Old 08-16-2008, 10:25 AM   #1
copyman_5
copyman_5 is on a distinguished road
Default How do I disassemble my steering wheel? My horn is stuck BEEEEEEEEEEEEEP!
Hi-
From reading a lot of the posts about horn probs such as this, I've yet to read on that had instructions on how to dismantle the steering wheel to check the contacts which I hear stick frequently.
Funny too...or not...I called Saturn and told them of my problem and that I've heard of literally hundreds of others who've had the same issue. She couldn't find any other Vue's that complained or were repaired for this problem. She did offer, however, for me to bring the vehicle in at my cost---tis all about $$$.
Thanks in advance! Steven
Add to copyman_5's Reputation
Rate the quality of this post and help copyman_5 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
copyman_5 is offline   Reply With Quote
Old 08-16-2008, 11:43 AM   #2
IMkenNY
IMkenNY is on a distinguished road
Default Re: How do I disassemble my steering wheel? My horn is stuck BEEEEEEEEEEEEEP!
The battery should be disconnected for 30 minutes before removing the airbag.
The air bag is easily removed by inserting a 1/4 inch flat tip screwdriver into the three triangular slots on the back of the column and rotating it 90 degrees to release the spring clips.
Add to IMkenNY's Reputation
Rate the quality of this post and help IMkenNY reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IMkenNY is offline   Reply With Quote
Old 08-16-2008, 12:21 PM   #3
gmsuv
gmsuv will become famous soon enough
gmsuv's Avatar
2008 VUE 3.6L
Disable the SIR system. Remove the fuse from the BCM .
Rotate the steering wheel until one of the triangular openings is accessable with a small flat-bladed tool.
Insert the small flat-bladed tool into the triangular opening to release the steering wheel inflatable restraint module from the steering wheel.
Rotate the steering wheel 180 degrees and insert the small flat-bladed tool into the triangular opening to release the steering wheel inflatable restraint module from the steering wheel.
Disconnect the horn switch and the inflatable restraint electrical connectors.
Remove the inflatable restraint steering wheel module.
If you need more info I'll be standing by.
Add to gmsuv's Reputation
Rate the quality of this post and help gmsuv reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gmsuv is offline   Reply With Quote
Old 08-16-2008, 01:14 PM   #4
gmsuv
gmsuv's Avatar
2008 VUE 3.6L
Old 08-16-2008, 07:54 PM   #5
copyman_5
Hey many thanks---I'll not be able to get to it till mid week but it sounds fairly simple. If you don't mind I'll keep you informed?
Take care, Steven
Removing steering wheel/horn tallNewfie Astra Tech 1 12-30-2009 01:59 PM
1998 SL1 horn wont work on steering wheel or keychain remote -checked fuse under hood 2002SaturnMan S-Series General 9 04-02-2006 09:11 PM
Cruise and Horn do not work on Steering wheel..need help dschwer S-Series General 5 03-03-2006 11:07 AM
stuck horn angeltrash Vue General 3 10-24-2005 06:02 PM
Horn Relay Stuck? 97wagon S-Series General 1 08-19-2003 09:28 PM
