Old 07-19-2007, 06:43 PM   #1
Robertmoss
Robertmoss is on a distinguished road
Robertmoss's Avatar
Default P0455 Code
I own a 2003 L series sedan, 4cylnder. My check engine light came on with code P0445 I know its a Evaporative Emission Control System Leak Detected (gross leak). I read up in the forums but not sure this is directly addressed as this cant be just a loose gas cap. Anyone have any info on this code, do I need to rush to get it fixed, can a novice fis it himself? I have had a number of issues with the emissions system with thi car O2 sensor replaced last year, had to explain to saturn that they needed to replace the catalytic converter after reading up on it here in this forum. Car ran fine after $400 of unnecessary repairs and the new Cat. Thanks in advance for your advice!
Add to Robertmoss's Reputation
Rate the quality of this post and help Robertmoss reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Robertmoss is offline   Reply With Quote
Old 07-20-2007, 08:38 PM   #2
scort_beater
scort_beater is on a distinguished road
Default Re: P0455 Code
i work as a technician i see that code alot just check your gas cap to make sure you tightened it up get the the codes cleared out if it comes back on go to saturn and buy a new fuel cap if on again replace the charcoal canister but the fuel cap seems to fix it 9 times out of 10
Add to scort_beater's Reputation
Rate the quality of this post and help scort_beater reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scort_beater is offline   Reply With Quote
Old 08-01-2007, 08:50 PM   #3
Robertmoss
Robertmoss's Avatar
thanks, didnt even have to do that, went away a week laer and hasnt come back..whew...
Old 01-24-2010, 10:58 PM   #4
kknobl
kknobl will become famous soon enough
kknobl's Avatar
2009 AURA XE
2008 Outlook XE
Just curious, where is the charcoal canister located, and is it a DIY job on a 2003 L300?
Thanks!
Add to kknobl's Reputation
Rate the quality of this post and help kknobl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kknobl is offline   Reply With Quote
Old 01-24-2010, 11:48 PM   #5
Its on top of the gas tank.
Old 01-25-2010, 12:42 PM   #6
born again
2000 L-Series 2.2L Wagon
I may be wrong here but didn't someone report that the canister is part of the gas tank and can't be separately replaced?
Old 01-25-2010, 01:03 PM   #7
Its replaceable according to the FSM.
check engine code 11, coolant hot light flashes code 23, 95 SL2 2003MercMaraude S-Series Tech 2 10-23-2009 05:17 PM
P0455 kknobl L-Series Tech 3 08-05-2009 06:37 PM
P0455 - Evap Leak Large hufhouse L-Series Tech 0 10-25-2006 07:32 AM
95 SL2, SES Code 32 and Coolant Code 84? gkainz S-Series Tech 15 04-04-2005 09:43 PM
vin egine code to original code how to check? silver97sl General Saturn Discussion 1 01-12-2004 04:17 PM
