what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn S-Series > S-Series Mods
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 09-23-2007, 08:05 PM   #1
Craig
Craig is on a distinguished road
Default Saturn TDI
Heres a thread from the Sixthsphere.com forums of what I've been up to.
http://www.sixthsphere.com/forum2/vi...=311131#311131
Add to Craig's Reputation
Rate the quality of this post and help Craig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Craig is offline   Reply With Quote
Old 09-23-2007, 11:47 PM   #2
cfg83
cfg83 is on a distinguished road
cfg83's Avatar
Default Re: Saturn TDI
Craig -
Wow!!!!
CarloSW2
Add to cfg83's Reputation
Rate the quality of this post and help cfg83 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cfg83 is offline   Reply With Quote
Old 09-24-2007, 01:58 AM   #3
cfg83
cfg83's Avatar
Craig -
Are you using the Saturn PCM (I'm thinking no)? You should take it to a Saturn dealer for an oil change ! Or maybe a VW dealer !?!?!?!?!
CarloSW2
Old 09-24-2007, 04:14 AM   #4
plastic torpedo
plastic torpedo will become famous soon enoughplastic torpedo will become famous soon enough
plastic torpedo's Avatar
2000 SL2
1994 SC2
Damn that is off the hook! What kind of power will it put down?
I know this isn't for performance, but it sure as hell looks like it will be faster than a normal 1.9L You guys could make a kit or something, I'm sure a lot of people will be interested in doing that mod. I know I would (for my next engine) if I had all the mounts and stuff!
Add to plastic torpedo's Reputation
Rate the quality of this post and help plastic torpedo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
plastic torpedo is offline   Reply With Quote
Old 09-24-2007, 06:41 AM   #5
Jim Dunlop
Jim Dunlop is on a distinguished road
Jim Dunlop's Avatar
2002 SL
1998 SL
Wowie-wow! That is truly awesome! Keep us posted.
2002 SL 1.9L SOHC 5-spd mods:
-Custom HAI
-K&N Airbox Filter
-Custom Air Dam
-PCV Catch Can
-Drilled & slotted rotors
-14x6 König Incident's, Yoko AVID's
-Grille Block (aluminum)
SCS! DD.
Add to Jim Dunlop's Reputation
Rate the quality of this post and help Jim Dunlop reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jim Dunlop is offline   Reply With Quote
Old 09-24-2007, 02:13 PM   #6
Craig
Thanks! This is one-of-a-kind at the moment; still have a ways to go with finalizing the motor mounts, axles, wiring, intercooler, coolant plumbing, ect. But it's going together surprisingly well...the TDI motor is a bit more compact in overall length, although the front mount and oil filter warranted cutting out the engine cradle crossmember for a new one. I'll keep you guys posted as things progress.
Old 09-24-2007, 04:31 PM   #7
quiksc2
quiksc2 is on a distinguished road
quiksc2's Avatar
1997 SC2
Argh. Stupid work. They have so many things blocked, we can't even do our job. I can get on here, but 6S is blocked...
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 09-24-2007, 07:10 PM   #8
cfg83
cfg83's Avatar
Craig -
Since I'm not a member of sixthsphere (yet ), I can't read this :
Q&A Thread: http://www.sixthsphere.com/forum2/vi...=311143#311143
Soooooo, can you give me some more details? Which year/model VW did the engine come from? I want to know so I can compare the curb weight of what the TDI engine was pulling to what it will be pulling in the Saturn. But I'll bet you already did this calculation, yes?
CarloSW2
Old 09-25-2007, 02:10 PM   #9
Craig
I'll go into more detail later (doing this from work), but the drivetrain is from a 1997 Jetta TDI. I looked at the shipping invoice, and it weighed 318 lbs, but that was with the pallet and axles, so I'm guessing closer to 290 lbs. There's a lot you can do with these things; a simple chip change will bump this up from 90hp/150lbs to 120hp/200lbs...there are some people out there getting 200+hp out of them with more radical tunes. I'll see if I can get some pictures posted here for those of you who are having problems with accessing the 6S site.
Old 09-25-2007, 02:33 PM   #10
madpogue
madpogue is a glorious beacon of lightmadpogue is a glorious beacon of lightmadpogue is a glorious beacon of lightmadpogue is a glorious beacon of lightmadpogue is a glorious beacon of light
1996 SW2
Hmm, a 200 hp biodiesel with a spaceframe . Now I just gotta find an old waggin with a blown motor.
Add to madpogue's Reputation
Old 09-25-2007, 06:12 PM   #11
cfg83
cfg83's Avatar
Checkered Flag Re: Saturn TDI
Craig -
Ok, then here are the specs :
1997 Volkswagen Jetta TDI Sedan Specifications
http://www.automotive.com/1997/101/v...ons/index.html
- Weights: curb weight (kg) 1,215
1215 kg = 2673 lbs
1995 Saturn S-Series Specifications
http://www.automotive.com/1995/12/sa...ons/index.html
- Weights: gross vehicle weight rating (kg) 1,429 and curb weight (kg) 1,070
1070 kg = 2354 lbs
Sooooo, 2673 - 2354 = 319 lbs lighter, but that is not taking into account the difference in weight of the engines. Also, I think the wagon may have weighed more than 2354 lbs.
