Old 07-06-2007, 12:30 PM   #1
Admiral Beez
Admiral Beez is on a distinguished road
Admiral Beez's Avatar
2000 SL2
Default Oil Capacity for 2000 SL2
Hello,
Can someone please advise me of the oil capacity for the 2000 SL2. I've searched everywhere for engine specs, but all I can find is the usual 1.9L, DOHC stuff. How much oil does the engine hold up the fill level on the dip stick.
Thx
Add to Admiral Beez's Reputation
Rate the quality of this post and help Admiral Beez reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Admiral Beez is offline   Reply With Quote
Old 07-06-2007, 01:03 PM   #2
TXSaturn02
TXSaturn02 will become famous soon enoughTXSaturn02 will become famous soon enough
TXSaturn02's Avatar
Default Re: Oil Capacity for 2000 SL2
I believe Wolfman once said 4.25 qt. - even though the manual might say 4
Sticker: $13,995
As of 03/13/13: 179,571 Miles
Old 07-06-2007, 01:51 PM   #3
WingsOfSaturn
WingsOfSaturn will become famous soon enoughWingsOfSaturn will become famous soon enough
WingsOfSaturn's Avatar
I always put in the 4 qts the manual recommends. Then end up topping it off with about 1/4 quart. Wolfman is always right.
"When you stop to fill up on oil, don't forget to check the gas"
98 SL2 MT 213K+ Daily Driver 38+ mpg
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Add to WingsOfSaturn's Reputation
Rate the quality of this post and help WingsOfSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WingsOfSaturn is offline   Reply With Quote
Old 07-06-2007, 02:13 PM   #4
MrWhsprs
MrWhsprs is on a distinguished road
MrWhsprs's Avatar
2000 SL2
1999 SW2
Originally Posted by romzek View Post
I always put in the 4 qts the manual recommends. Then end up topping it off[...]
That's also a good way to do it if one is using a slightly oversized filter... :-)
<>< Mike
1999 SW2: 256,639 mi.
2000 SL2: 112,830 mi.
(as of 1/1/2013)
Add to MrWhsprs's Reputation
Rate the quality of this post and help MrWhsprs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MrWhsprs is offline   Reply With Quote
Old 07-06-2007, 05:16 PM   #5
adhsc2
adhsc2 is on a distinguished road
adhsc2's Avatar
its 4qt stock, but its always good to go about 1/4qt over to compensate blow by and such. as stated above, wolfman is always right, you will do good to not question him, if you read anything that he posts, lol
1995 Saturn SC2
Screw engines...I R HAVS A POWER MODULE!
Member of: Saturn Tuners Club - Southeast
Add to adhsc2's Reputation
Rate the quality of this post and help adhsc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
adhsc2 is offline   Reply With Quote
Old 07-06-2007, 11:17 PM   #6
eRic 02sc2
eRic 02sc2's Avatar
Wrench Re: Oil Capacity for 2000 SL2
Originally Posted by Admiral Beez View Post
Hello,
Thx
the S-Series Owner's Handbook in my Saturn glove box says 4 quarts (3.8L)
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 07-06-2007, 11:24 PM   #7
TwinRevver
TwinRevver is on a distinguished road
A little more oil cant hurt u since it has to go thru the whole system and wait until u try a dodge viper oil filter on the saturn (it fits) It uses up almost 1 QUART!!!
Add to TwinRevver's Reputation
Rate the quality of this post and help TwinRevver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TwinRevver is offline   Reply With Quote
2000 SW2 Coolant capacity? weezerdeadcat S-Series Tech 3 11-03-2008 10:32 PM
what's my oil capacity? bflan2001 S-Series General 23 04-02-2007 01:58 PM
1992 SL2 A/C compressor oil capacity seanseaghan S-Series General 2 06-27-2006 06:50 PM
1992 SL2 A/C compressor oil capacity seanseaghan S-Series Tech 0 06-27-2006 02:18 PM
oil capacity on 95 sl2 whitesl2 S-Series Tech 3 06-24-2002 09:00 AM
