#1 | ||||
![]() Join Date: Dec 2007
My wife’s Vue has had the instrument panel backlighting slowly dying, bulb-by-bulb. I finally took the time to replace them, 5 bulbs at $8.50 each! OUCH! The Saturn part number is 21019274 for these bulbs. See attached picture for a look at the part. Does anyone know of a better source for these? other than the dealership? I went to all three of the local auto part stores to no avail. I looked at every Web site I could come up with, and could not find these.
#2 | ||||
I went through the same thing. Dealer is the only place. I scoured the internet as well, there appears to be ZERO aftermarket bulbs. It must be a proprietary bulb design to certain GM cars.
... '99 Volvo S70 GLT '07 Camry SE V6
#3 | ||||
Proprietary bulb design, no, base - yes. Try and look for another number other than Saturn's part number such as the generic bulb number equivalent (without the GM/Saturn specific bulb base). There's a strong possibility that such a bulb exists, silk-screened on the bulb(?), and some clever disassembling of the burned out bulb replaced with the bare bulb and wiring may save you $$$ if you are inclined.
I wouldn't post the suggestion if I hadn't gone through the same non-sense with the third brake light lamps for the L-series. They are similar bulbs-in-the-plastic base arrangement but different since they are greater output lamps. Have a look; http://www.saturnfans.com/forums/sho...d.php?t=109104 ... *The CPS is the heart of the entire EFI system. No cps = dead EFI system* *There's more to a/c than just a few cans of refrigerant* *There's more to brakes than just replacing parts*
#4 | ||||
![]() Join Date: Nov 2002
2003 VUE 3.0L
How hard is it to change the dash bulbs?
#5 | ||||
Not hard at all. MAKE SURE THE LIGHTS AND ALL POWER IS OFF BEFORE DOING THIS!
1st remove the two screws on the underside of the glare shroud (over the gauges) 2nd, the lower portion of the shroud is held in with clips, lower the steering wheeel as far as it will go and pull the shroud straight toward you. (a little force is necessary) 3rd, remove the four bolts that hold the cluster in place. 4th, pull the cluster out. The tan colored hexogonal bases are the lamps, the white one is the lighting for the odomoter numbers. to test the lamp filiments: take the lamps out (1/2 turn ccw) using an ohm meter across the leads the lamp should read almost 0 ohms. An open is a bad lamp. When you install the lamps make sure to turn them fully to the stops or the tabs will not make contact and not light. I did this with the two 'opera' lamps on the top so the needles did not light up, and had to take it apart a second time just to turn the lamps 1/1000 of an inch. Hope this helps.
#6 | ||||
![]() Join Date: Jul 2007
2006 ION-2 Quad Coupe
I know you have a Vue, but I've managed to do the Ion and S-series replacement hassle-free. Read thru here for a list of aftermarket bulbs, even in color! IDK offhand which bulbs you would need though; I've never dealt with swapping a Vue's dashlight, sorry. However, I've got nothing bad to say about dealiing with superbrightleds.com so I'm sure they'd be happy to help.
... "Remember folks, street lights timed for 35 mph are also timed for 70 mph." *** 3 - 2006 Ion Quad Coupe 2.2L, Manual, Black 2 - 2002 SC2, Manual, Silver 1 - 1998 SL2, Manual, Blue
#7 | ||||
Oh, wow. I think the ION/Vue use the same cluster bulbs...
If these work I think I love you. I'm about to buy these.... soooo I'll have some pictures up soon. ... '99 Volvo S70 GLT '07 Camry SE V6 Last edited by burnout; 12-21-2007 at 02:31 AM..
#8 | ||||
![]() Join Date: Apr 2006
2001 SL2
There is a Sylvania lighting Bulb Guide
if that doesn't work, try this link If it is referring to the same bulb [instrument-general] as you replaced, I'm sorry to say that you paid $7-8 more than they would have cost you at NAPA or equivalent. If it is 194 bulbs you need, get a handful of extras. Sometimes the ones from the bin are duds, but it isn't a crisis at $0.78 per bulb. Also, the 194 bulb can be tested with a 9V battery before you install to prevent the "Oh crap, the bulb isn't the problem" panic. ... Election 08 Leave no non-performing incumbent employed! If they haven't delivered on their campaign promises yet, do you think they will in yet ANOTHER term?