CarloSW2
Old 09-25-2007, 06:51 PM   #12
geartooth94
geartooth94 will become famous soon enough
geartooth94's Avatar
1991 SL2
craig, how much did the engine run you? did you buy the trans. too ?
'91 SL2 silver-gray two-tone resto-mod converted to manual trans. 73K miles
'95 SC2 gas mileage: 25mpg
----------oil mileage: 1,025 mpg
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline   Reply With Quote
Old 09-26-2007, 08:34 PM   #13
Craig
I got everything out of a Jetta that was being parted out (motor, trans, ECU, wiring, intercooler, various bits, ect) for $2300, plus another $350 to ship it from California to Maine. If you ever have to have something like this shipped, have it shipped to a business, such as your employer like I did with mine. It's cheaper that way, and I just had one of my coworkers bring it to my house in his truck.
A couple of things I've done so far: I made up a new piece to fit the Saturn clutch master cylinder with a 1/8" FPT so I can use it to work the Jetta clutch slave cylinder, and I blew the Saturn shifter apart so I can rework it for the Jetta shift pattern. I'll get some pictures of this up so you can get a visual of what I am talking about.
Old 09-27-2007, 09:45 AM   #14
sc2dave
sc2dave is on a distinguished road
sc2dave's Avatar
same here,supposedly i can only use it for business purposes,but i can get on hotmail,bank of america, ANCESTRY.COM.Why the hell would someone need to check on their ancestry at work?
www.bold-fortune.com
Add to sc2dave's Reputation
Rate the quality of this post and help sc2dave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sc2dave is offline   Reply With Quote
Old 09-28-2007, 05:55 PM   #15
quiksc2
quiksc2's Avatar
1997 SC2
I can't even get on Hotmail anymore. And I use my email for work purposes. It's how I stay in contact with all of my reps.
DCS
Old 09-28-2007, 10:05 PM   #16
bgates2b
bgates2b is on a distinguished road
bgates2b's Avatar
2007 AURA XR
1994 SL2
Gotta update the links for the new server Craig
"Congratulations on your brand new 2007 Acura" - Tenisha, the On*Star rep that handled my call during the Aura's delivery
Add to bgates2b's Reputation
Rate the quality of this post and help bgates2b reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bgates2b is offline   Reply With Quote
Old 10-30-2007, 08:04 PM   #17
Craig
Sorry to be so long in updating this...between work and school, I haven't had much time for anything else! But here is a link to the TDI Club forum that I just started a thread on http://forums.tdiclub.com/showthread.php?t=193909 that I hope you find useful. I've been working on the wiring harness and various mounting brackets, plus I have some pictures of the modified Saturn shifter I built to work with the VW transmission.
Old 01-19-2008, 08:41 PM   #18
Craig
Haven't been to this site in awhile, saw this mentioned in another engine swap thread and couldn't resist bumping it up. Progress has been slow but steady...the wiring harness is "almost" done, I now have axles and a shift linkage, currently have the shifter back out of the car for a reverse lockout mechanism. Winter makes it a little hard to work on it, but I've been making a lot of little parts i.e. exhaust flanges and stuff like that.
Old 01-20-2008, 05:37 PM   #19
Cat Fuzz
Cat Fuzz is on a distinguished road
Cat Fuzz's Avatar
1992 SL2
Dang, that metal fab work is giving me wood. I would love to be able to fab stuff like that.
94 Saturn SL2 Auto (sold!)
99 Dodge Grand Caravan Sport
99 Isuzu Rodeo V-6, 4WD (new fave)
63 Mercury Comet Convertible
Add to Cat Fuzz's Reputation
Rate the quality of this post and help Cat Fuzz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cat Fuzz is offline   Reply With Quote
Old 01-20-2008, 07:48 PM   #20
Craig
Thanks! I can make lots of things, but the only thing I can't seem to make is money!
Seriously, though, if you really want to learn more about metal fabrication, check with your local high school or college about courses in welding, machining, ect. Another really good source is www.lindsaybks.com for some excellent books on these and many other topics. I'm forever takings courses or reading/researching textbooks, the internet, engineering publications, ect; I'm currently enrolled at Southern Maine Community College in their Integrated Manufacturing Technologies degree program...I'm working on the academics at the moment (Business, Calc, Physics, ect), can't wait to get into their machining program!
On the other hand, I wish I could cook...
Driving Saab 9-3 1.9 TDI with 6-speed manual AuraXRFan Aura General 79 03-07-2008 09:43 AM
Saturn TDI conversion in progress. aja8888 S-Series Tech 3 01-16-2008 12:13 AM
Saturn with a TDI Diesel. ayeayemate S-Series Tech 7 01-09-2008 11:46 AM
Saturn Racing Group Saturn Show at Saturn of Tempe ry92sc Events 7 01-23-2005 08:38 PM
JETTA TDI... Any Comments SaturnGuy3 General Saturn Discussion 12 02-10-2001 09:59 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
