPG hwy with 205/50/15s after the odometer difference was figured in without trying too hard. I went back to stock size when I put the Falkens on, and now I usually get 29-30 MPG hwy and seldom get higher than that no matter how I drive.
2007 Ion 2 Quad Coupe 5-speed manual 177K miles
2007 Chevy Equinox LT 183K miles
Add to ruley73's Reputation
Old 08-13-2009, 05:21 PM   #31
I was clocked at ~36mph (in a 40mph zone) with a reading of 42-43mph (on the speedometer) with my 205/50R15's. It was one of those camera, show the speed, trailer rigs. According to the miata tire calc it shouldn't be THAT much off at 40mph, it should be roughly that much off at ~60mph
I want the 5th gear from the MP2 back as well, 70mph and 3000rpms is pure horsehockey. Hopefully I'll have time to fix it tomorrow, the past couple days have been interesting.
Old 08-13-2009, 05:24 PM   #32
dorisSL
dorisSL's Avatar
1995 SL
nah. i took my 3 foot wing off and didn't have the downforce to keep it on the road. had to push it home like a shopping cart...
Old 08-13-2009, 10:21 PM   #33
ruley73
ruley73's Avatar
I always keep an extra set of stick-on flames in my back seat. I just slap it on the fenders and it gives me the Go-Baby-Go boost that I need to waste those pesky Evos, STIs, and Supras. LOL
Old 08-14-2009, 09:49 AM   #34
That's odd but makes a good point about the other variables - wheel weight, tire weight, inflation pressures, tire compounds, construction, etc. , that are involved in what seems like a simple change.
Also makes a good point about the need to keep records of before and after the changes. If you're not tracking the stuff, you're just guessing at what changed.
Old 08-14-2009, 10:20 AM   #35
I was clocked by one of those speed trap trailers at 43-44mph, speedometer reading ~52mph. Got the radar thing down to 36 before passing into the 40mph zone, but my speedometer was still reading ~42mph. WTF? According to the miata tire calc it should be that much off at 60mph, not 40-50mph...
And the speedometer shows 70mph @ 3000rpms with the normal MP3 transmission so I dunno what's going on.
DOHC SC2 Mods Possible HP Figures? Macgyver S-Series General 13 06-29-2009 08:51 AM
94 SL2 with major problems! briansmom S-Series General 12 06-12-2006 03:04 PM
Major Confusion...97 SL2 jigawatt77 S-Series General 1 01-19-2006 04:46 AM
First-Gen DOHC mods.... JADEDSL2 S-Series General 34 06-17-2005 04:37 PM
FS: 1992 DOHC SC w/ mods! Rob92SC Classifieds 1 03-25-2002 06:47 PM