#9 | ||||
Nope, unfortunately there aren't really many 194 bulbs in the vue at all. The shifter lighting is one of them, and I think the license plate bulbs are the other ones.
The cluster ones are DEFINITELY this B8.5D spec bulb. It's funny that its actually cheaper to play around with the color and go the LED route, than get the stock bulbs from the dealer! ... '99 Volvo S70 GLT '07 Camry SE V6
#10 | ||||
![]() Join Date: Jan 2006
Just purchased 10 8.5d led lights from superbright led's. Unfortunately, I believe the bulbs in the cluster are 8.4d's and not 8.5d's. There's 30 bucks in the toilet.
#11 | |||||
![]() ![]() Join Date: Aug 2006
2000 SC2
The PC118 number that many of the aftermarket cataologs have listed do not work. ... 2000 SC2 5-spd, H&R Sport springs, KYB struts, AEM CAI, Hotshot header, Prothane engine mount inserts, 1995 Teardrop II wheels, Saturn Ion MP3 stereo, heated upstream O2 sensor...231K miles
#12 | ||||
![]() Join Date: Aug 2005
With sales tax you are right around $45. For that kind of money you could get yourself a complete used cluster out of an 04-05 VUE, Equinox or Torrent. Then you have extra bulbs and something more aesthetically pleasing.
... Michelin LTX M/S2's // Optima Red // Razzi Spoiler // Westin // Hella // K&N // Clear Corners V6 Air Bag and Steering Wheel Swap http://www.saturnfans.com/forums/showthread.php?t=155754
#13 | ||||
2000 SC2
Is your sales tax about 35%? $3 x 11 bulbs x $1.10 (assuming a ridiculously high 10% sales tax) = $36.30. If you have a 2004-2007 Vue then you only need 9 bulbs because they don't have the front gauge lights.
Regardless, I see the point you are trying to get across: these bulbs are stupidly high priced. There are plenty of "more valuable" things you can get for the same amount of money. You can get LEDs for about the same price. ... 2000 SC2 5-spd, H&R Sport springs, KYB struts, AEM CAI, Hotshot header, Prothane engine mount inserts, 1995 Teardrop II wheels, Saturn Ion MP3 stereo, heated upstream O2 sensor...231K miles
#14 | |||||
![]() Join Date: Jul 2008
I'd look around for one of these: ![]() Its clearly a Theta dash, but the fuel and temp gauges are in the center- not sure if the harness would stretch enough.
#15 | ||||
Or the pontiac one, which is just the 05 Vue with different paint and fonts on the bezels
#16 | |||||
2000 SC2
#17 | ||||
![]() Join Date: Aug 2009
2002 L-Series 3.0L Sedan
I have an 04 vue cluster in my l series, and for the life of me i cannot figure this out:
Are the needles just colored red? Or are the led's in the step motors actually red. I want green needles with my white led backlighting and green odo cuz my footwell lights are white and green. I was just wondering if anyone knew about these specifics. Thanks in advance.
#18 | ||||
I actually like the Pontiac version better. It's hard to see the K/ph scale at night which can be a problem when I visit our neighbors to the North. You guys are giving me waaaayy too many ideas to do to the VUE to make it a bit different.
... "Remember, if the women don't find you handsome, they should at least find you handy" -Red Green 2005 VUE V6 AWD
#19 | |||||
2000 SC2
#20 | ||||
thank you very much now i might try to get the red off and make them green!
| Thread Tools | |
| Display Modes | |
| Instrument Panel Lighting Woes (1999 SL2) | EdHasA99 | S-Series Tech | 4 | 05-28-2008 10:31 PM |
| Instrument panel lighting | clintlight27 | S-Series Tech | 0 | 12-10-2006 09:47 AM |
| Flickering Instrument Panel Lighting | hugh | L-Series General | 15 | 11-25-2003 12:23 PM |
| Lighting | Scubasteve586 | Mods and Performance | 9 | 10-19-2002 08:46 AM |
| lighting | Sattyman | Mods and Performance | 7 | 04-22-2002 09:10 AM |
