Old 11-12-2007, 10:07 AM   #1
dogpile
dogpile is on a distinguished road
Default Car won't shift into drive...
Hi Folks,
I have a 2001 SL2 (automatic) and have been having an issue with putting the car in to drive...
When I put the car into drive, it doesn't seem to shift into gear until the car warms up. I'll back out of my driveway into a busy street, shift to drive and not go anywhere. I'll let it sit for a couple of minutes, then eventually I'll get going.
Just seems to get stuck.
Is this due to the cold weather? How can this be fixed?
Thanks.
2001 SL2 ~125,000km
Add to dogpile's Reputation
Rate the quality of this post and help dogpile reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dogpile is offline   Reply With Quote
Old 11-12-2007, 10:11 AM   #2
webbkarz
webbkarz is on a distinguished road
Default Re: Car won't shift into drive...
How does it go into reverse? Are there any trouble codes?
Del
'95 SC2
'93 BMW 325is
Tulsa, OK
Add to webbkarz's Reputation
Rate the quality of this post and help webbkarz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
webbkarz is offline   Reply With Quote
Old 11-12-2007, 10:56 AM   #3
dogpile
We'll sometimes it will go into reverse no problem, but when I shift it to drive, it won't go anywhere. I will sometime switch back to reverse when I'm stuck with no luck either. It's been very random.
2001 SL2 ~125,000km
Old 11-12-2007, 11:26 AM   #4
madpogue
1996 SW2
How frequently have you changed the fluid and filter?
Add to madpogue's Reputation
Old 11-12-2007, 11:29 AM   #5
dogpile
I believe the transmission fluid has always just been topped up, but never flushed and replaced. The filter, I'm not sure. Probably never.
2001 SL2 ~125,000km
Old 11-12-2007, 11:36 AM   #6
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
An automatic transmission is a hydraulically actuated device. No hydraulic pressure it won't operate. Proper fluid levels and pressures are necessary for operation.
Changing the transmission fluid is just as easy as the oil in your engine, change it and put a new filter on... For preventative maintenance I change my automatic fluid yearly despite the number of miles I drive.
2006 Black VUE Red Line - Now running iOS 11
Add to BobbyP's Reputation
Rate the quality of this post and help BobbyP reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-12-2007, 11:39 AM   #7
madpogue
1996 SW2
Don't flush it. Drain and replace it (and the filter) NOW. And do it at LEAST every 30,000 miles, as your owner's manual states.
Old 11-12-2007, 12:59 PM   #8
dogpile
Thanks guys. Will do.
2001 SL2 ~125,000km
Manual Shift Drive - how to? govna Aura General 3 08-22-2009 09:32 PM
Car starts in drive SL2-Guy S-Series Tech 9 08-22-2007 01:23 PM
2001 SL2 Auto trans Won't Shift into Drive. Speedyox S-Series Tech 7 03-20-2006 01:42 PM
Wont shift to drive on startup fatrat S-Series Tech 5 11-06-2005 07:59 PM
help my sl1 won't shift in drive lee92509 S-Series General 1 05-28-2005 07:48 PM
