Old 12-04-2008, 11:51 AM   #1
rdkingryder
rdkingryder is on a distinguished road
rdkingryder's Avatar
Default Leaking
Okay I have a 2000 L 4 Cyl. It is leaking (slowly) from where the heater hose connects @ the firewall. It seems to be the stupid quick connect. My question is if there is an O ring there? Can I just cut off the quick connect and put the hose straight to the pipe that comes out of the firewall? It's the one on the drivers side (return???).
Add to rdkingryder's Reputation
Rate the quality of this post and help rdkingryder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rdkingryder is offline   Reply With Quote
Old 12-04-2008, 01:02 PM   #2
Default Re: Leaking
Read past threads about replacing the O-rings; an arm and a leg for dealer ones or very cheap at neighborhood stores with O-rings like Home Depot, Lowe's, etc.. The hard part is sizing one but also posted in the past here. One member had to buy 100 of them as bulk and gave away any first-come-first-serve. Approximate size; 3.5mm thickness, 26mm O.D., 19mm I.D. or 1/8th in. thickness, 1 in. O.D., 9/16th in. I.D.. No one has done what you're suggesting and went with the O-rings.
Leaking oil BlackSaturn S-Series Tech 0 10-30-2009 02:09 PM
Front discs leaking, rear drums leaking. Derekleu S-Series Tech 11 07-10-2007 10:14 AM
Still leaking RickKlages S-Series General 9 03-26-2007 04:48 PM
sunroof leaking? mikemrq S-Series General 1 02-15-2005 03:32 PM
. leaking . ka7ie25 Ion General 4 06-08-2003 03:20 PM
